Scale Props
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 Piper J-3 Cub 40 - RTF
Seller:  DAVIS300
Details:   $375.00   |  11/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> Scale Props
Page: [1]
Login
Scale Props - 3/26/2002 7:10:25 PM
RONSTERMONSTER
Status: offline
I found out the hard way that you cannot paint a Master Airscrew prop with acrylic paints . The paint just peeled off . I then tryed prefect paint primer that seemed to stick ,then painted the acrylic on looked good . I then painted my tip looked even better . I was then going to put lusterkote clear over it . I did this on my inter aileron strust over aluminium and it turned out great . So I was home free I thouht till I sprayed on the clear and bam !! . All the paint started to crinkle . I guess that I will have to get a wood prop and shape it a little and the paint . Also can you fly with a prop you painted your self. I am posting a pic of the plane I am putting the prop on . The engine on this plane is a 1.08 asp with a 15x8 prop that looks very scale in size .
Ron
       Post #: 1
Scale Props - 3/27/2002 5:27:59 AM
HuskerBoy
Status: offline
Ron:
You didn't mention whether all the acrylic was lacquer or enamel
Basic rules are (hope not to insult if you already know)
enamel can go over lacquer not vice-versa
The new enamels most often say on can that an additional coat
can be applied within 30 min. of first coat-- then after that you
must wait 3 days ( which I usually wait a week ). On your second
coat apply a light tack coat,wait a few minutes then apply more.
Don't put on a heavy second coat or it will blister even after wait-
ing the required time.
Lot of pilots paint their scale props -- but you have to be cautious not to put it out of balance.
_____________________________
Randy
AMA# 56432
(in reply to RONSTERMONSTER)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU3
