RE: G.P Super Sportster 40 dual build
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: G.P Super Sportster 40 dual build Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: G.P Super Sportster 40 dual build - 6/7/2009 9:48 PM
wzak29
Score: 113
Last Login: 3/12/2010
Status: offline
I need to see how you routed the tubing inside the plane from the firewall to the servo and over 2B.
< Message edited by wzak29 -- 6/7/2009 10:01 PM >
_____________________________
According to my calculations the problem does not exist
Hide Signatures
(in reply to shd3920)
       Post #: 276
RE: G.P Super Sportster 40 dual build - 6/7/2009 10:32 PM
shd3920
Score: 195
Status: offline
Here it is, just finished . . .
Photo 1: Lining the pushrod tube with the cable so I can glue it in
Photo 2: Steering pushrod epoxied in
Photo 3: At the firewall
Photo 4: Former F2B
Photo 5: Servo end, make sure it is lined up real good with the servo EZ connector
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to wzak29)
       Post #: 277
RE: G.P Super Sportster 40 dual build - 6/7/2009 10:42 PM
wzak29
Score: 113
Status: offline
Looks real good glade I ordered 8 of those EZ connectors will get started as soon as I receive my order with the steering arm, never used cable but you made it look easy. In photo #5 did you add a block of wood? are you shure the fuel tank will fit?
Hide Signatures
       Post #: 278
RE: G.P Super Sportster 40 dual build - 6/7/2009 10:59 PM
tschuy
Score: 101
Status: offline
quote:
ORIGINAL: shd3920
Photo 4: Former F2B
Nicely done.  Only thing I would have done different is reversed the middle servo to allow hook-up of the linkages without worry of binding against each other...
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 279
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:09 AM
wzak29
Score: 113
Status: offline
Post #262 shows me using a steel pushrod for the throttle I am changing this to cable. The reason for the change is that at some point I will have to remove the engine from the top of the cowl can’t do that with a rod need the flexibility of a cable. Photo (1) the throttle cable, photo (2) shows the EZ connector with bolt facing engine it must be this way or it will hit the cowl side.
Click for fullsize
Click for fullsize
< Message edited by wzak29 -- 6/8/2009 2:27 AM >
Hide Signatures
(in reply to tschuy)
       Post #: 280
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:11 AM
shd3920
Score: 195
Status: offline
I glued a small piece of scrap balsa about 1/4"x1/2" behind the pushrod tube to keep it lined up with the servo arm connector because you can not glue it directly to the fuselage side.
Yes there is more than enough room to fit a 10 oz tank in the compartment, but you will need to widen the opening in F2 so you can slide the tank through.
Hide Signatures
       Post #: 281
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:13 AM
shd3920
Score: 195
Status: offline
I never use anything but a cable pushrod for steering and throttle. So much easier. Aren't you glad I sent you the cable now even though you told me not to ?
And although it is not shown in a photo, the pushrod exit tube is now cut flush with the front of the firewall.
Photo 1: Started fuelproofing the tank compartment with 30-minute epoxy while I have easy access
Photo 2: Went back to the wing and epoxied the ply wing plate on
Click for fullsize
Click for fullsize
< Message edited by shd3920 -- 6/8/2009 2:20 AM >
Hide Signatures
       Post #: 282
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:31 AM
wzak29
Score: 113
Status: offline
did you see the change I made to the throttle? added photos
Hide Signatures
       Post #: 283
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:34 AM
wzak29
Score: 113
Status: offline
I will fuel proof mine after I install the steering cable, thank you for the cable!
Hide Signatures
       Post #: 284
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:35 AM
tschuy
Score: 101
Status: offline
quote:
ORIGINAL: wzak29
Good job on the throttle cable installation.  I may have done if different by extending the cable sleeve out closer to the carburetor.  This would help minimize the amount of flex that the cable has.  Being that this is a throttle it may not be an issue for you.  A quick test is to press against the carburetor arm and see how much the throttle cable flexes.
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 285
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:37 AM
wzak29
Score: 113
Status: offline
there is no flex and the cable moves very easy
Hide Signatures
       Post #: 286
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:40 AM
shd3920
Score: 195
Status: offline
Isn't it going to be hard taking the cable out of the throttle hookup with the screw facing the engine? You don't really need to remove it, just slide the cable out with it still attached to the throttle arm.
Are you using a plastic retainer on the EZ connectors? You should use the metal retainers when you permanently attach them. I am using the plastic just for setting them up, I will be using the metal when permanent. And don't forget the threadlock when using the metal retainers.
Hide Signatures
       Post #: 287
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:42 AM
tschuy
Score: 101
Status: offline
quote:
ORIGINAL: wzak29
Awesome.  I guess using the heavier cable solved the issue....
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 288
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:43 AM
wzak29
Score: 113
Status: offline
at full throttle it's easy to get to the EZ screw, will change to metal when my order gets here. also ZAP thread lock
Hide Signatures
       Post #: 289
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:57 AM
RCKen
Score: 192
Last Login: 3/5/2010
Status: online
You don't want to use the metal retainer on your throttle arm. Metal to metal contact such as the retainer on the throttle arm can produce RF noise, which can interfer with your radio. I've seen plane brought down by using metal on the throttle arm like this. Use the nylon retainer clip.
Ken
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
AMA# 712539 - www.gettingairborne.com
Hide Signatures
       Post #: 290
RE: G.P Super Sportster 40 dual build - 6/8/2009 3:05 AM
shd3920
Score: 195
Status: offline
quote:
ORIGINAL: RCKen
Ken
Thank you for that info ken, I stand corrected. So glad you are around to straighten us beginners out
We were told to use the metal retainers on the control surface EZ connectors, different thread started by wzak http://www.rcuniverse.com/forum/m_8806518/tm.htm How does that not interfere with radio transmissions?
< Message edited by shd3920 -- 6/8/2009 3:12 AM >
Hide Signatures
(in reply to RCKen)
       Post #: 291
RE: G.P Super Sportster 40 dual build - 6/8/2009 11:31 AM
TomCrump
Score: 100
Status: offline
quote:
ORIGINAL: wzak29
Tom
Glade to hear the maiden flight went well and that the SS fly’s well with adequate control, beautiful photo of the landing did you set the throws exactly as stated in the manual?
Thanks.
The controls were not set according to the manual. I just set them so that they looked right, to me. Remember, this is my 3rd Sportster, and I've built over 20 models in the last 20 years.
At your experience level, I suggestthat you set them per the manual. Then have them checked out by an experienced club member, before flying.
Tom C
Hide Signatures
       Post #: 292
RE: G.P Super Sportster 40 dual build - 6/8/2009 12:07 PM
wzak29
Score: 113
Status: offline
I have been a electronic technician for 40 years and worked in RF for 30 years I also hold a general class amateur radio license. I have seen a lot of weird stuff but I don’t buy the noisy rf connector. I guess the two dissimilar metals and the fuel could act as a dielectric but to put out enough RF noise to interfere with a FM duel conversion receiver is not possible. As far fetched as it sounds it would only be possible with a AM receiver and I still don’t believe it. And if it was true it would not come from the steel back plate it would be the brass shaft and the steel throttle arm (dissimilar metals) and you still have this even with a nylon retainer.
< Message edited by wzak29 -- 6/8/2009 12:16 PM >
Hide Signatures
       Post #: 293
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:13 PM
homeboy61
Score: 100
Status: offline
Wow I have read this whole thread and love all of the info that has been passed around!!!!!!!!!!!!!!   Keep it comming guys I have only been in this hobbie or obsesion as my better half calls it  for about 4 years and need and will use  all of this info from ya`all  I have an 46 supersporster with an tower hobbies .46 on it and it hauals ass very fast and adjile !!!!  My best friend put an tower hobbies .75 on his supersporster and almost broke the sound barrier ( HA HA  the speed was awsome and it still handeled very well speed was well over 120 mph we had a cop that was our bud radar it @ our field he was amazed @ the speed !!!
Not much info being passed along here but just thought I would throw my hat in on it !!!!!!
Thank everyone one again very much for all of the info giving out here AWSOME THREAD AND TO THE GUYS BUILDING AND TAKING THE PICS AND AWSOME JOB KEEP IT UP !!!!!!!!!!!!!!!!!
HomeBoy
homeboy@iowatelecom.net
< Message edited by homeboy61 -- 6/8/2009 2:25 PM >
Hide Signatures
       Post #: 294
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:42 PM
CGRetired
Score: 118
Status: offline
This is with your vast experiences in RC, right?  RF noise is RF noise.  It tends to get in all sorts of unwanted areas, especially in close proximity to another RF source, the RC receiver.
Many many people with years of  RC experience offer assistance in various subjects, not only for engine throttle linkage.  This is not a new subject.  They offer help because they've seen it.. you know, the old been-there-done-that.  Good safe and sound practices make for good and safe RC flying.  Hey, if you don't believe what they have to say, there is absolutely no need to try to denounce what they have to say based on their experiences.  If you don't like it, don't follow their advice.  We can be assured of one thing.. sooner or later, we will see a posting from you in the crash forum about a crash for un-known reasons.
CGr.
< Message edited by CGRetired -- 6/8/2009 2:48 PM >
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
       Post #: 295
RE: G.P Super Sportster 40 dual build - 6/8/2009 2:53 PM
bruce88123
Score: 100
Status: offline
Let's see, I've been involved with electronics since 1963, BS-EET, worked in Avionics since 1976 and in RC since 1978 and have Comercial Radio Telephone Licencse. I believe in the RF interference fairy. CGRetired also has much experience.
3-D is for Monster Movies
Hide Signatures
(in reply to CGRetired)
       Post #: 296
RE: G.P Super Sportster 40 dual build - 6/8/2009 3:09 PM
shd3920
Score: 195
Status: offline
We were told to use metal retainers on the control surface servos. Is that still ok? http://www.rcuniverse.com/forum/m_8806518/tm.htm
< Message edited by shd3920 -- 6/8/2009 3:15 PM >
Hide Signatures
(in reply to bruce88123)
       Post #: 297
RE: G.P Super Sportster 40 dual build - 6/8/2009 3:18 PM
RCKen
Score: 192
Status: online
It won't matter on control surfaces because the retaining clip will be in contact with the nylon control horn which will not cause RF noise. However, still wouldn't use a metal retainer clip because you will never be able to get it back off again. And this will cause problems when you need to perform maintenance on it.
Ken
RCU Forum Manager
Hide Signatures
       Post #: 298
RE: G.P Super Sportster 40 dual build - 6/8/2009 3:20 PM
shd3920
Score: 195
Status: offline
OK, so plastic retainer on throttle hookup, gotcha
Hide Signatures
(in reply to RCKen)
       Post #: 299
RE: G.P Super Sportster 40 dual build - 6/8/2009 3:24 PM
bruce88123
Score: 100
Status: offline
SOME engines have plastic/non-metal arms. Metal clevis's or linkages are OK on those.
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.717RCU1
