RE: G.P Super Sportster 40 dual build
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: G.P Super Sportster 40 dual build Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: G.P Super Sportster 40 dual build - 5/25/2009 12:53 PM
wzak29
Score: 113
Last Login: 11/20/2009
Status: offline
Started building the fuselage had to stop and recharge my drill so I can drill the formers.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
According to my calculations the problem does not exist
Hide Signatures
(in reply to shd3920)
       Post #: 126
RE: G.P Super Sportster 40 dual build - 5/25/2009 1:54 PM
shd3920
Score: 175
Last Login: 11/22/2009
Status: offline
Looking good wzak29. I assume you will be using the full pushrod system. I think I will attempt to use the transfer links if I can. I will not be continuing with my build until I hear from you again.
Hide Signatures
(in reply to wzak29)
       Post #: 127
RE: G.P Super Sportster 40 dual build - 5/25/2009 3:12 PM
wzak29
Score: 113
Status: offline
I will be using the pushrod system that came with the plane, I need to let the fuselage with doublers dry a few hours and let my drill charge. Will be back building this afternoon if it’s not to hot the room I’m building the plane in is a sun room/office it’s the only room in the house without A.C.
Hide Signatures
       Post #: 128
RE: G.P Super Sportster 40 dual build - 5/25/2009 5:33 PM
wzak29
Score: 113
Status: offline
page #17
D 8. Use 6-minute epoxy to glue F-1B to F-1C and F-2 to
F-2B. Important: F-1B is slightly shorter than F-1C to
allow for the angle of the cowl bottom. The same height
difference applies to F-2B, which is shorter than F-2.
My f-1b and f-1c are the same size, same with f-2b and f-2.
Also the photo of 1c has 4 holes in it nowhere does it tell you to drill holes in 1c.
Need some instructions and photos before I epoxy these and screw it up!
Click for fullsize
< Message edited by wzak29 -- 5/25/2009 5:39 PM >
Hide Signatures
       Post #: 129
RE: G.P Super Sportster 40 dual build - 5/25/2009 6:42 PM
shd3920
Score: 175
Status: offline
I glued the pieces together with Elmer's Glue-All and they are fine, so you can use wood glue instead. I am only going to use epoxy on high stress points such as firewall and tailfeathers.
Do not worry about the formers being the same size, they were for me too, if we need to cut a angle into them later we can easily. And do not worry about there not being holes as pictured. The holes will be drilled through that former when we drill the firewall. We can go as far as drilling the mounting holes in the firewall and gluing the firewall in place because the hole locations are the same for any size engine. The mounts slide apart to adjust for any size motor in the range given. I will be ordering the motor around the 3rd and probably receive it around the 10th. A long time to wait but I will find plenty to do during the wait.
How far are you now?
Click for fullsize
Hide Signatures
       Post #: 130
RE: G.P Super Sportster 40 dual build - 5/25/2009 8:08 PM
jrcaster
Score: 100
Last Login: 10/3/2009
Status: offline
The difference in size is minimal.  If you look at the picture in step 9 on page 17 you can see the difference.
Kit building is the fine art of persuasion. Please line up.
Hide Signatures
       Post #: 131
RE: G.P Super Sportster 40 dual build - 5/25/2009 8:59 PM
wzak29
Score: 113
Status: offline
I use my computer with Adobe reader to build with, I magnified that step to 400% and could not see the difference.
shd3920 need to see photos of these two formers mounted does that big hole go forward or aft?
Hide Signatures
(in reply to jrcaster)
       Post #: 132
RE: G.P Super Sportster 40 dual build - 5/25/2009 9:31 PM
shd3920
Score: 175
Status: offline
Photo 1: Wing forward mount holes in former F2 was not big enough for me to slip the wing dowels in, had to drill them bigger.
Photo 2: Drilling holes in F2 bigger.
Photo 3: Fitting fine now.
Photo 4: Formers F1 & F2 assembled and glued to fuselage crutch with 30-minute epoxy. Make sure the hole in F1C is facing into the fuselage. I wanted to have the extra strength of a piece of 1/2" tri-stock.
Photos 5, 6 & 7: Tail doublers glued in place. May have to squeeze these in carefully to have them meet flush inside against former F7.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 133
RE: G.P Super Sportster 40 dual build - 5/26/2009 12:15 AM
wzak29
Score: 113
Status: offline
 I wanted to have the extra strength of a piece of 1/2" tri-stock. do I need to do this?
< Message edited by wzak29 -- 5/26/2009 12:31 AM >
Hide Signatures
       Post #: 134
RE: G.P Super Sportster 40 dual build - 5/26/2009 1:58 AM
shd3920
Score: 175
Status: offline
quote:
ORIGINAL: wzak29
No, it is not necessary. I just always feel safer when the firewall has tristock braces behind it.
Hide Signatures
       Post #: 135
RE: G.P Super Sportster 40 dual build - 5/26/2009 2:08 AM
shd3920
Score: 175
Status: offline
WARNING!!!!!
The plans/manual instructs you to keep the fuselage top pinned to the board when gluing the sides on.
I did not find this possible as the joints were very poorly constructed and some of the notches had to be touched up to make firm contacts.
I highly recommend you remove the fuselage from the building board and rubber-banding and clamping it together BEFORE gluing (as pictured below). DO NOT apply any glue until the fuselage is perfectly squared and all the joints are firmly together without any gaps along the length of the entire fuselage. It was very difficult and took me an hour just to get the sides to meet all the joints properly, keeping the fuselage square. But it came out real good and was worth the trouble.
I tacked all attaching points with CA with accelerator, adding thick fillets of Elmer's Glue-All the entire fuselage length. I also recommend adding the tail end filler right away during assembly of the fuselage sides.
I will be reinforcing the firewall assemblies with tristock and epoxy, but I am out of epoxy at the moment. Good luck assembling the fuselage sides, take your time, it will be tough. And remember that many of the notches will have to be widened.
Contact me any time if you need further assistance.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 136
RE: G.P Super Sportster 40 dual build - 5/26/2009 3:30 AM
jrcaster
Score: 100
Status: offline
Go back to my build on page 3.  If you lift it off of the board to glue it up you run the chance of introducing twist.
Hide Signatures
       Post #: 137
RE: G.P Super Sportster 40 dual build - 5/26/2009 5:38 AM
shd3920
Score: 175
Status: offline
quote:
ORIGINAL: jrcaster
No twist, my fuselage is perfectly square and level. The choice is yours wzak29 of course, but if you keep it pinned to the board take your time and make sure all the tabs and notches fit into each other perfectly before you start gluing.
The transfer links are not going to work for this build, fuselage too narrow, so I will be following manual instructions
Hide Signatures
       Post #: 138
RE: G.P Super Sportster 40 dual build - 5/26/2009 12:35 PM
wzak29
Score: 113
Status: offline
I left fuselage pined to the building board dry fitted the sides everything lined up perfectly so I glued on the sides and tail wedge. Used wood glue on the side of the firewall and wing support also on the tail doublers and tail wedge CA on the rest. dry fitted the bottom perfect fit! will add fillets when it's dry.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by wzak29 -- 5/26/2009 12:43 PM >
Hide Signatures
       Post #: 139
RE: G.P Super Sportster 40 dual build - 5/26/2009 2:52 PM
wzak29
Score: 113
Status: offline
Added fillets of wood glue to firewall and wing support formers I also had to drill out the holes for the wing dowels, soaked holes with thin CA.
Click for fullsize
Hide Signatures
       Post #: 140
RE: G.P Super Sportster 40 dual build - 5/26/2009 3:51 PM
wzak29
Score: 113
Status: offline
Added fillets of medium CA over all formers, gluded on bottom with CA installed pushrod tubs.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 141
RE: G.P Super Sportster 40 dual build - 5/26/2009 4:59 PM
shd3920
Score: 175
Status: offline
It is always best to use epoxy around the firewall. Also best if you can get triangle stock for support behind the firewall.
Hide Signatures
       Post #: 142
RE: G.P Super Sportster 40 dual build - 5/26/2009 8:34 PM
shd3920
Score: 175
Status: offline
Did a little bit today, waiting to hear from wzak29 to know how far he is. Here is where I'm at.
Photo 1: Reinforced the rear of the F1 assembly with tristock
Photo 2 & 3: Pushrod tubes installed
Photo 4 & 5: Test fitting the wing (bottom view)
Photo 6 & 7: Test fitting the wing (top view)
Photo 8: Firewall, formers F3B, F4B, F5B and F6B epoxied on
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 143
RE: G.P Super Sportster 40 dual build - 5/26/2009 8:35 PM
wzak29
Score: 113
Status: offline
1 pushrod tub with balsa filler
2 after sanding
3 added block to reinforce firewall
4 formers
5 installed firewall
6 cockpit deck
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 144
RE: G.P Super Sportster 40 dual build - 5/26/2009 8:42 PM
bruce88123
Score: 100
Status: offline
quote:
ORIGINAL: shd3920
Why epoxy for all of these formers? Extra un-needed weight.
3-D is for Monster Movies
Hide Signatures
       Post #: 145
RE: G.P Super Sportster 40 dual build - 5/26/2009 9:03 PM
wzak29
Score: 113
Status: offline
need some help with F7 (7C ? 7B?)how do you draw the lines and where do you mount it?
< Message edited by wzak29 -- 5/26/2009 9:13 PM >
Hide Signatures
(in reply to bruce88123)
       Post #: 146
RE: G.P Super Sportster 40 dual build - 5/26/2009 10:06 PM
shd3920
Score: 175
Status: offline
quote:
ORIGINAL: bruce88123
Assumed, perhaps wrongly, that the turtledeck was considered a high-stress area. Especially when it's not sheeted.
Hide Signatures
       Post #: 147
RE: G.P Super Sportster 40 dual build - 5/26/2009 10:19 PM
shd3920
Score: 175
Status: offline
quote:
ORIGINAL: wzak29
Photo 1: At top of plans, use this sketch to draw the stringer lines
Photo 2: Glue 7B to the front of 7C. Glue former 7 assembly to rear top of fuselage just forward of where the stab sits. Right above the lower former 7. Make sure the smaller 7B is facing forward.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 148
RE: G.P Super Sportster 40 dual build - 5/26/2009 10:20 PM
bruce88123
Score: 100
Status: offline
quote:
ORIGINAL: shd3920
Refresh my memory. Are there going to be stringer strips running between the "B" formers ? If so there should be plenty of strength. They appear to be notched for stringers.
Hide Signatures
       Post #: 149
RE: G.P Super Sportster 40 dual build - 5/26/2009 10:22 PM
shd3920
Score: 175
Status: offline
Photo 1, 2: Cockpit deck
Photo 3: Top turtledeck stringer
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.328RCU1
