RE: Sterling Stearmin, PT-17, lazer reproduction    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sterling Stearmin, PT-17, lazer reproduction Page: <<   < prev  3 4 5 6 7 8 9 10 11 [12]
Login
RE: Sterling Stearmin, PT-17, lazer reproduction - 2/26/2012 5:17 PM
rcten
Score: 100
Last Login: 5/17/2013
Status: offline
NM, Good luck on your move, hope all is well. Let us know when your back online.
Rcten
Hide Signatures
(in reply to Nintendomaniac_00)
       Post #: 276
RE: Sterling Stearmin, PT-17, lazer reproduction - 2/26/2012 11:09 PM
thailazer
Score: 110
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: rcten
Hi NM, The yellow is ultracote cub yellow, and the gray is aluminum flashing from Home Depot, it's attached using contact cement, better be where you want it the first time, there's no second chance. Speaking of, I presume you have flown your PT-17,,, well? A few more picts.
rcten... Project sure looks good. What brand and type of contact cement are you using? Never thought of using flashing on models and want to try this in the future.
_____________________________
Tiger Flyer #49
Hide Signatures
(in reply to rcten)
       Post #: 277
RE: Sterling Stearmin, PT-17, lazer reproduction - 2/27/2012 12:39 PM
rcten
Score: 100
Status: offline
Hi Thailazer, I used DAP, Weldwood brand brush on Contact Cement. The aluminum flashing is .010 in. thick and easy to form since it not as stiff as lithoplate and of course more easily obtained. I also painted each piece before attaching.
Hide Signatures
(in reply to thailazer)
       Post #: 278
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 3:15 PM
u2builder
Score: 105
Last Login: 1/26/2013
Status: offline
I just purchased a Sterling PT-17 kit on Ebay. Well, half a kit is what I got, as it only really had the wing parts. Someone had built the fuselage. And the tailfeathers. I am trying to get a partial refund from the seller. I think I have located another half kit that contains the fuselage. If not, I guess I could purchase the lazer cut fuselage parts.
Anyway, this build thread has been great, but it seems to have stopped. Have any of these been completed and flown yet?
I am curious what the final weight is? And whether the supplied landing gear is "sufficient". I don't really want to spend money on the Robart system if it is. But I would like to know.
I am curious how the build with the Saito 100 wound up balancing, and if the Saito 100 is a good choice, and if it was integrated with the plastic dummy engine that comes with the kit.
I am used to building a kit in a few weeks. It looks like this one may take a little longer!!!!
Hide Signatures
(in reply to rcten)
       Post #: 279
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 6:21 PM
rcten
Score: 100
Status: offline
Hi, u2builder, good luck on finding fuselage, the lazer short kit would be better. The plans have no templates as I'm sure your awear. Haven't finished mind yet, just plane ran out of ambition, but will get back to it because I refuse to start another until it's finished. I figure it'll weight around 10 lbs. The landing original landing gear will bent easily if landing is alittle hard, as per other people who have flown this model. The Robart does make for a more scale look, plus it handles the not so perfect landings better. A 90 or 100 would be agood choice and should balance OK.
Hide Signatures
(in reply to u2builder)
       Post #: 280
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 6:36 PM
u2builder
Score: 105
Status: offline
Someone is sending me a scratch and dent kit gratis. Nice fellow. I'll see if it is usable. If not I can order some lazer parts. But I need to keep expenses down where I can. I am retired and have "more time than money".
Can the wire gear be removed and replaced if it is bent? I haven't really studied the plans yet. If not, I'll have to give some thought to the Robart gear. But I'll do the wings first since I have them.
Yours was looking super nice. And that engine is to die for. It would be nice to see it finished. Thanks for the reply, and have a great HOliday.
Hide Signatures
(in reply to rcten)
       Post #: 281
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 6:53 PM
rcten
Score: 100
Status: offline
U2builder, if you go to post 219 you'll see how the gear, be it Robart or Sterling is bolted in on F2 and then covered with the 1/8x5/16 or thereabouts balsa strips, which precludes any access once fuselage is finished. You could stiffen the gear by using a heavier gauge wire. I believe the wire gear uses 1/8 music wire.
Hide Signatures
       Post #: 282
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 6:59 PM
Sharpeye22
Score: 120
Status: offline
 I often find the wire supplied with kits, (Including these old ones) is a bit soft.  I will often use them as a pattern and bend my on from stiffer wire. I sometimes go up a size to get the added strength.  What this does not do is give the cushion that the oily struts will give on a hard landing.  The shock can well be transmitted into the airframe instead of being obsorbed by the springs of the struts.
Just food for thought.
Larry
Saito Club #692
Hide Signatures
       Post #: 283
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 7:39 PM
u2builder
Score: 105
Status: offline
Given the way the wire gear (3/16") is buried, I am going to have to seriously consider the Robart gear. The way that the Robart gear is attached also seems more secure and spreads the loads. Thanks for the comments.
Hide Signatures
(in reply to Sharpeye22)
       Post #: 284
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 7:46 PM
u2builder
Score: 105
Status: offline
That picture is very good, and looks like a good mounting system. Could you tell me what wheels you used? Thanks. Joe
Hide Signatures
(in reply to rcten)
       Post #: 285
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 9:14 PM
rcten
Score: 100
Status: offline
Robart 4" diamond tread, they look more scale, Sterling calls for 4.5", which are fine but they look to big and the tire contour is wrong...picky..picky.
Hide Signatures
       Post #: 286
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/4/2012 9:49 PM
xxwolfyxx
Score: 100
Last Login: 5/9/2013
Status: offline
I would definitely go for the Robarts. I am almost to that point  now.
When i was growing up my dad had the stearman and I can remember the stock gear being very weak.
Hide Signatures
(in reply to rcten)
       Post #: 287
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/5/2012 3:13 PM
LesUyeda
Score: 151
Status: offline
"If not, I'll have to give some thought to the Robart gear. But I'll do the wings first since I have them. "
Be aware, that even with the Robart gear, you will have to tear out the belly, and reconstruct things in that area to accomodate; but you will not be sorry you did so. The Robart look and work great.
Les
Hide Signatures
(in reply to xxwolfyxx)
       Post #: 288
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/5/2012 4:45 PM
rcten
Score: 100
Status: offline
Tear out the bottom for gear, not really unless you've already installed wire gear and closed it in. I Took F2A and glued it to the front of F2, this provided more thickness for bolts, you just need to leave out the bottom front fuse. stringers until the Robart gear is installed. The gear comes with drawings to make up the 1/4 ply mounting plates. The final setup is quite rigid. Post 220 should give you an ideal.
Hide Signatures
(in reply to LesUyeda)
       Post #: 289
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/6/2012 3:12 PM
LesUyeda
Score: 151
Status: offline
"Tear out the bottom for gear, not really"
Oh!!!!! How does that work????
"Someone had built the fuselage"
Les
Hide Signatures
(in reply to rcten)
       Post #: 290
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/6/2012 3:33 PM
u2builder
Score: 105
Status: offline
I haven't built my fuselage and am still awaiting a partial kit that I hope contains it; otherwise I'll order the laser cut version. My concern was that if I put in the wire gear and bent it THEN I would have to tear the plane apart, and by all accounts the Robart gear, while also buried, is stronger. Plus, it probably puts less stress on the fuselage, and the mounting, shown by a builder who used it, seems better and stronger and seems to spread loads better. So, I guess I need to fork out the dough and get the Robart system.
Hide Signatures
       Post #: 291
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/12/2012 2:35 PM
u2builder
Score: 105
Status: offline
Hi Folks,
I received my die crushed second kit that contains the fuselage and tail feather parts. It was obviously one of the last kits produced, and die crushed only begins to describe it. They also seeming ran of of ink, so not of the parts were marked. But it was kindly donated to me by another builder, so I am grateful to have it, though I can sure see the advantages of the laser cut version! Anyway, with patience I have been able to identify and cut out the die crushed parts and the fuselage is coming together nicely. I finished the wings, the parts for which came from the much older and better die cut balsa.
Anyway, I have been building away. I ordered the Robart gear but don't have it yet. Anyone know how long it takes Robart to produce and send the gear?
Should I mount the doubled up F2a gear bulkhead to the front side of f2, or wait till I see the Robart instructions?
Also, can someone describe what the fitting looks like that mounts the cabane wires? I am not sure what to use. Thanks!!!!
Hide Signatures
       Post #: 292
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/12/2012 3:19 PM
LesUyeda
Score: 151
Status: offline
"It was obviously one of the last kits produced, and die crushed only begins to describe it."
In the last days of availability of any of original Sterling, any thing you got looked like floor sweepings. I bought a "'60 Chris craft" kit, and that was what the wood in it looked like.
Les
Hide Signatures
       Post #: 293
RE: Sterling Stearmin, PT-17, lazer reproduction - 7/12/2012 3:30 PM
u2builder
Score: 105
Status: offline
Hi Folks,
Should I mount the doubled up F2a gear bulkhead to the front side of F2, or wait till I see the Robart instructions?
Also, can someone describe what the fitting looks like that mounts the cabane wires? Is it the little aluminum "clamp"? I am not sure what to use.
Also, there are a couple of half round metal rods about 3 or 4 inches long and 1/8" diameter. Where do they go?
Finally did you use the stock tailwheel set up or replace it with aftermarket and if so what?
Thanks!!!!
Hide Signatures
       Post #: 294
RE: Sterling Stearmin, PT-17, lazer reproduction - 10/26/2012 2:50 PM
Nintendomaniac_00
Score: 100
Last Login: 5/6/2013
Status: offline
All
Hey I'm back! Have completed the move to Newberg and am settling in to the new job etc, etc. Working on a new shop area so I can pick back up on the building. U2Builder, I saw your last post and offer this info; Post #84 has some detail on the j-bolt design to secure the cabanes inside the fuselage. Note the ply reinforcements, etc. Also on the short round stock, could they be the hoops for the top of the cabanes? See post 204 and 209/210. Hard to be sure w/o a picture of what you have. Regards, NM
Hide Signatures
       Post #: 295
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
