Extra airfoil thickness
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> Extra airfoil thickness
Page: [1]
Login
Extra airfoil thickness - 5/16/2009 3:19 AM
jim52519
Score: 100
Last Login: 11/6/2009
Status: offline
Hi All,I am planning on building the Project Extra designed by Mike Hurley, published in MA about 5 years ago. It has a span of 106" and is powered by a 100 cc twin. I am wondering about the wing airfoils. It has a 14% wing root and a 12% wing tip airfoil. It seems to me that this would encourage tip stalling. I would think the tip should be thicker than the root. What do you guys think?Jim
Hide Signatures
       Post #: 1
RE: Extra airfoil thickness - 5/16/2009 3:37 AM
dick Hanson
Score: 100
Last Login: 11/8/2009
Status: offline
The airfoil thicknes is fine for this application - run em even thinner  with lighter wing loadinds  have done so for many years
_____________________________
I am watching you
Libby
Hide Signatures
(in reply to jim52519)
       Post #: 2
RE: Extra airfoil thickness - 5/16/2009 6:29 AM
wellss
Score: 100
Status: offline
The optimum thickness for models is 12%.  Thicker airfoils don't show improvement until high Reynolds number ( full size ).  Looks like Mike Hurley knows what he's doing.
Hide Signatures
(in reply to dick Hanson)
       Post #: 3
RE: Extra airfoil thickness - 5/16/2009 9:14 PM
Danny Baker
Score: 100
Last Login: 11/7/2009
Status: offline
The thinner airfoils on the tip are done by design.  These help the plane to start and stop rolls and snaps more crisply.  Other models (extras, edges, yaks, etc.) have the same.
Hide Signatures
(in reply to wellss)
       Post #: 4
RE: Extra airfoil thickness - 5/22/2009 12:18 AM
P-40 DRIVER
Score: 100
Last Login: 11/1/2009
Status: offline
A 12% symetrical airfoil is the thinnest you can run without a loss of angle of attack/lift. There is really no advantage to going thicker for aerodynamics sake; but for structural reasons, it can allow for a stronger wing with no weight penalty. In an Extra, you want to be able to stall the wing quickly and completely, so thats part of what your buying. This is assuming we are talking about NACA 4 digit airfoils.
RC budget, $10 per week, time spent building and flying, priceless.
Hide Signatures
(in reply to Danny Baker)
       Post #: 5
RE: Extra airfoil thickness - 5/22/2009 1:44 PM
dick Hanson
Score: 100
Status: offline
We used  thinner foilsyears back at  1990's TOC - worked fine -on the bipes  some foils were  9%
 If weight is  low enough the foil can be  flat  dead flat
 no problemexcept structural.
 In real world of  1000sq in n up stuff   sticking close to 12% allows for  a strong shape  woith good  stall /recovery  character.
I am watching you
Libby
Hide Signatures
(in reply to P-40 DRIVER)
       Post #: 6
RE: Extra airfoil thickness - 5/22/2009 4:41 PM
CrateCruncher
Score: 100
Status: offline
quote:
ORIGINAL: wellss
Wow, thats a pretty broad statement.  Are you refering to all R/C?  I fly a pattern plane with 18% and its one of the most popular wings ever designed for R/C.  The same wing is found on the Kwik-Fly, Kaos, and UltraSport's.
"Never be seen with an ugly airplane."
Hide Signatures
       Post #: 7
RE: Extra airfoil thickness - 5/22/2009 8:09 PM
dick Hanson
Score: 100
Status: offline
quote:
ORIGINAL: CrateCruncher
quote:
ORIGINAL: wellss
18% was common years back  but present competition stuff is  more in the  12-9% range.
 My super light  larger  electric stuff  (like the  ERATIX is  a thick wing - mainly for  structural reasons
 it is far  easier to make  a light wing if yo make it  thicker.
I am watching you
Libby
Hide Signatures
(in reply to CrateCruncher)
       Post #: 8
RE: Extra airfoil thickness - 6/14/2009 4:53 PM
NJRCFLYER2
Score: 100
Status: offline
That design was meant primarily for 3D and did pretty well at it.  It actually resists snapping to the point that it is a bit of a liability in sequence flying.
Ed Alt
Tech-Aero Designs
Hide Signatures
       Post #: 9
RE: Extra airfoil thickness - 6/15/2009 5:08 AM
BMatthews
Score: 100
Status: offline
When you're looking at a plan for an aerobatic model that has a proven track record you're wise to accept the design as it comes.  As Dick has pointed out the details inherent in the design were not put into the plan on a whim.  Rather they are products of evolution from a series of models that led to what you see in front of you.  If the wing is set up with an airfoil transition that seems to favour tip stalling it was almost 99.999% sure to have been done because it was found to be needed to fly the model the way it is made to fly for the events it has to fly in.
It's like the stabilizer anhedral in one of the mid 70's pattern ships.  Everyone thought it looked uberkewl but when you read the details in the article about the design evolution it was done because the original stabilizer was too high and it didn't knife edge or something the way the designer intended.  So it was cut up the fuselage to move the stabilizer or somehow lower the stabilizer.  Since that model had a fiberglass fuselage cutting the fuselage would have been messy at best.  So he did the easy thing and put anhedral in the stabilizer.  It worked, he won a few big contests and others followed and put anhedral in their stabilizers wether it was needed or not because it was thought that the anhedral had magical powers.....
Now if this was for a scale model plan where only one was ever built and the designer basically said it was an evil demon to fly then you'd be right to be asking about fixes.  But on models that come with a proven flight performance you shouldn't bother trying to second guess until you fly the model.  If it doesn't suit you then it becomes more a case of you needing to adapt to the model and learn to fly it within the bounds it presents so that it can do the things it is intended to do.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to NJRCFLYER2)
       Post #: 10
RE: Extra airfoil thickness - 6/15/2009 5:30 AM
NJRCFLYER2
Score: 100
Status: offline
quote:
ORIGINAL: BMatthews
I'm not the one interested in building this model, but I am saying to the guy who wants to build it that he doesn't need to worry about the tip stall stuff.  The design, as-is, is difficult to stall.  As a result, it doesn't snap particularly well, but does the 3D stuff about as well as anyone might expect.  That's primarily what Mike designed it to do, and ofcourse wanted it to do sequence work well, but as with all compromises it does not excel in all areas.
< Message edited by NJRCFLYER2 -- 6/15/2009 5:32 AM >
Ed Alt
Tech-Aero Designs
Hide Signatures
(in reply to BMatthews)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.799RCU1
