Vortexgen
Joined: 3/12/2003 From: Fortitude Valley, AUSTRALIA Status: offline
You can set up the rotor head two ways on the caliber 30. 1. FRS (front link-grip system) 2. RRS (rear link-grip system) - This offers a choice of the mechanical mixing of the rotor head to provide either positive delta mixing (FRS) or negative delta mixing (RRS) - The delta mixing will either decrease (RRS/negative) or increase (FRS/positive) the effect of the blade flapping motions. - blades move on 3 planes, pitch, lead/lag, and flap. - pitch is angular changes from the collective inputs. - Lead/lag is the blade pivoting fore and aft from the main bolts (these bolts should never be that tight that the blades cannot lead/lag) - Flapping is where the blades rise and fall, or seesaw. -As the blade flaps up (due to increased lift on the advancing blade in a gust, or roll, or other acrobatic manuever, and termed "dissymmetry of lift" the RRS will oppose (by mechanical mixing) the flap up condition and retain helicopter stability. - this is great for hovering, but not for acrobatics. -On the other hand, the RRS, will add to the blade flap condition, and may require opposite cyclic to keep the helicopter stable. - RRS is apparently better for beginners as it makes the helicopter about 70% more stable than when set up as FRS. - The ARF version these days comes setup as FRS. - FRS is still very stable for beginners and you will find that the vast majority of caliber guys keep the factory setup of FRS, regardless of their skill level. - Stability is rarely a problem in a well built caliber, normally pilot inputs make them fly a bit erratic, which can be reduced for beginners by setting dual rates on the cyclic to 70%. - The physical difference between FRS and RRS is that the pitch links are attached to the bladegrips leading edges in FRS, and trailing edges if setup as RRS, and the second position on the mixing arms is used. - Controlled flight is very possible in either system, its simply a question of a little more stability vs agility. - I believe that the caliber rotor head is designed to have zero delta, but in any dissymmetry of lift condition, as the blades flap, it will either be reduced or increased. this is the option that RRS and FRS gives caliber owners. - Other helicopters call it a Head Flip mod. So..., im not sure what you mean by "BALL to the other position", but you are correct in that to swap between FRS and RRS, you have to rotate the bladegrips 180 degrees. In regard to the 0mm gap between the two rod ends that form the pitch link, I think its better to set the pitch links so that when the collective stick is in the half/50%/hover position, the main rotor blade angles are approximately +6 degrees. maybe with RRS it is close to 0mm. These will need to be changed again at the flying field to track the blades correclty (if required). the gaps in mine are about 4-5mm. (using RRS) Your getting deep into it now!!!! I kept it basic for non-engineering types. still workning on the gyro setup....
< Message edited by Vortexgen -- Jun 25 2003 5:27AM >
