DX5e settings reset
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> DX5e settings reset Page: [1]
Login
DX5e settings reset - 5/19/2009 7:58 PM
Switch_639
Score: 289
Last Login: 11/6/2009
Status: offline
how do I reset all settings on the remote? is there like a reset button or what can I do?
Hide Signatures
       Post #: 1
RE: DX5e settings reset - 5/20/2009 1:11 AM
richg99
Score: 100
Last Login: 11/7/2009
Status: offline
I don't believe that there are any settings to reset on the Dx5e.
 The servo reversals are all by slide switches; the hi-low  "rates" are fixed at 70-100.  There isn't any provision for "throw distance".   You have to re-bind with any additional receivers.  You can use the first receiver over and over again, as long as you remember to reset the servo reversal setups to the newer plane. What is left??  regards, Rich
_____________________________
richg99
Hide Signatures
(in reply to Switch_639)
       Post #: 2
RE: DX5e settings reset - 5/20/2009 1:13 AM
richg99
Score: 100
Status: offline
Oh, if by "remote" you mean the receiver...then there aren't any switches on it.  Rich
richg99
Hide Signatures
(in reply to richg99)
       Post #: 3
RE: DX5e settings reset - 5/20/2009 6:28 AM
Switch_639
Score: 289
Status: offline
the trims I want to know how to reset them to centre...
Hide Signatures
       Post #: 4
RE: DX5e settings reset - 5/20/2009 1:14 PM
richg99
Score: 100
Status: offline
I don't know...but...I'd just count the audible clicks and leave them at a half-point.  I think we only get ten up or ten down, but I am not sure of that number.   Rich
richg99
Hide Signatures
       Post #: 5
RE: DX5e settings reset - 5/31/2009 1:31 PM
-pkh-
Score: 102
Status: offline
The DX5e has a long audible beep for center trim, and for the left & right trim limits. If you try the rudder trim for example, if you press and hold it left (from center trim) you'll hear several beeps going higher in tone until it stops at a longer high tone beep. This is your far left trim limit. If you release the trim button and push it left again, you will hear no more beeps since you are at the left limit. Next push and hold the rudder trim right, and you'll hear several beeps going down in tone until it stops at longer beep. This is your center trim point. If you release the trim button and push it right again, you'll hear several beeps going lower in tone until it stops at a longer low tone beep. This is your far right trim limit. If you release the trim button and push it right again, you'll hear no more beeps since you are already at the right limit.
Once you try this a few times, the beep tone feedback makes it pretty easy to figure out when you're at center trim.
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 60, Tribute 36, Two PZ BL P51s, Two F27C Strykers
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
