wheels and tire help for yellow aircraft p-47
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli P-61 Black Widow - Kit
Seller:  topgun600
Details:   $575.00   |  11/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> wheels and tire help for yellow aircraft p-47
Page: [1]
Login
wheels and tire help for yellow aircraft p-47 - 6/19/2003 11:15:34 PM
p-47 razorback pilot
Status: offline
building a yellow aircraft p-47, what are folks using for tires and wheels? would like scale, ones offered from yellow are foam, i fly on and off a paved runway and they wont last........ also the instr book calls for 4 1/4 tires, web site says 5in... i called yellow, he said there 4 5/8!!!!! what works? thanks guys
       Post #: 1
wheels and tire help for yellow aircraft p-47 - 6/19/2003 11:39:21 PM
Tempest-RCU
Status: offline
I am trying to find the same thing out myself. I know Aerotech offers a set of wheels at $145 for the pair. I do not recall the size.
I have also sent an inquiry to Darrell Tinney at Sierra Precision to see if he offers a set.
Lastly, you could always go with Glennis.
Here's their respective URL's:
http://www.aerotechmodels.com/p47kit.htm
http://www.sierraprecision.com/prod08.html
http://www.glennis.com/usawarbirdgallery.htm
I have a set of Williams Brothers wheels at home from a Yellow P-47 I picked up earlier this year. If no one has given you the dimensions by the time I get home, I'll measure the tires and let you know the diameter.
Paul
(in reply to p-47 razorback pilot)
       Post #: 2
wheels and tire help for yellow aircraft p-47 - 6/19/2003 11:43:25 PM
Status: offline
thanks, glennis is working on it but dont make ones now, still looking
       Post #: 3
wheels and tire help for yellow aircraft p-47 - 6/20/2003 3:02:54 AM
tim thompson
Status: offline
used a set of dubro 4.5 in. Had to sand both sides of wheels thin to fit in wheel well which is fully enclosed with doors. Sierra makes a baeutiful set with scale hubs but very expensive. Robart makes a set of scale 5" lot less $$. Mine is 1:5 scale
       Post #: 4
wheels and tire help for yellow aircraft p-47 - 6/20/2003 3:05:51 AM
tim thompson
Status: offline
would the aerotech acc. fit the tf giant p-47?? How close in scale are the two???
       Post #: 5
wheels and tire help for yellow aircraft p-47 - 6/20/2003 5:16:48 AM
Status: offline
whats sierras website?
       Post #: 6
Yellow wheels. - 6/20/2003 7:29:28 AM
BobH
Status: offline
P-47 I sent you an email.. My yellow tires are 4 5/8. you could use 4.5 from dubro or sullivan.. I would not go larger than 4.75. you may run into problems going into the wheel well.. Robart makes aluminum hubs that are reasonable... check the for sizes...... Regards BobH.
_____________________________
BobH.
       Post #: 7
wheels and tire help for yellow aircraft p-47 - 6/20/2003 9:22:03 AM
Tempest-RCU
Status: offline
[QUOTE]whats sierras website?[/QUOTE]
I posted it above, but here it is again [url]www.sierraprecision.com/[/url]
Thanks!
Paul
       Post #: 8
wheels and tire help for yellow aircraft p-47 - 6/20/2003 6:33:25 PM
Flypaper 2
Status: offline
I use Sullivan Liteflite 5 in.
Gord
Dreamed I was a muffler. Woke up exhausted.
       Post #: 9
Yellow P-47 wheels - 6/20/2003 6:52:26 PM
GlennisAircraft
Status: offline
Glennis does make wheels for the Yellow P-47 and has since the introduction of the kit.
We do not manufacture 4 1/4" diameter (which is what the inquiry was about), but the 4 1/2" and 5" (which is the size it originally used) are standard items.
Dennis
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU3
