OMP 80 inch Edge Gas Engine Question
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> OMP 80 inch Edge Gas Engine Question
Page: [1]
Login
OMP 80 inch Edge Gas Engine Question - 5/24/2009 1:34 PM
edavis
Score: 100
Last Login: 5/25/2009
Status: offline
I have a couple of questions regarding which gas engines to use with the OMP 80 inch Edge ARF.  My first question is will the airplane still 3D well with the extra weight of a gas engine?  Also, the OMP site recommends using beam mounted engines in the range of 30cc to 40 cc along with suggesting an RC Showcase 180 engine as a good engine. I went to the RC Showcase web site and did not see the engine listed. In general, most gas engines are going to four post mounts. Can you use a 4 post mount engine and what mods to you have to do? Also, are there any other mods you have to do to this plane when switching to gas engines other than the fuel lines in the tank?  Are there any other good recommended gas engines for this plane either beam or four post mounted?
Hide Signatures
       Post #: 1
RE: OMP 80 inch Edge Gas Engine Question - 5/24/2009 2:06 PM
ThumbSkull
Score: 103
Last Login: 3/21/2010
Status: offline
OS 160FX with a macs one piece muffler or header and BudLight can is a good setup. Gassers with beam mounts that also have a good HP/weight ratio are rare indeed.
Hide Signatures
(in reply to edavis)
       Post #: 2
RE: OMP 80 inch Edge Gas Engine Question - 5/24/2009 4:06 PM
Walt and Sage
Score: 100
Status: offline
I have a 40cc 80 inch profile that was built by Bill Hemple ( so I have been told)
Has a MVVS 40cc gas motor with a canister muffler...
EVERTHING HEAVY DUTY, 8 servos, on the heavy side at 18 lbs...
Found that I could get 20 to21 lbs of thrust with a Xoar 21x8
Will hover with a slow pullout...
Lightned by 6 oz by installing ONE A123 battery for everthing...
MVVS was purchased by Eveloution , I think
Walt...
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
A Man''s Character is his Destiny.........
........AMA 38255 "PRO BRO 2344"
Hide Signatures
(in reply to ThumbSkull)
       Post #: 3
RE: OMP 80 inch Edge Gas Engine Question - 5/26/2009 12:13 AM
AFSalmon
Score: 100
Last Login: 3/20/2010
Status: offline
That's definately an OMP 80" Edge.  Looks to be a kit built version for sure.  Don't know of an MVVS 40cc gas.  The MVVS 2.15 which is equavalent to 35cc was very popular on the 80" Edge and reported to be a powerhouse.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to Walt and Sage)
       Post #: 4
RE: OMP 80 inch Edge Gas Engine Question - 5/26/2009 4:28 PM
Walt and Sage
Score: 100
Status: offline
Hi Mike,
Below is a link to the MVVS site...
http://mvvs.nl/
When you get there ,  click on the PETROL ENGINS link...
Nice to know it is an OMP kit,,,
Walt
Hide Signatures
(in reply to AFSalmon)
       Post #: 5
RE: OMP 80 inch Edge Gas Engine Question - 5/26/2009 4:35 PM
outssider
Score: 100
Status: offline
18 lbs...???  holly crap !!!...what did he use for glue... portland cement ??
Hide Signatures
       Post #: 6
RE: OMP 80 inch Edge Gas Engine Question - 5/26/2009 4:53 PM
Walt and Sage
Score: 100
Status: offline
YES, I think you are right: Portland Cement instead of foam: Makes it heavy duty...
The old TeatherRite gears just flex and holds it fine...
Not a good 3der but flys very nice... attracts alot of attention...
needless to say
quote:
ORIGINAL: outssider
Hide Signatures
(in reply to outssider)
       Post #: 7
RE: OMP 80 inch Edge Gas Engine Question - 5/27/2009 3:10 AM
aviti
Score: 100
Last Login: 3/17/2010
Status: offline
Hardly seems possible.
quote:
ORIGINAL: Walt and Sage
needless to say
quote:
ORIGINAL: outssider
Hide Signatures
       Post #: 8
RE: OMP 80 inch Edge Gas Engine Question - 5/27/2009 5:19 PM
alpapilot
Score: 100
Last Login: 2/16/2010
Status: offline
It might just be me but, if you are going to be putting a three and a half pound engine on the front you might as well go with a DA50 or DL50.  They weigh about the same as an Evo 35.  And, power would be absolutely sick!
Hide Signatures
(in reply to aviti)
       Post #: 9
RE: OMP 80 inch Edge Gas Engine Question - 5/28/2009 3:06 PM
Walt and Sage
Score: 100
Status: offline
quote:
ORIGINAL: alpapilot
The plane is a profile so it requires a beam mouned motor...
I have a Burelli 46 that would work if the power issue starts to bug me....
Hide Signatures
(in reply to alpapilot)
       Post #: 10
RE: OMP 80 inch Edge Gas Engine Question - 6/1/2009 2:07 PM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: alpapilot
That's been done several times and requires modifying the nose and engine mount.  It has been successful though!
I really like that MVVS 40!  Probably the same motor as the EVO 40GT Horizon is selling.  How could one get the MVVS 40 and how much would it be?  Looks like a perfect engine for the giant profiles.
Ohio Model Planes
Hide Signatures
       Post #: 11
RE: OMP 80 inch Edge Gas Engine Question - 6/1/2009 3:37 PM
Walt and Sage
Score: 100
Status: offline
Hi Mike,
I think EVO purchased MVVS and the 40 and 40MVVS are the same
Pe Reivers is the MVVS dealer I located in the Netherlands at:
http://mvvs.nl/
Hope the above link works for you...
Mine may be a 35cc, can not tell
IT IS THE SMOOTHEST RUNNING GAS ENGINE I HAVE EVER SEEN   NO VIBRATION
Walt...
Hide Signatures
       Post #: 12
RE: OMP 80 inch Edge Gas Engine Question - 6/2/2009 4:28 AM
alpapilot
Score: 100
Status: offline
quote:
ORIGINAL: AFSalmon
quote:
ORIGINAL: alpapilot
I'm actually itching to do an E-conversion on one.  The mounting hardware would be the same as if I was mounting a DA.  I'm also considering yanking out the DA in my Hybrid and doing an E-conversion on that as well since motors and batteries seem to be getting cheaper.
Hide Signatures
       Post #: 13
RE: OMP 80 inch Edge Gas Engine Question - 1/26/2010 1:57 AM
dquatse
Score: 100
Last Login: 2/9/2010
Status: offline
I have an evolution 35 gasser i want to put in this 80" edge . what did everybody do to mount the motor? (wont fit)
Hide Signatures
       Post #: 14
RE: OMP 80 inch Edge Gas Engine Question - 1/26/2010 1:02 PM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: dquatse
I have an evolution 35 gasser i want to put in this 80'' edge . what did everybody do to mount the motor? (wont fit)
I believe the Evo 35 is the same engine as the MVVS 2.15 gasser which was probably the most common gasser on the 80" slabs. Just widen the engine mounts enough to fit and mount it like a normal glow engine. The evo 35 has rails like a glow engine. Also the new 80" Edge ARFs have wider engine beams (3/4") so you do have some material to widen the mount some. Just keep the engine centered and remove wood symetrically on both beams.
< Message edited by AFSalmon -- 1/27/2010 2:03 PM >
Ohio Model Planes
Hide Signatures
(in reply to dquatse)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.336RCU1
