top flite p51 60..and more    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> top flite p51 60..and more
Page: [1]
Login
top flite p51 60..and more - 5/25/2009 10:00 AM
steelwarriior26
Score: 100
Last Login: 9/11/2009
Status: offline
Hello, with this being my first post let me start with saying thanks to you guys I have started anew after some 20 years of being away from the rc field. I am back with much to learn.I recieved a world models zero that needed abit of tlc..ok alot of tlc and some retracts and the whole rc thing kinda snowballed...now I need some input. I picked up a top flite P51 60 kit thinking it would be nice to finally build a  mustang.my questions are as follows. would the O.s. 91 max engine work well for this bird?second how do you feel about the durability of the included engine mount? third how  would you re inforce  the wings for the retract  mounts. and last what other modifications,or  improvements would you recomend for  this bird. thanks in advance   Tim
Hide Signatures
       Post #: 1
RE: top flite p51 60..and more - 5/25/2009 10:16 AM
DSTIEBS
Score: 100
Last Login: 2/14/2011
Status: offline
Sorry but can't help you with your questions but just wanted to say welcome back. I too came back after a 15 year absence. I read these forum questions and answers everyday and have learned a lot about the new electronics available now that were not around 15 years ago. The advancements that have been made is incredible. Read these forums to catch up on things. You will be glad you did. See ya around. Dave.
_____________________________
Dstiebs
AMA #922816
Hide Signatures
(in reply to steelwarriior26)
       Post #: 2
RE: top flite p51 60..and more - 5/25/2009 10:30 AM
steelwarriior26
Score: 100
Status: offline
Dave,  thanks for the kind words. I went with getting my pilots license and let the rc stuff go..the advancements really are great especially in the radios. I picked up a Jr xp8103 and am kinda overwhelmed at its everthing it can do.but for now I just want to get this P 51 ready. thanks again  Tim
Hide Signatures
(in reply to DSTIEBS)
       Post #: 3
RE: top flite p51 60..and more - 5/25/2009 4:15 PM
DavidAgar
Score: 146
Last Login: 5/21/2013
Status: offline
The 91 will be okay. The trick to the Top Flite kits is work work hard at keeping them light weight. They will get heavy fast. As for the retracts, just build them as per plans and add some triangle stock in key places to help hold the mounting rails. As for the engine mount, if it is the 2 piece Great Planes mount, it will be just fine. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
       Post #: 4
RE: top flite p51 60..and more - 5/25/2009 6:55 PM
redfox435cat
Score: 105
Last Login: 2/21/2010
Status: offline
I built this and the sea fury kit and both are just fine as built. the adjustable engiine mount it comes with is a none issue, I have at least 3 and never had a problem with them.
Try to build it light, all tf kits are heavy. The .91 will fly it ok. I'd go for the 1.08 but I don't think it's available anymore, I recommend a 4-stroke 1.2.  I've found all their war birds could use more power
The retract rails will hold up just fine. If your worried about it reinforce the ribs with triangle stock and light fiberglass and epoxy
Gravity wins everytime
Hide Signatures
       Post #: 5
RE: top flite p51 60..and more - 5/25/2009 9:08 PM
tail strike
Score: 110
Last Login: 4/21/2013
Status: offline
yy
< Message edited by tail strike -- 5/26/2009 6:45 AM >
I am watching you
Larry S
Hide Signatures
       Post #: 6
RE: top flite p51 60..and more - 5/26/2009 12:29 AM
planebuilder66
Score: 131
Last Login: 11/12/2012
Status: offline
I got a ST 75 in my TF p47, it flies just fine, it's a warbird, not an aerobat, so the 91 max will be just fine, the TF kits all build heavy but the airfoil in the wings and the built in washout keeps them very stable, so don't worry about it, all will be fine.
Hide Signatures
(in reply to tail strike)
       Post #: 7
RE: top flite p51 60..and more - 5/26/2009 4:05 AM
bigtim
Score: 132
Status: offline
79 pages of information on the TF Mustang http://www.rcuniverse.com/forum/m_2886581/tm.htm well worth reading.
the mount is fine I have a OS120 4stroke in my TF P-47 its plenty strong,I also have a OS91 in my TF Spitfire I am using the provided mounts in both planes,I bolted the engines in with through bolts with nuts instead of tapping the mount with threads just for security
 the 91 2stroke will pull the mustang around with authority,it flys fine with a 91-120 4stroke or 61-91 2stroke as recomended by TF, depending on weight.
like planebuilder66 said work on building it light, these TF planes build up weight fast easy on the glue and think about weight reduction, no need to go crazy with heavy details on a 60 size plane, it just makes it harder to fly.
Hide Signatures
(in reply to planebuilder66)
       Post #: 8
RE: top flite p51 60..and more - 5/26/2009 5:51 AM
steelwarriior26
Score: 100
Status: offline
thanks for the input guys! I feel alot better about the engine mount and retract mounts now. the fuse is comming along alot faster  then I expected. I will get the engine mount on it tonite and start on the upper cowl when I locate a spinner..and the retract parts hopefully I can get the from the classifieds.. isnt it kinda crazy how some of these things just  kind of fall together? first the kit then an engine and a decent radio??all on the same weekend?? my 8 y/old daughter says god just wants me to fly again just on a smaller  scale..   Tim
Hide Signatures
(in reply to bigtim)
       Post #: 9
RE: top flite p51 60..and more - 5/26/2009 8:11 AM
redfox435cat
Score: 105
Status: offline
after 20 yrs your gonna reacquaint<meta content="text/html; charset=utf-8" http-equiv="Content-Type"><meta content="Word.Document" name="ProgId"><meta content="Microsoft Word 9" name="Generator"><meta content="Microsoft Word 9" name="Originator">  yourself with flyin on some sorta low wing sport model first right? Did ya get that WM zero going? I had one and it was pretty stable
< Message edited by redfox435cat -- 5/27/2009 7:35 AM >
Hide Signatures
       Post #: 10
RE: top flite p51 60..and more - 5/26/2009 9:28 PM
FallDownGoBoom
Score: 100
Last Login: 4/6/2013
Status: offline
Steel:
I picked up a partially build TF P51 kit and am in the finishing process.  Two suggestions I'd make, but they may be too late if you've got most of the fuselage done:
1) Use a metal clevis on the elevator torgue rod/pushrod junction.  I lost a T34 when the pin on a plastic clevis/metal torque rod sheared off.
2) I'm not thrilled with the way the plans set up the rudder/tail wheel control system.  While I'm sure it works fine in practice (and it's too late to change mine), I think I'd install a two separate pushrods, one directy to the rudder, the other for the tail wheel.  You could still run these off a single servo.  This would give you a little more control over how much the tail wheel swivels when taxiing.
Fred
Fred
UltraSport Brotherhood #50
Hide Signatures
       Post #: 11
RE: top flite p51 60..and more - 5/27/2009 7:04 AM
steelwarriior26
Score: 100
Status: offline
Redfox, all the zero needs would be some struts for the gear. I dont care for the springs.. so I am in the process of finding a set for both the mustang and the zero. and I need to patch a small hole in the horizontal stabilizer, then after i get some trainer time in I will give it a shot.. Fred thanks for the input I dont care for the tail wheel setup either, I chose to beef it up some and decided to keep it simple . but the next mustang will be a "B" model .   Tim
Hide Signatures
(in reply to FallDownGoBoom)
       Post #: 12
RE: top flite p51 60..and more - 6/3/2009 7:18 AM
steelwarriior26
Score: 100
Status: offline
I will have pics posted soon, finnishing the tail this week. and fitting thje lower cowl etc when the spinner arrives. any suggestions on what fuel tank to use? thanks  Tim
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
