Spectra 2.4 Ghz Module compatible with Futaba Transmitters?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Spectra 2.4 Ghz Module compatible with Futaba Transmitters?
Page: [1]
Login
Spectra 2.4 Ghz Module compatible with Futaba Transmitt... - 5/28/2009 6:19 AM
lewdfinger
Score: 100
Last Login: 11/18/2009
Status: offline
Hi Mike. I have a Futaba 9z whose life I wouldn't mind extending for awhile with 2.4.  It looks like I will eventually be getting an Aurora 9 when they come out. Out of interest, would I be able to use the Spectra 2.4GHz module in the 9Z? The 9C? With the aporopriate Optima receiver, of course.
_____________________________
Do I know what rhetorical means?
Hide Signatures
       Post #: 1
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/4/2009 3:04 AM
submikester
Score: 105
Last Login: 3/18/2010
Status: offline
Any documentation on this? I'm interested as well.
Hide Signatures
(in reply to lewdfinger)
       Post #: 2
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/4/2009 3:37 AM
MikeMayberry
Score: 100
Status: online
We've tested it and other are using it in the 9C. I don't have a 9Z to test it with but if they use a similar module then it should work.
Note: In the past many people used the Hitec Spectra synthesized module in Futaba radios, and while it worked, the combo was not FCC type accepted so technically it was illegal. Hitec Spectra 2.4 system is self contained and does not use any of the radios RF section so it is legal to use in any radio that it fits.
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
Hide Signatures
(in reply to submikester)
       Post #: 3
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/4/2009 7:00 PM
submikester
Score: 105
Status: offline
Okay, so it does work with the 9C then (That's what I have).
Where can I find the technical information on this (like the manual?).
I looked on the Hitec site but was unable to find any specific Futaba compatibility information. My understanding is that things are supposed to be available sometime this month?
Hide Signatures
(in reply to MikeMayberry)
       Post #: 4
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/4/2009 10:23 PM
lewdfinger
Score: 100
Status: offline
quote:
ORIGINAL: submikester
Ya me too
Hide Signatures
       Post #: 5
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/6/2009 11:14 AM
A.T.
Score: 100
Status: offline
quote:
ORIGINAL: submikester    Okay, so it does work with the 9C then (That's what I have). Where can I find the technical information on this (like the manual?).  I looked on the Hitec site but was unable to find any specific Futaba compatibility information. My understanding is that things are supposed to be available sometime this month?
Hitec RCD Optima 6, 7 & 9ch Receiver ManualHitec RCD 2.4GHz Spectra Module Manual
No specific instructions relating to any one type of transmitter as the two listed Manuals cover various instalations and uses. Web search will evidence posts already submitted on various forums by several satisfied Futaba owners describing their various transmitters and results with the Hitec 2.4GHz Spectra installed.
The most comprehensive thread on the Hitec 2.4GHz system includes a tip for those frequently interchange modules and wish to avoid time taken to interchange PPM & 2.4Ghz TX antenna:
Antenna Mount - suggested alternative. Full thread has sufficient information to answer almost any question.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Post Script: 20Nov09.
Spectra Pro Antenna Mast fitting
Spectra 2.4G is also compatible with other Module Type Transmitters that use the same Futaba/Hitec module shape/size/pin slots. e.g.:
5UAF, 5UAP
7UAF,7UAFS, 7UAP,7UAPS, 7UHF,7UHFS, 7UHP,7UHPS
8UAF, 8UAFS, 8UAP, 8UAPS, 8UHF,8UHFS,8UHP, 8UHPS
(8FGA, 8FGH as non-module radios can not be accomodated).
9CA, 9CH, 9CAPS, 9CAFS, 9CHPS, 9CHFS
10CH, 10CA
(10CAG or 10CHG as non-module radios can not be accomodated).
< Message edited by A.T. -- 11/19/2009 11:25 PM >
Hide Signatures
       Post #: 6
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 10/6/2009 2:42 PM
lewdfinger
Score: 100
Status: offline
Thanks for the links AT. Next time I'll remember to search all other RC forums before posting questions here. My bad.
Hide Signatures
(in reply to A.T.)
       Post #: 7
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 11/18/2009 12:48 AM
gplarry
Score: 100
Last Login: 11/20/2009
Status: offline
I have an Eclipse 7 that is only a few months old.
I bought it to replace an Eclipse 7 that is several years old.
I ran the older eclipse on a 3 cell lipo and did not have any trouble with it.
In fact it still operates fine.
I replaced it because it has been dropped several times and is held together with JB weld.
My question is whether the Eclipse 7 can be operated on 3s with the 2.4 GHZ module.
Larry
Hide Signatures
       Post #: 8
RE: Spectra 2.4 Ghz Module compatible with Futaba Trans... - 11/18/2009 3:15 AM
A.T.
Score: 100
Status: offline
quote:
ORIGINAL: gplarry   I have an Eclipse 7 that is only a few months old.   I bought it to replace an Eclipse 7 that is several years old.   I ran the older eclipse on a 3 cell lipo and did not have any trouble with it.  In fact it still operates fine.  I replaced it because it has been dropped several times and is held together with JB weld. My question is whether the Eclipse 7 can be operated on 3s with the 2.4 GHZ module.
Thanks,  Larry
AOK provided your Lipol pack has a voltage regulator built in so as not to exceed 12.0V.
Please refer to previous advices: Batteries_Lithium Polymer - Do Not Use Lipol in Transmitters
The Spectra Pro is designed to be used within two circuits, depending on pinouts, either the Aurora which is specifically designed to operate on 7.2v NiCad/NiMH or  2S Lipol, or the pinouts of earlier module based TX fitted with 9.6V NiCad/NiMH or 8 x AA Alkaline (12.0v), higher voltage voids warranty.
Hitec RCD Product Details 2009
Hitec RCD Spectra 2.4GHz Module Manual
Aurora A9, Eclipse 7, Flash 4&5, Optic 6, Prism 7 series Lipol, Field and Fast Charging.
Regards
Alan T.
< Message edited by A.T. -- 11/18/2009 9:54 AM >
Hide Signatures
(in reply to gplarry)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.517RCU1
