Need a little Ryobi help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Need a little Ryobi help
Page: [1]
Login
Need a little Ryobi help - 5/28/2009 6:15 PM
paparex2
Score: 100
Last Login: 3/8/2013
Status: offline
i've converted a Ryobi 31cc to go on my 80" SPAD but have a small problem. The engine will start and run great but after it runs for a few minutes the crank will move into the case about 1/8" causing the prop adapter to bind against the front of the engine. This is a long shaft and I have put the crank in a different case and it did the same I only have one long shaft crank so was not able to swap it.
Any ideas or suggestions.
Specs:
Long shaft Ryobi  excellant compression
Walbro 324 carb
CH EI prop adapter
RCexl ignition
JAG muffler
JAG mount
MAS 18x8 prop  getting 8000rpm when running
Rex
Hide Signatures
       Post #: 1
RE: Need a little Ryobi help - 5/28/2009 6:43 PM
w8ye
Score: 318
Last Login: 5/25/2013
Status: offline
The prop adapter must seat tight against the taper and/or the inner race of the front bearing without touching the case itself
< Message edited by w8ye -- 5/28/2009 6:46 PM >
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to paparex2)
       Post #: 2
RE: Need a little Ryobi help - 5/28/2009 7:00 PM
paparex2
Score: 100
Status: offline
I've checked the prop adapter several times and it is seated. I have machined the back of it to give it extra clearance. With the crank seated tight against the inner bearing the adapter has better than 1/8" clearance. After it runns for a few minutes there will be a 1/8 or better space between the crank and the inner bearing.
Rex
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Need a little Ryobi help - 5/28/2009 7:43 PM
av8tor1977
Score: 665
Last Login: 5/26/2013
Status: offline
Sounds like the crank fit in the bearing is a little loose.   This is a bit strange, as usually on Ryobis they are a bit too tight.
You will probably have to machine a groove in the crankshaft for a circlip to prevent the crank from "walking".  Be careful, because if it walks back far enough it is going to smack the reed valve stop and make a mess....
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 4
RE: Need a little Ryobi help - 5/29/2009 1:02 AM
trumpetman
Score: 100
Last Login: 5/17/2013
Status: offline
I'm confused.  It seems to me that if the hub is locked down on the inner race of the front bearing, then the hold bearing has to move aft.
This to me means that the outer surface of the front bearing is too loose in the block and it is shifting back, and the locked in crank with it.
NO ?
Hide Signatures
(in reply to av8tor1977)
       Post #: 5
RE: Need a little Ryobi help - 5/29/2009 4:02 AM
paparex2
Score: 100
Status: offline
The ryobi has a seal out front with a bearing behind it ( unless I have identified my engine wrong ) if it had a front sealed bearing you could bulid the prop hub to set against the inner race.  I'm going to pull the engine back apart and clean everything then put it back with a little loctite on the inner race and reassemble it. If that does not fix it I will cut a groove for a circlip and solve the problem.
The engine runs to well when it don't have a problem to junk it out.
I was able to get 8000rpm with a 18x8 MAS which I think is reasonable.  It should pull my 14lb SPAD around better than the wore out  weedeater engine I have on it now, it has little compression left but runs.
Thanks for the help any comments,ideas or observation are greatly appreciated
Rex
Hide Signatures
(in reply to trumpetman)
       Post #: 6
RE: Need a little Ryobi help - 5/29/2009 7:27 AM
Flathead
Score: 100
Last Login: 5/11/2013
Status: offline
I have one crankcase and crank assembly that seemed to do the same thing, especially whenI  used an electric starter, but at other times also. I used some rough emry on both the crank, and inside the bearings, and then on the housing for the bearing, then used indutrial strength sleeve seal (similiar to thread locker) and to date, the bearings and crank have stayed in place.  Worth a try. The sealer is available at most Auto parts stores.  Flathead
Hide Signatures
       Post #: 7
RE: Need a little Ryobi help - 5/29/2009 7:47 AM
paparex2
Score: 100
Status: offline
You could be on to something I have been using a electric starter.  Thanks for the tip on the sleeve seal
Rex
Hide Signatures
(in reply to Flathead)
       Post #: 8
RE: Need a little Ryobi help - 5/29/2009 8:08 AM
tkg
Score: 657
Status: offline
Use JB weld OR make a spacer that will fit between the inner bearing race and prop hub. That way the crank can't move back.
TKG
Too much power is just about right.
Hide Signatures
       Post #: 9
RE: Need a little Ryobi help - 5/29/2009 5:08 PM
combatpilot
Score: 100
Last Login: 6/14/2010
Status: offline
8000 rpm on a mas 18x 8  If this is a stock engine im sorry im not buying that.  What have you done to this engine? any mods?  be specific.
< Message edited by combatpilot -- 5/29/2009 5:09 PM >
Hide Signatures
(in reply to tkg)
       Post #: 10
RE: Need a little Ryobi help - 5/29/2009 5:50 PM
paparex2
Score: 100
Status: offline
I'll have to check the RPM's again but that is what I read. I've been playing with these toys for 30 years so my Globee tach has been around a while it could have personal problems....
Hide Signatures
(in reply to combatpilot)
       Post #: 11
RE: Need a little Ryobi help - 5/29/2009 6:53 PM
w8ye
Score: 318
Status: offline
My Ryobi has a stock "20" carb with opened muffler and it does the 18-8 at just above 7000
Original AMA #31261
Hide Signatures
       Post #: 12
RE: Need a little Ryobi help - 5/30/2009 4:21 AM
combatpilot
Score: 100
Status: offline
Give us some details on how this engine is built up.
What?  "20" carb ?
Hide Signatures
(in reply to w8ye)
       Post #: 13
RE: Need a little Ryobi help - 5/30/2009 10:17 AM
Iflyglow
Score: 122
Last Login: 5/24/2013
Status: offline
I picked up two 31 CC's at the City recycle center today.  They have a Walbro WA Carb with a "20" clearly stampted on the carb.  The Carb bore looks to small to me though.
I plan on messing with them this summer.
Hide Signatures
       Post #: 14
RE: Need a little Ryobi help - 5/30/2009 8:51 PM
av8tor1977
Score: 665
Status: offline
The numbers cast into the throat of the carb is the venturi size in 64's of an inch.
20 = 20/64" = .32125" = 7.9mm venturi.  A very small carb.  The weedies come with small carbs and often low port timings so that they can be run at full throttle and even if the string breaks they won't rev high enough to hurt themselves.
The Ryobi responds well to an 11mm venturi carb, which has a "28" casting number in the carb throat.  A "26" carb will work fairly well on a Ryobi too if you happen to have one of those.  I use 11mm.
AV8TOR
Hide Signatures
(in reply to Iflyglow)
       Post #: 15
RE: Need a little Ryobi help - 5/31/2009 12:02 AM
combatpilot
Score: 100
Status: offline
Now thats some good info to know.  i had no idea what he was talking about.  With that size carb the 7000 rpm sounds about right.  If you get a 12.7 mm carb i think you can expect at least 300 more rpm and that number is kind of conservative.
Hide Signatures
       Post #: 16
RE: Need a little Ryobi help - 5/31/2009 12:10 AM
av8tor1977
Score: 665
Status: offline
But only if he opens up the exhaust as well....  A bigger carb seldom helps much if the muffler is restrictive.
AV8TOR
Hide Signatures
       Post #: 17
RE: Need a little Ryobi help - 6/2/2009 10:23 PM
paparex2
Score: 100
Status: offline
So far it looks like I have it fixed. I cleaned all surfaces with contact cleaner and put the bearings and crank back in with locktite was able to run it for about 15 minutes with no problems. I'll find out for sure when I get back home I had to come to Shreveport to work for two weeks so I can get more money for toys and pay a few bills.
Rex
Hide Signatures
       Post #: 18
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Need a little Ryobi help
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
