os .10fp and wonder    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> os .10fp and wonder
Page: [1]
Login
os .10fp and wonder - 5/28/2009 9:53 PM
mickeymouse23
Score: 100
Last Login: 2/24/2013
Status: offline
I have a sig wonder new in box and was wondering about lighning it up to power it with the .10. Any sugestions? I have 4 hs-55's and a micro reciever to use. I usually build these for big engines, had one with a .25 and a .30, and do not have allot of experience with the little airplanes. Any help would be appreciated, Mike
_____________________________
Your suposed to type something clever here, I haven't figured it out yet. Pro Bro #5321
Hide Signatures
       Post #: 1
RE: os .10fp and wonder - 5/28/2009 9:59 PM
rainedave
Score: 100
Last Login: 4/24/2013
Status: offline
Trace all the parts onto contest balsa and put the Sig lumber on a shelf.
David
Hide Signatures
(in reply to mickeymouse23)
       Post #: 2
RE: os .10fp and wonder - 5/28/2009 10:56 PM
mickeymouse23
Score: 100
Status: offline
What weight would I need to get it to? And are my servoes enough?
Hide Signatures
(in reply to rainedave)
       Post #: 3
RE: os .10fp and wonder - 5/28/2009 11:59 PM
flying poodle
Score: 100
Last Login: 6/19/2013
Status: offline
I have powered my 10yr old wonder with a worn out 10fp, a conquest 15, a norvell 15,, and os 25, and a 40 fp.  The wonder was built bone stock with hs-81 servos.  The best flying version were 15 powered.  The added power of the larger engines did not seem to add very much speed, but made landing speeds much higher as well as making general flying not as fun.  I have seen other 10 powered wonders and they seem to fly much the same as my 15 powered one.  My 10fp is just a pos, but it would fly  the plane, although without any vertical power.
Hide Signatures
       Post #: 4
RE: os .10fp and wonder - 5/29/2009 12:36 AM
rainedave
Score: 100
Status: offline
I would go with HS-81's. I can see the 55's getting stripped. Just build it as light as you can. Remember, the idea is not to save an ounce in one place, the idea is to save a gram in 28 places.
After building a stock one with an LA .15 for flyinrog, I scaled the plans up 12% and built one for an LA .25. It's no bullet, but it will glide across the field. I have an Enya .25X with a pipe that I want to put in it, but I need to rotate the mount 45° to sling the pipe under the wing.
David
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to flying poodle)
       Post #: 5
RE: os .10fp and wonder - 5/29/2009 12:59 AM
RocketRob
Score: 100
Last Login: 6/15/2013
Status: offline
Thats pretty Dave!
The vintage covering you mentioned in the sureshark thread?
Space Available
Hide Signatures
       Post #: 6
RE: os .10fp and wonder - 5/29/2009 1:24 AM
nekked_man_2000
Score: 100
Last Login: 5/26/2013
Status: offline
Had one with a .10fp and full size radio gear.  It will fly, but you will want more power.  It will fly a loop from level, but if you try to stretch the loop it will start to fall out in the top.  Put an la .15 on it, was perfect for about 20 seconds until the radio battery died and it augered in the ground.  I think the .15 would have been perfect.  The plus to the .10 is how quiet it is though.
Austin
Hide Signatures
(in reply to RocketRob)
       Post #: 7
RE: os .10fp and wonder - 5/29/2009 1:38 AM
Andrew
Score: 105
Status: offline
David
What's your wonder covered with?  Looks really nice.
andrew
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 8
RE: os .10fp and wonder - 5/29/2009 9:42 AM
DeviousDave
Score: 110
Status: offline
When the Wonder came out, my Dad went full retard on them. He built .10 sized, 2 .15 sized ones, 2 .25 sized ones, and one .10 twin engine.  For sport flying, the .15's were the best IMO as the OS .10FP was marginal. The .25 sized ones were a real ball! Just plain bearing engines, but they went straight up and were very fast. He learned from these two that Wonders really need a rounded leading edge because he lost one or two after pitch stability in dives. With the .25's it was anytime they were flown at full power.
Hide Signatures
(in reply to Andrew)
       Post #: 9
RE: os .10fp and wonder - 5/29/2009 9:45 AM
rainedave
Score: 100
Status: offline
Thanks. It's transparent Worldtex (same thing as Solartex).
http://search.horizonhobby.com/index.jsp?N=0&Ntt=worldtex&sid=1218AE47D94E
The prices have really gone up over last year or so. It used to be $14 a roll.
David
Hide Signatures
(in reply to DeviousDave)
       Post #: 10
RE: os .10fp and wonder - 5/29/2009 11:15 AM
Boomerang1
Score: 120
Status: offline
Just keep it light, pick your wood carefully.  The 10 FP's are great little sport engines but no miracles for performance.
Mine is in a trainer I built for my daughter from a plan in a book.  The model is called a Pronto trainer & originally designed for a 35!
Built light with small radio gear it flys fine on the 10. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 11
RE: os .10fp and wonder - 5/29/2009 10:41 PM
mickeymouse23
Score: 100
Status: offline
Thanks guys for the info, I will definetly try this real soon,,,,,,,, I have had this 10 sitting around for quite some time. I won the kit a few years ago at sig and the engine was given to me at a fun fly last year. should be fun!
Hide Signatures
(in reply to Boomerang1)
       Post #: 12
RE: os .10fp and wonder - 5/30/2009 4:45 PM
RocketRob
Score: 100
Status: offline
Hey DD, not like we haven't ever been enthusiastic about a model before......
Space Available
Hide Signatures
       Post #: 13
RE: os .10fp and wonder - 5/30/2009 7:26 PM
longdan
Score: 103
Status: offline
Keep us updated on the progress.
I have an almost new FP .10. I've been looking for a home for it for ages. I'd be interested to see how your project goes.
Take plenty of pics
< Message edited by longdan -- 5/30/2009 7:29 PM >
Hide Signatures
       Post #: 14
RE: os .10fp and wonder - 5/31/2009 10:48 PM
Bipe Flyer
Score: 105
Last Login: 12/3/2012
Status: offline
quote:
ORIGINAL: rainedave
David
Cool, I went the other way and scaled down.  My normal sized one was powered by an OS .25 FP.  Small - Norvel AME .061. Mini - Cox .010.
Click for fullsize
Click for fullsize
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 15
RE: os .10fp and wonder - 6/2/2009 2:18 AM
mickeymouse23
Score: 100
Status: offline
Well here is what i have so far. Lighting of the ribs, starting weight is 1 oz ending 3/4 oz. I also built the fuse last night, Just did that per plans but used as little glue as possible. I am going to drill some holes in the stab and fins also.
Click for fullsize
Hide Signatures
(in reply to Bipe Flyer)
       Post #: 16
RE: os .10fp and wonder - 6/2/2009 2:49 AM
Bipe Flyer
Score: 105
Status: offline
I wouldn't go with the HS-55s either.  If you want sub micros, I'd go with HS-65HBs because of the Karbonite gears.  I hear Boba Fett uses them.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
