dick Hanson
Joined: 12/12/2001 From: slc, UT, USA Status: offline
Nice installation - I installed my ZDZ a little further aft -and basically did it the same way - except I used a 1/4" ply plate - copied from original firewall - then-- cut out most of original firewall and mounted the new plate, first with 1/2" wooden dowels - drilled for 6/32 bolts--which I attached thru the remaining firewall perimeter. The carb needles fall at leading edge of original firewall. Use light 1/8 ply to close in the new box. The stock servo locations are just fine. To best operate the carb --do this. Use a hobby power tool and a disc and carefully remove entire carb stop.-It is of no use anyway. A plastic servo arm, cut to aprox 3/4" long, is placed under the little jog on the metal carb arm--then a single small screw is used to attach the two. This mod, places the hook up point of the carb at a new center- which allows a perfect 50/50 fore/ aft movement of the pushrod. A plastic snap on clevis works fine now. The choke rod falls straight down, and is reached under the cowl -in the stock cutout. Mine flys beautifully- on a 20x10 prop-and will pull straight up on take off. flying is done at very reduced throttle - and I have run the model through most aerobatic routines - . Spins are exceptionally easy to initiate and stop -exactly where desired. Rolling circles are even nice - but you must use no rudder , as the rudder /aileron couple simply stops the roll-or speeds it wildly. Landings - easy - All in all a really nifty model - I did notuse any struts- tho they are cute - I just did not care to use em. I did round a hole on inner end of the slots in the struts, to allow the wing mounting bolts to stay in the wing - You simply drop the struts over the screws, then pull struts inward -into the slot. The plane is perfect for casual flying -or I am confidant it will do the Basic and Sportsman IMAC routines- quite nicely. Use a little aileron differential - or raise both ailerons a few turns - the rolls - even vertical- are quite axial.
