RE: Official DF-03 Ra Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: Official DF-03 Ra Thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Official DF-03 Ra Thread - 12/17/2009 3:31 AM
alexchen86
Score: 105
Last Login: 1/31/2013
Status: offline
Props aflipz!! Good luck with your build!
_____________________________
"...they call me tater salad."
Hide Signatures
(in reply to aflipz)
       Post #: 26
RE: Official DF-03 Ra Thread - 12/17/2009 3:58 AM
aflipz
Score: 100
Last Login: 3/4/2013
Status: offline
Thanks! Build is complete.
It's bone stock with a slipper, that's it... Got a ezrun 9T motor/esc on the way along with a set of Ti screws. I ran a 2s2P 2200mah Lifepo, some 20C 1500mah 2s lipos and... Yes, I defiantly ran a 11.1v 25C 2200mah lipo on the TEU-101BK with no problems to report.
Disclaimer; it's COLD here... Sure I wrap the chassis so it doesn't get all wet in there but it's well below freezing outside. Also; I made a resistor driven light set that is designed to run on 6V, and just as I connected the pack to my stock esc, two of my painstakingly installed LED's emitted a popping sound and failed (perhaps things would have been different had the esc been off at the time, not willing to find out)
Drove the heck out of that pack on snowy/icy surfaces, in cold weather and getting stuck frequently (meaning many short pauses) I have some data log graphs of the 2S and 3S lipos if you are curious to see I could export pics and upload them.
I treated the ESC with corrosion block and ran a couple of packs that way; esc fully covered in melting snow and running tap water directly onto it while operating so far has also not caused any issues. (yet..)
Planning on putting this in the rx and brushless esc as a second line of defense.
Hide Signatures
(in reply to alexchen86)
       Post #: 27
RE: Official DF-03 Ra Thread - 12/20/2009 8:51 PM
mvff1984
Score: 100
Last Login: 4/7/2011
Status: offline
sounds awesom aflipz.
 Im really interested in getting one of these but I love the suzuki sx4 body with for the tt01e. according to what Ive read you can shorten the wheel base on the df03ra to the same as the tt01e. does anybody know if I would have any issues trying to mount th sx4 body for the tt01e on the df03ra ?
Hide Signatures
       Post #: 28
RE: Official DF-03 Ra Thread - 12/20/2009 9:15 PM
aflipz
Score: 100
Status: offline
There are two sets of rear arms, one to shorten the wheelbase, but I don't see them taking more than 4-5mm off the total length.
Personal observation; the swing shafts are already swept forward a few degrees which seems wierd to me; in a perfect world the dog bones would line up straight with the diff outdrives; the more pronounced the angle, the less efficient it becomes angling it farther forward will make the drivetrain that much more awkward looking, which might be all there is to it, I couldn't tell you by how much if any this would affect performance.
My manual said to use the long wheelbase arms, so I did. All I can tell you is that in this configuration the distance between the front and rear wheel nuts is 258MM measured at the center of the nut and it's 180mm wide wheel to wheel (measured outside sidewall to outside sidewall)
The highest points on the chassis (spur gear cover and front shock tower) sit 20mm higher than the top of the tire measured with suspension fully extended.
There are two sets of front body mounts one to be used on the shock towers and one to be used on the front bumper. I believe using the ones on the bumper are much better because in a roll over crash the force exerted on the mount posts is not transferred to the fragile suspension mounts. I had put away the manual by then and did it wrong myself... Haven't paid the price yet but every run is another round of russian roulette. (mind you the consequences are not so dramatic) There are body mount marks on the DF-03 RA bodies to suit both post mounting locations.
Hide Signatures
(in reply to mvff1984)
       Post #: 29
RE: Official DF-03 Ra Thread - 12/21/2009 5:52 PM
alexchen86
Score: 105
Status: offline
holy crap the TEU-101BK can handle 2S Lipo?!
Maybe I should upgrade the motor now...I have the stock silver can...any suggestions on motor? I should probably get an external LVC too right I don't think the TEU-101BK has one.
Hide Signatures
       Post #: 30
RE: Official DF-03 Ra Thread - 12/21/2009 7:15 PM
aflipz
Score: 100
Status: offline
I actually fed my teu-101BK 11.1v (3S lipos) and it doesn't seem to be phazed by it at all... It does NOT have a lipo LVC but I ran it with a data logger to keep tabs. I stopped when I felt the first dip in power and it never went below 3v/cell
when I gave it the 11.1v, it fried my LED set which was connected to the RX; this means the BEC of the TEU-101bk sent it a huge spike of voltage; user beware! This is not recommended... 2s lipos are definitely safe no problem there. An LVC or LVA is desirable but not necessary if you "listen" to your ride and stop driving as soon as you feel a dip in power.
Rather than spending ANY money on something brushed I would suggest saving up and upgrading to brushless once and for all; better throttle response, less drag braking (*unless you WANT to program some in) longer run times, more power, more speed... win win win!
Hide Signatures
       Post #: 31
RE: Official DF-03 Ra Thread - 12/21/2009 7:33 PM
alexchen86
Score: 105
Status: offline
Well all my LEDs are already a PITA...I have so many things going wrong with them right now I just took the body and dropped it off to my LHS to figure it all out since I am running 2 sets of Ram LEDs and soldered 2 additional 5mm leds to two of the wires on each set so that I can have 6 red LED lights on the rear...I guess the circuit board could not handle that much.
Check out the pic...
Ram LED light sets come with a pair of 5mm front and a pair of 5mm rear hooked together to a circuit board.
Next time I am just going to do it myself RAM LED light sets are just a PITA!!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 32
RE: Official DF-03 Ra Thread - 12/21/2009 7:36 PM
MD6
Score: 100
Last Login: 5/7/2013
Status: offline
Have you seen this?
Hide Signatures
       Post #: 33
RE: Official DF-03 Ra Thread - 12/21/2009 7:37 PM
studysession
Score: 105
Last Login: 4/24/2013
Status: offline
quote:
ORIGINAL: MD6
Have you seen this?
Sorry, the page you requested was not found.
My CNC Website:
http://celticmachining.com
My CNC blog:
http://cncinside.com
Hide Signatures
(in reply to MD6)
       Post #: 34
RE: Official DF-03 Ra Thread - 12/21/2009 7:44 PM
alexchen86
Score: 105
Status: offline
I bet MD6 was going to post the Tamiya light connector thing which I have on my TT-01E where you can plug in up to 12-14 lights I think...and then I would probably balloon it.
Lesson learned: You get what you pay for and patience is a virtue!
My LHS only carries RAM LED light sets...i guess I will just have to order online next time...or go Radioshack haha
Hide Signatures
(in reply to studysession)
       Post #: 35
RE: Official DF-03 Ra Thread - 12/21/2009 9:30 PM
MD6
Score: 100
Status: offline
Let's try this.
Hide Signatures
       Post #: 36
RE: Official DF-03 Ra Thread - 12/21/2009 9:34 PM
studysession
Score: 105
Status: offline
Nice -
http://www.tamiyausa.com/images/product/250/58459/header_58459.jpg
My CNC Website:
My CNC blog:
Hide Signatures
(in reply to MD6)
       Post #: 37
RE: Official DF-03 Ra Thread - 12/21/2009 10:25 PM
aflipz
Score: 100
Status: offline
Seems like posting links taken from tamiya usa does not work... I am not surprised, it's one of the most poorly designed websites I have ever seen. If that were their only sales/distribution channel they would have been out of business a long time ago.
Hide Signatures
       Post #: 38
RE: Official DF-03 Ra Thread - 12/23/2009 7:11 PM
aflipz
Score: 100
Status: offline
Took the DF03 RA for an ice drifting session last night. My studded tires are hooking up like crazy on ice and packed now, really fun!
Defiantly, I ran the stock power system on 3 cells again (2200mah 25C 11.1v zippy slim pack) no issues to report, put 1900mah back into the pack, stopped when I felt a dip in power and again resting voltages were very normal.
Can't wait to get my brushless power system to see what this baby can really do!
Hide Signatures
       Post #: 39
RE: Official DF-03 Ra Thread - 12/23/2009 11:20 PM
bmx833
Score: 100
Last Login: 12/22/2010
Status: offline
Hi
I am gettin this beat for my christmas present, and was wondering about those arms that shorten it, would they shorten it enough to use a hpi citroen saxo body? thought it would look cool.
Can't wait to build it though
Brad
Hide Signatures
       Post #: 40
RE: Official DF-03 Ra Thread - 12/23/2009 11:38 PM
aflipz
Score: 100
Status: offline
what's the wheelbase? on this very page I was asked the same question and posted a long winded response including measurements; did you read it?
Hide Signatures
(in reply to bmx833)
       Post #: 41
RE: Official DF-03 Ra Thread - 12/24/2009 12:41 AM
bmx833
Score: 100
Status: offline
Yes i read it, the wheelbase on the saxo is 137mm and 190mm wide, do you think it would look stupid with it been 10-15mm out? might look ok?
thanks
Brad
Hide Signatures
       Post #: 42
RE: Official DF-03 Ra Thread - 12/24/2009 12:48 AM
aflipz
Score: 100
Status: offline
nah i think it'll put some of the wheels in the rear bumper and a large gap on the other side.
Hide Signatures
       Post #: 43
RE: Official DF-03 Ra Thread - 12/29/2009 11:38 PM
aflipz
Score: 100
Status: offline
Anybody know where to buy suspension springs for this guy? And sway bars?
I have no intention of getting heavier alloy shocks just to get spring options...
Hide Signatures
       Post #: 44
RE: Official DF-03 Ra Thread - 12/29/2009 11:58 PM
alexchen86
Score: 105
Status: offline
Hmmm...aflipz when running LiPO in your DF03Ra are you using the stock silver can? I will just watch the dip in power when I run my 3S as well hahaha
Hide Signatures
       Post #: 45
RE: Official DF-03 Ra Thread - 12/30/2009 12:44 AM
aflipz
Score: 100
Status: offline
Yup, stock to the bone; I could care less about the included motor and ESC thus my "balls of steel" when it comes to running it beyond it's specs.
If you care about yours, running it like I do mine is probably not the best for longevity.
Hide Signatures
       Post #: 46
RE: Official DF-03 Ra Thread - 12/30/2009 12:48 AM
alexchen86
Score: 105
Status: offline
aflipz....with the lineup of rigs and cars I have I don't really care if something breaks I always have a back up.
My girlfriend says I have too many. I say they're for back up. Lol
Hide Signatures
       Post #: 47
RE: Official DF-03 Ra Thread - 12/30/2009 1:06 AM
aflipz
Score: 100
Status: offline
I think it's a fairly popular disease afflicting RC people... Up until a few months ago I had no less than 9 airplanes fully decked out and ready for action, 3 rc cars 2 helicopters, 1 boat etc...
I managed to trim that down to 3 planes, 2 cars and one heli. (still borderlines obsessive compulsive disorder)
Hide Signatures
       Post #: 48
RE: Official DF-03 Ra Thread - 12/30/2009 4:00 AM
CWHFSR
Score: 110
Last Login: 3/29/2013
Status: offline
Hey!
I happened to get one of these recently off of ebay and I'm loving it! Was already put together (just nothing done with the shell, I painted it and my 11 year old put on the stickers) with several upgrades (the biggest one for me was the slipper clutch) and it was brand new! Anyway, I'm running the stock electronics until I burn them up but have a brushless system from my VXL Rustler waiting in the wind once needed. I've got a 2c4200 but have been running some of my 3c2200's through this as well... BIG difference in speed with a 3c.
I do have a question.... anyone running larger 3c batteries like in the 3c5000 range? Do they fit? If so, what brand?
Well, enough of my rambling post, I have a couple pictures:
Edit: My dogs sometimes get chased by the car.... don't know anything about that.... but they saw a chance to attack so had to pick it up after the pictures, you can see they were moving in!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 49
RE: Official DF-03 Ra Thread - 1/4/2010 1:50 AM
str8.krooked
Score: 100
Last Login: 1/14/2011
Status: offline
Are there any motor/gearing restrictions for the DF-03 RA? I'm currently drifting, but would like to get a rally car going. Also, what are other 1/10 electric rally options? I googled it, but didn't come up with much.
WWW.COLORADODRIFTRC.COM
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.922RCU1
