RCV120sp question for Keith from Keith
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> RCV120sp question for Keith from Keith
Page: [1]
Login
RCV120sp question for Keith from Keith - 6/3/2009 3:02 PM
ktcanuck
Score: 100
Last Login: 11/7/2009
Status: online
I believe someone asked this before but it wasn't fully answered.  I am about to mount one in a  TopFlite Bonanza.  The Bonanza nosewheel is offset to starboard.  I would like the exhaust exit on the port side so I have more room to route the exhaust internally without conflicting with the nosewheel mount or cowl.
I guess the first observation is about that crankcase vent.  It looks like it must be mounted close to the bottom so oil doesn't build up in the crankcase.  What tolerance can be applied to the mounted orientation of the crankcase vent?
Second question is whether you can separate the cylinder assembly from the crankcase and rotate it 180 degrees so the exhaust is on the right, carb on the top and vent on the bottom - all looking from the front.  Can the timing be maintained?
Answers much appreciated soonest - I am at engine mount stage right now!
Keith
Hide Signatures
       Post #: 1
RE: RCV120sp question for Keith from Keith - 6/4/2009 1:16 AM
rcbill58
Score: 100
Last Login: 10/29/2009
Status: offline
I guess the first observation is about that crankcase vent.  It looks like it must be mounted close to the bottom so oil doesn't build up in the crankcase.  What tolerance can be applied to the mounted orientation of the crankcase vent?  In my experience there is no restriction on the orientation of the vent, only that the vent hose be as short as possible and of the largest diameter practical.
Second question is whether you can separate the cylinder assembly from the crankcase and rotate it 180 degrees so the exhaust is on the right, carb on the top and vent on the bottom - all looking from the front.  Can the timing be maintained?  The cylinder can be rotated to any of 4 rotational positions, but the gears must be timed as described in the owner's manual.
Answers much appreciated soonest - I am at engine mount stage right now!  Happy Flying!!
Keith
Best Regards,  Bill Jensen
BJ's Model Engine Service*, 51 Hillside Dr., Beacon Falls, CT 06403
phone: 203-888-4819,   email: wbilljensen@cs.com
www.bj-model-engines.com
*a trade name of Flight Star Devices, Inc.
We are the factory authorized service center for:
RCV Engines                www.rcvengines.com
Revolution                    www.rc-revolution.com
Aerovate (RCGF)         www.zrcgf.com
Brison                           www.rc-revolution.com
ENYA                            www.enya-engine.com
JBA                              www.kangkeUSA.com
SK                               www.kangkeUSA.com
We also service all other brands!
"DEMON-CLEAN (tm)" heavy duty engine cleaner, buy it now on-line!.
Hide Signatures
(in reply to ktcanuck)
       Post #: 2
RE: RCV120sp question for Keith from Keith - 6/4/2009 12:52 PM
ktcanuck
Score: 100
Status: online
Excellent.  Thanks Bill.
Hide Signatures
(in reply to rcbill58)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
