RE: CD ScaleDesigns Albatros CI build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $400.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: CD ScaleDesigns Albatros CI build
Page: <<   < prev  106 107 108 109 [110] 111 112 113 114 115   next >   >>
Login
RE: CD ScaleDesigns Albatros CI build - 11/21/2012 10:44 PM
jeffo
Score: 105
Last Login: 5/24/2013
Status: offline
Francesco,Is your Ciii a Darrell Hansen design.If so,what angles did you set the stab and wings?The wings have 2* dihedral and both wings are in line,no staggering-Jeffo
Hide Signatures
(in reply to GianFrancesco)
       Post #: 2726
RE: CD ScaleDesigns Albatros CI build - 11/22/2012 7:18 AM
GianFrancesco
Score: 100
Last Login: 12/13/2012
Status: offline
Jeffo
No, my Albatros CIII is from my own plans; 1/6 scale and all the angles , incidence and wash-out are like the original; the airfoil also is from original 1915 drawings.
Hide Signatures
(in reply to jeffo)
       Post #: 2727
RE: CD ScaleDesigns Albatros CI build - 11/23/2012 10:18 PM
jeffo
Score: 105
Status: offline
Francesco,What did you set the wing incidence in relationship to the stab.-Jeffo
Hide Signatures
       Post #: 2728
RE: CD ScaleDesigns Albatros CI build - 11/24/2012 7:30 AM
GianFrancesco
Score: 100
Status: offline
As from 1915 J. Lagorgette drawings:
upper wing +6°
lower wing +6°
Stabilizer +2,5 -3° (with possibility to adjust this incidence +/- 1,5°)
Hide Signatures
(in reply to jeffo)
       Post #: 2729
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 9:58 AM
jeffo
Score: 105
Status: offline
Francesco,I measured the plans and came close to the same results.
Both wings 5.5* pos.
stab 2* pos.
I was a little concerned with the wing incidence,but my guess is why they have so much incidence is because the airfoil is so thin.-jeffo
Hide Signatures
       Post #: 2730
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 10:23 AM
GianFrancesco
Score: 100
Status: offline
I believe that if my Alb flies so well in 1/6 scale in a bigger scale (1/4) it should fly only better
Hide Signatures
(in reply to jeffo)
       Post #: 2731
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 1:53 PM
abufletcher
Score: 1576
Status: offline
That would be my guess too. On my CI I'm just trusting the incidences that Chris used in his design. I know they are not "scale" but I know that Tom's CI flies well.
Hide Signatures
       Post #: 2732
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 2:14 PM
GianFrancesco
Score: 100
Status: offline
In Italy we say "nessuno ha la verità in tasca" that sounds like "nobody has the Truth in his pocket"...
Hide Signatures
(in reply to abufletcher)
       Post #: 2733
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 2:18 PM
abufletcher
Score: 1576
Status: offline
Ain't THAT the truth!
Hide Signatures
       Post #: 2734
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 3:55 PM
US185Damiani
Score: 105
Status: offline
Just a quick reminder,  The heavily positive incidence was due to the nature of the undercambered airfoils.  The had their own positive incidence built in.
_____________________________
www.goldenageair.org
Hide Signatures
       Post #: 2735
RE: CD ScaleDesigns Albatros CI build - 11/25/2012 4:57 PM
Nieuport nut
Score: 105
Last Login: 5/23/2013
Status: offline
Also, at that time, climb rate was very important. It is less so for us as we stay on the ground and so are always adjusting the flight for our fixed vantage point. Most R/C fliers are more comfortable with less difference between the wing and tail incidences. However, the originals are perfectly usable if you don't mind using the throttle more for climb and descent.
Martin
Hide Signatures
(in reply to US185Damiani)
       Post #: 2736
RE: CD ScaleDesigns Albatros CI build - 11/27/2012 3:52 PM
abufletcher
Score: 1576
Status: offline
Step by step, experiment by experiment, the quest for the best looking covering goes forward. After multiple tests, problems remained with the silk-applied-with-PolyC approach. For one, the PolyC really doesn't function effectively as an adhesive to stick the edges of the silk to the underlying fabric. Second, no matter what I tried, I was still getting a sandy texture to the silk even after 2-3 coats of PolyC. It was as if the PolyC was somehow "raising the grain" on the silk. Also the PolyC seems to render the fabric+silk combination almost transparent (almost like yellowed plastic). But perhaps worse of all, when I tested the PolyC over the Polyspan I got both sandy grain and wrinkles (maybe caused by differential drying), so that was no good at all.
So I went back to basics. I covered a test frame with Natural (uncolored) Solartex and then applied a coat of non-tautening Nitrate, then the moistened silk is laid down and smoothed out with a fingertip. And then more non-tautening Nitrate is brushed through the silk. And that seems to do it. Once the second coat of nitrate dope is applied, the rest of the weave can be filled with either PolyC or Butyrate instead of the nitrate (of which I have only a limited supply). This still isn't going to solve the problem of the black CF tubes showing through, but I may just have to accept that. I've done tests where I sprayed the frame with grey primer, but I'm not sure that's really an improvement. Actually the silk is fairly opaque after the first "thin" coat (as seen in the test piece towards the tip) but goes more transparent with further coats. I was hoping I could just add the PolyC after the initial doping to keep this more opaque look, but this creates an uneven look where the PolyC goes where the dope hadn't.
I've added a couple small swatches of Solartex Linen and Antique for comparison purposes.
Click to see fullsize image.
Click for fullsize
< Message edited by abufletcher -- 11/27/2012 5:06 PM >
Hide Signatures
(in reply to Nieuport nut)
       Post #: 2737
RE: CD ScaleDesigns Albatros CI build - 11/27/2012 10:18 PM
caribefoto
Score: 100
Status: offline
Why not spray a coat of wood colored paint over the primed CF rod? Then the see through framework would look quite natural. .......John
2012 Blue Max contest and Fun Fly 28-29 Jan
Sanford Aero Modelers Field, Geneva FL
Hide Signatures
       Post #: 2738
RE: CD ScaleDesigns Albatros CI build - 11/28/2012 12:33 AM
abufletcher
Score: 1576
Status: offline
Actually, on the original CI the entire stab, elevator, fin, and rudder were made of steel tubing which would have been primed and then the edges wrapped with fabric. And according to Matz, the original linen isn't translucent enough to see the structure anyway. So my covering solution isn't perfect in this regard. One of my test during this week was to add white paint to the PolyC before applying the silk but that resulted in it's own problems.
This photo shows the test over the primered frame.
Click for fullsize
< Message edited by abufletcher -- 11/28/2012 1:21 AM >
Hide Signatures
(in reply to caribefoto)
       Post #: 2739
RE: CD ScaleDesigns Albatros CI build - 11/28/2012 3:41 AM
abufletcher
Score: 1576
Status: offline
I've also experimented with priming the frame with "rust" primer, white, and silver. The only thing that can be said for pre-painting the structure is that is at least all one uniform color. Also it IS possible to apply Stix-it (and dope) over the primer, through if you apply it heavily it eats into the primer, so thin coats are best.
Hide Signatures
       Post #: 2740
RE: CD ScaleDesigns Albatros CI build - 11/29/2012 11:21 AM
abufletcher
Score: 1576
Status: offline
Tail feathers primed and ready to cover.
Click for fullsize
Hide Signatures
       Post #: 2741
RE: CD ScaleDesigns Albatros CI build - 11/29/2012 3:00 PM
abufletcher
Score: 1576
Status: offline
Neat website:
http://jasta11.co.uk/index.htm
Hide Signatures
       Post #: 2742
RE: CD ScaleDesigns Albatros CI build - 11/29/2012 3:07 PM
Teus
Score: 105
Status: offline
Yeb,
Tail parts are looking great Don
Hide Signatures
       Post #: 2743
RE: CD ScaleDesigns Albatros CI build - 11/30/2012 11:59 AM
abufletcher
Score: 1576
Status: offline
The tail feathers are now covered with Solartex Natural. The next step will be to dope on the silk for the color. This shouldn't be as bad as covering everything again. It's more like "painting on the silk."
Click for fullsize
Click for fullsize
< Message edited by abufletcher -- 11/30/2012 12:52 PM >
Hide Signatures
(in reply to Teus)
       Post #: 2744
RE: CD ScaleDesigns Albatros CI build - 11/30/2012 1:02 PM
TFF
Score: 148
Status: offline
It is too bad the covering is not just a little off of white. It would look like a plane new out of the factory. Looks good.
Hide Signatures
       Post #: 2745
RE: CD ScaleDesigns Albatros CI build - 11/30/2012 1:23 PM
abufletcher
Score: 1576
Status: offline
Not really. German CDL wasn't yellowish from weathering. It was yellowish because the raw unbleached linen itself was beige/tan and this color was made even stronger by the varnish used. That is, the varnish gave a warm tone right out of the can. As near as I can tell the color of my test pieces covered with silk is what the aircraft looked like right out of the factory.
< Message edited by abufletcher -- 11/30/2012 5:17 PM >
Hide Signatures
(in reply to TFF)
       Post #: 2746
RE: CD ScaleDesigns Albatros CI build - 11/30/2012 2:45 PM
Nieuport nut
Score: 105
Status: offline
Still it looks quite nice.. Reminds me of clear doped silkspan.
Martin
Hide Signatures
       Post #: 2747
RE: CD ScaleDesigns Albatros CI build - 11/30/2012 2:57 PM
abufletcher
Score: 1576
Status: offline
The only parts still uncovered are the ailerons. I put off covering those while I looked into what material to use (Solartex) and whether I might consider making the structure more scale (no). Well, maybe no.
Adding the silk will be a big job...but perhaps no bigger than painting would have been. But before I add the silk I'm going to give some further thought to how I might do rib-stitching with this "no paint" method. I made some interesting attempts earlier they were all a bit too crude looking.
Hide Signatures
       Post #: 2748
RE: CD ScaleDesigns Albatros CI build - 12/1/2012 11:25 AM
abufletcher
Score: 1576
Status: offline
After thinking long and hard about methods for doing or simulating rib stitching, I've concluded that none of them are really satisfactory and/or compatible with my silk-CDL approach. I had some initial success reproducing the Z-shaped stitching but the were far too wide to be scale...sort of like having giant rivets on a WWII model. So for this model, I think it's best just to leave them off.
Hide Signatures
       Post #: 2749
RE: CD ScaleDesigns Albatros CI build - 12/1/2012 5:24 PM
abufletcher
Score: 1576
Status: offline
Too windy for flying today...but still beautiful fall weather.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
