Need some help with thrust figures guys....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> Need some help with thrust figures guys....
Page: [1]
Login
Need some help with thrust figures guys.... - 6/21/2003 7:35:08 AM
zope_pope
Status: offline
Hey,
I have my DP Ultimate put together and want to do 3d with it so i bought a YS 1.40 DZ. Its a hell of a nice motor, but I just want to see if these thrust figures sound right, and whether i am loading the motor too much (I think i am just a tad). I have this engine with a 20x6 Pro Zinger and I am turning it at about 8100 rpm leaned fully (before i back off 200 rpm). At that setting I am getting about 18 lbs of thrust. I am using CP 30% heli fuel, and live at 6000 feet. Does that thrust reading sound a bit too optimistic? Also my airplane weighs in at about 12.5 lbs (the weight on the box is so off!!). My questions are, does this thrust reading sound right? What prop should i try to get more thrust, and finally, will this engine have enough power to 3d my bipe at my altitude. Thanks to everyone that helps out. I plan to fly not this tuesday but next. Thanks.
Adam
       Post #: 1
Need some help with thrust figures guys.... - 6/21/2003 6:45:23 PM
bryan bateman
Status: offline
your thrust figures sound a little low actually. the way im figuring you are gettin at least 22 or 23 lbs. of thrust. That YS must be running like a champ to swing a 20 6 prop that fast. I may have to get me one. I have a saito 180 on my H9 Edge swinging a 16 8 at 9500 rpm. it is pretty good but then again i live at 600 asl. But i think that setup ought to work real good.
(in reply to zope_pope)
       Post #: 2
Need some help with thrust figures guys.... - 6/21/2003 7:24:04 PM
zope_pope
Status: offline
22 to 23 lbs? Wow, didnt think it was that much, then again it really does pull when i pick it up and try to hold it. Bryan, did you catch that i was at 6000 feet asl?? This may effect the thrust because there is less air to pull. Please let me know. I am thinking of switching to an APC 18x8W to run a little higher rpms and hopefully a little more efficient prop (I have found pro zingers to be not so efficient.) Thanks again for your reply.
Adam
       Post #: 3
Need some help with thrust figures guys.... - 6/21/2003 10:19:36 PM
robert
Status: offline
I think that the 18x8/9w would give you a better bite of whatever air there is.
       Post #: 4
Need some help with thrust figures guys.... - 6/21/2003 11:04:58 PM
zope_pope
Status: offline
Anyone have experience with Bambula? Please let me know. also i need to know where to get one. Thanks.
Adam
       Post #: 5
Need some help with thrust figures guys.... - 6/22/2003 11:24:15 PM
bryan bateman
Status: offline
Yes i considered the fact that you were at 6000 asl. At sea level i was getti actual figures of 28 and 29 lbs. of thrust. i took a lot away for the thinner air. I too would also try a 18*8/9.
       Post #: 6
Need some help with thrust figures guys.... - 6/22/2003 11:28:17 PM
zope_pope
Status: offline
Is this from experience or thrust hp? Just had to ask. thanks again for helping.
_____________________________
If you choose not to make a decision, you have still made a decision.
       Post #: 7
Need some help with thrust figures guys.... - 6/23/2003 1:14:58 AM
robert
Status: offline
28 pounds? Thats a heck of alot.
       Post #: 8
Need some help with thrust figures guys.... - 6/23/2003 1:17:16 AM
zope_pope
Status: offline
If i get 20 pounds i will be happy. Infact if get 18 lbs i will be happy, can someone help me put my worries away? I know i worry too much. :P Thanks again
       Post #: 9
Need some help with thrust figures guys.... - 6/23/2003 1:21:21 AM
robert
Status: offline
I'll give you some stuff from my YS 140L. It is turning an APC 16x11 at 8,960RPM, and 2600RPM at idle. This engine should put out about 18 pounds+, so your DZ, which is alot more powerfull, should give out about 22 I think. 28 pounds I think is either optimistic (Thrust HP), or one helluva motor.
       Post #: 10
Need some help with thrust figures guys.... - 6/23/2003 1:26:06 AM
zope_pope
Status: offline
Hey thanks, Just remember i am at altitude, but i think i should be able to produce that much. Proabaly 19-20 at my altitude. By the way, how much do you think thrust hp is off by?
       Post #: 11
Need some help with thrust figures guys.... - 6/23/2003 1:33:04 AM
robert
Status: offline
I think that your performance (12 pound bibe at that altitude) would still be sensational, probably hovering at 3/4 stick. Just get the drill out and look for obvious not wanted weight.
I have no idea about thrust HP, but it can't be accurate.
       Post #: 12
Need some help with thrust figures guys.... - 6/23/2003 1:39:35 AM
zope_pope
Status: offline
Yeah, It looks like they took most of the weight out, but I am going to look for some carbon fiber gear (not sure it will help because it is tail heavy). Well maybe i could lighten up that tail section. Thanks for everyones help. According to thrust hp My 40 LA would hover my Trainer. :P
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
