AeroWorks Yak .60-.90    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> AeroWorks Yak .60-.90
Page: [1]
Login
AeroWorks Yak .60-.90 - 6/8/2009 8:40 AM
grasstrimmer
Score: 100
Last Login: 8/24/2010
Status: offline
 I was wondering if anyone had flown one of these with an OS .91.  What kind of power would it have, and does it fit in the cowl decently?
Hide Signatures
       Post #: 1
RE: AeroWorks Yak .60-.90 - 6/17/2009 11:58 PM
Gargoyle
Score: 100
Last Login: 7/4/2011
Status: offline
Grasstrimmer
I don't know about how much power an O.S. 91 would have, because mine has an O.S. 120 AX.
Are you talking about a .91 Four stroke or the two stroke FX ?    The 120 AX is a perfect match up here in
Alberta where I'm at about 2000 ft.  The O.S. 91 FX is about the same size as the 120 AX so it would fit
 perfectly in the cowl.  The 91 FX would probably be a little under powered though especially if you want to fly 3-D.
George
_____________________________
There is no such thing as a "sucking chest wound", all chest wounds "Suck".
Hide Signatures
(in reply to grasstrimmer)
       Post #: 2
RE: AeroWorks Yak .60-.90 - 6/18/2009 12:03 AM
Gargoyle
Score: 100
Status: offline
Grasstrimmer
Sorry !,  I miss-read, I thought you were talking about the .90 - 1.20 size YAK.
 My Bad... But the 91 should fly it just fine... The cowl however I'm not sure.
George
Hide Signatures
(in reply to Gargoyle)
       Post #: 3
RE: AeroWorks Yak .60-.90 - 6/18/2009 2:22 AM
skyesdad
Score: 100
Last Login: 1/6/2013
Status: offline
If it is a 91 fx 2 stroke it fits inside the cowl and the stock pipe fits the pipe tunnel they have. it flys the plane well but it is not unlimited but it is a very fun plane
Hide Signatures
       Post #: 4
RE: AeroWorks Yak .60-.90 - 6/19/2009 1:10 AM
Mark Dennis
Score: 100
Last Login: 5/20/2013
Status: offline
The .91FX really is the perfect 2 stroke motor for the 60-90 planes, it will require cutting the cowl for the head to clear but that is expected with most engines on this model.Let me know if you have any questions when it comes to mounting.I'm sure you will be very happy with it.
Team Aeroworks
Hide Signatures
(in reply to skyesdad)
       Post #: 5
RE: AeroWorks Yak .60-.90 - 1/5/2010 4:47 AM
mschulz531
Score: 115
Status: offline
I know it has been awhile since this thread was used, but I have a related question. I recently purchased a Magnum .91 four stroke engine (because they are on sale for $139) and I'm considering the Aero-Works .60 - .90 Yak 54 ARF-QB Quick Build as a home for this engine. Does anyone have any comments on this engine in the Aero-Works .60-.90 Yak-54 ARF-QB?
Also, I've looked at the manual for this plane and noted that the manual calls for servos to have the following specs: servos: min 80 in./oz. Torque @ 4.8 volts
I'm just wondering if they really need to be that strong...it doesn't seem like this model is all that big...also, high torque servos are really expensive.
I found these: Airtronics 94162Z High Torque Ball Bearing Servo (Torque @ 4.8V: 123 oz-in), but they are $30 each, and seem to be a little over-rated. Having trouble finding servos that are in the 80-90 oz-in range.
The radio for this plane will be the Airtronics RDS-8000 with the 92674 7-ch FHSS-1 Aircraft receiver, so I would need servos that are compatible with this equipment. I noticed that Hitec has some 72 oz-in servos but they have an "S" connector and I don't know if that is compatible with my Airtronics equipment.
Sorry for all the questions, just trying to plan things out as much as possible. Thanks for any help.
-Mike
Gold Wing Su-26m/DLE-30, Twist 60/Saito 1.15, Airtronics 2.4 Ghz SD-10G.
Hide Signatures
(in reply to Mark Dennis)
       Post #: 6
RE: AeroWorks Yak .60-.90 - 1/5/2010 6:10 AM
Aero-Works
Score: 100
Last Login: 5/15/2013
Status: offline
Hello Mike,
Thank you for your interest in our 60-90 Yak 54.
The Magnum .91 4stk would be a good choice for the plane. We did the flight testing with an OS .61 2 stk and the performance was very good.
As for the servo torque requirements we recommend the 80 in. oz. servos because of the larger surfaces. The plane will fly with a lower rating servo but we recommend the 80 in. oz. to be on the safe side.
Please feel free to give us a call and we would be happy to answer all your questions
Thank You
Rocco / Aeroworks
Hide Signatures
(in reply to mschulz531)
       Post #: 7
RE: AeroWorks Yak .60-.90 - 1/10/2010 10:32 PM
helifixer
Score: 100
Last Login: 1/25/2010
Status: offline
Rocco,  I have a question on the .60-.90 size yak I just built.   I went with an electric set-up and am trying to get the C.G. set at the recomended 2 1/4.  The manual states with fuel tank empty.  Does that mean no flight power battery installed for an electric set-up.
It is a big change in cg,  Thanks, great plane, waiting for the wind to die down for the maiden..............frozen in south florida.
Hide Signatures
(in reply to Aero-Works)
       Post #: 8
RE: AeroWorks Yak .60-.90 - 1/12/2010 8:34 PM
Aero-Works
Score: 100
Status: offline
Hello,
You will balance the plane with the Battery in place ready to fly. We balance the glow planes with tank empty because the plane will need to fly at the correct CG when the plane is out of fuel.
Let us know if you have any other questions
Thank You
Rocco / Aeroworks
Hide Signatures
(in reply to helifixer)
       Post #: 9
RE: AeroWorks Yak .60-.90 - 1/14/2010 10:42 PM
Moki 1.8
Score: 115
Last Login: 3/12/2013
Status: offline
I have the .60-.90 Extra 260 with a O.S. .75ax and it does really well and its not under powered. Those lil engines really put out alot. Im very pleased with the performance. Pulls the plane around with authority.
Hide Signatures
       Post #: 10
RE: AeroWorks Yak .60-.90 - 4/3/2010 10:44 PM
YUKONFLYR
Score: 100
Last Login: 6/19/2012
Status: offline
Will a Zenoah G20ei fit in this plane? I would really like to have a 60size gas plane
<Nitro><Pistons><Castor>
Revver Bro 178
Hide Signatures
(in reply to Moki 1.8)
       Post #: 11
RE: AeroWorks Yak .60-.90 - 4/11/2010 1:12 AM
airborne2.4
Score: 105
Status: offline
quote:
ORIGINAL: Moki 1.8
Do you think its enough power for 3D?
If you think you can or think you can''''t, you''''re right.
Hide Signatures
       Post #: 12
RE: AeroWorks Yak .60-.90 - 4/11/2010 1:19 AM
airborne2.4
Score: 105
Status: offline
quote:
ORIGINAL: Mark Dennis
Hey Mark, what about using this? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXMU4&P=SM
Hide Signatures
       Post #: 13
RE: AeroWorks Yak .60-.90 - 5/8/2010 3:39 PM
s. wallace
Score: 102
Last Login: 10/16/2012
Status: offline
Just maidened my AW Yak 54 with the OS 95AX...it's a keeper! Engine, though still brand new and not broken in, seems to pull much harder than either of the 91FX's I own.
Hide Signatures
(in reply to airborne2.4)
       Post #: 14
RE: AeroWorks Yak .60-.90 - 1/24/2011 2:22 PM
cloudniner
Score: 100
Status: offline
I have just installed a Saito 125 with a Slimline side mounted muffler in my 60-90 Yak54. I decided to cut 3/4" from the firewall because the engine stuck out too far in my mind. I just made up a new 1/4" ply firewall and glued it in. I have the 85cc version of the Aeroworks Yak54 and want the same look. I use a 17 X 4 APC prop with the 125.
Can't wait for spring!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to s. wallace)
       Post #: 15
RE: AeroWorks Yak .60-.90 - 6/26/2012 7:18 PM
nikonlarry
Score: 105
Last Login: 5/19/2013
Status: offline
I am setting up a AeroWorks Yak 54 .60-.90 as electric. Considering the Rimfire .80 50-55-500 with a 15x8 prop. Castle Creations Ice2 HV80 ESC and Castle Creations BEC.
Flight power 5C 5000mAh battery.
I found it kinda hard to come up with the right combination. Some if the test reports are kinda old and I think there is better equipment on the market then ware in the tests.
Thanks, larry
Hide Signatures
(in reply to cloudniner)
       Post #: 16
RE: AeroWorks Yak .60-.90 - 9/14/2012 9:36 PM
Garthwood
Score: 100
Last Login: 5/12/2013
Status: offline
Rocco............i'm thinking of buying the YAK 60-90 and will install the SAITO 20CC GAS, will this engine fit inside the cowl ? it looks like it wll. I also wanted to know if i can install two instead of one elevator servos, i don't think this would be a problem, would it ? I am also wondering that the wheel pants on these YAKS are not scale, they're too big. Where can i get wheel pants that is to scale for this YAK ? Sorry for all these questions, but i need to know before i make the expense.
Charles.
WACO Brotherhood # 87
Carl Goldberg Ultimate 10-300 Brotherhood # 61
Hide Signatures
       Post #: 17
RE: AeroWorks Yak .60-.90 - 9/14/2012 9:46 PM
Garthwood
Score: 100
Status: offline
quote:
ORIGINAL: cloudniner
I have just installed a Saito 125 with a Slimline side mounted muffler in my 60-90 Yak54. I decided to cut 3/4'' from the firewall because the engine stuck out too far in my mind. I just made up a new 1/4'' ply firewall and glued it in. I have the 85cc version of the Aeroworks Yak54 and want the same look. I use a 17 X 4 APC prop with the 125.
Cloudniner..................can you post more pictures if you have any without the cowl. I might purchase this size YAK and install the SAITO 20CC . This Saito 20cc gas is the same physical size of the Saito 125. By the way i also have the saito 125 in a TOPFLITE Hawker Sea Fury, beautiful running engine, although i had a big problem during running in, but it's all sorted out now.
Will appreciate more pictures of your build in regard to engine installation. Thanks...Charles.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
