Sharp curve
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> Sharp curve
Page: [1]
Login
Sharp curve - 6/9/2009 12:00 PM
carlosam
Score: 100
Last Login: 11/6/2009
Status: offline
Someone has found it has problem with hovercraft rudder in the water to do much better the curve to the right and have difficulty to make the left.
If I to reduce the width of the rudder and to increase the length will be going to improve?
_____________________________
Be happy is to stop being a victim and becoming an author of the history itself.
Hide Signatures
       Post #: 1
RE: Sharp curve - 6/10/2009 10:47 AM
Rowboat
Score: 100
Last Login: 11/8/2009
Status: offline
I don't know exactly what your problem is . But I would say just try a diferent rudder size and see what happens.
 Have you anny pics to show us.?
Boating is not a matter of life or deth, It is more important than that !!
Hide Signatures
(in reply to carlosam)
       Post #: 2
RE: Sharp curve - 6/10/2009 12:59 PM
carlosam
Score: 100
Status: offline
quote:
ORIGINAL: Rowboat
My boat goes straight.
The problem is that it is much better to bend to the right and a great difficulty for the curves to the left.
The black version is current and the white is that I want to install.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Rowboat)
       Post #: 3
RE: Sharp curve - 6/10/2009 1:54 PM
Mr Cajun Gator
Score: 100
Last Login: 11/7/2009
Status: offline
If what you have now is not working then what will it hurt to try something else. Looks like the second rudder will work better
Catch a Gator by the Tail and hang on for the Ride!
Cajun Gator Airboats, M.AB.A
Hide Signatures
       Post #: 4
RE: Sharp curve - 9/30/2009 6:46 PM
mrfixitwhite
Score: 100
Status: offline
if you really mean 'Hovercraft' then you'd do much better with air rudders behind your thrust fan-unless your meaning an airboat then water rudders are fine
if you have a water rudder -kind of defeats the purpose of hovering on air so you can drive on land or water.
do you have any pics of your craft?
Hide Signatures
(in reply to Mr Cajun Gator)
       Post #: 5
RE: Sharp curve - 10/1/2009 6:48 AM
nick_75au
Score: 100
Status: offline
Is the steering servo attached with 1 rod to the rudder, when the servo pulls its usually a positive "connection". The rod can flex when pushed by the servo giving less throw to the rudder and causing the problem you describe. If you run 2 rods it makes a "pull pull" system and will be more direct action on the rudder.
The 1st rudder will exaggerate the problem as it is less "balanced" IE % of blade behind the pivot point is higher, requires greater force from the servo. Ideal is 25% forward and 75 % aft of the pivot.
Regards
Nick
Logan City Marine Modellers
Hide Signatures
(in reply to mrfixitwhite)
       Post #: 6
RE: Sharp curve - 10/19/2009 3:26 AM
rickburnout666
Score: 100
Last Login: 10/26/2009
Status: offline
I always found air rudders work best on an airboat, directly behind the prop or one either side, plus they dont go snagging submerged obsticles,weeds. etc. the only time you might need water rudders is when you have strong cross winds, that catch the air rudders, and can cause blow overs, been there, done that, got the T-shirt. What engine/motor will you be using ? Nitro,Gas,Electric Brushed or brushless? and what size is the craft?
(hello Mr Cajun Gator & mrfixitwhite i have returned)
http://www.rcuniverse.com/forum/m_5220872/anchors_5220872/mpage_1/key_/anchor/tm.htm#5220872
Hide Signatures
(in reply to nick_75au)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.564RCU1
