RE: 2.4 GHz Weatronics, PPM or PCM?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: 2.4 GHz Weatronics, PPM or PCM?
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 1:37 PM
mr_matt
Score: 107
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: BaldEagel
quote:
ORIGINAL: mr_matt
Will the Futaba MPDX-1 work in 12 channel Futaba PPM mode?
Matt
The MPDX-1's will only work with the 14MZ Tx.
Mike
Hi Mike,
The MPDX-1 works with the 12MZ ( I have one) and I have heard with the latest software it works with the 12FG as well.
Regards,
_____________________________
Matt
JetCat rep
Hide Signatures
(in reply to BaldEagel)
       Post #: 26
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 1:53 PM
BaldEagel
Score: 103
Status: offline
Matt
I have the latest FG and it has no way of accessing the multiple screens to set up the eight servo's that plug into the MPDX-1, I am hopping it will as I have two of them and would like to use them if I can.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to mr_matt)
       Post #: 27
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 2:00 PM
1Eye
Score: 100
Status: offline
quote:
ORIGINAL: HarryC
David, Weatronic doesn't seem to want to sell its new equipment!  The website hasn't been updated for about 9 months and doesn't tell us anything that we really want or need to know about the new kit.  <snip>   Are they going to be bothered to actually market the stuff properly and give us information?
H
Agree.  All this great stuff falls into the unobtanium category for now.
Mike
How is my flying? Call 1-888-BITEMY6
Hooligan AF/CC
Hide Signatures
(in reply to HarryC)
       Post #: 28
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 2:40 PM
mr_matt
Score: 107
Status: offline
quote:
ORIGINAL: BaldEagel
Matt
Mike
Hi Mike,
Yes who knows?
Check this out.
http://www.rcuniverse.com/forum/m_8376034/anchors_8376034/mpage_1/key_/anchor/tm.htm#8376034
EDIT: Mike BTW with the 12MZ, under the Function menu, you have a selection called "Multiprop1" (it is a pick from a list like "Aileron". "Rudder2", etc)
< Message edited by mr_matt -- 6/17/2009 2:48 PM >
Matt
JetCat rep
Hide Signatures
       Post #: 29
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 2:57 PM
BaldEagel
Score: 103
Status: offline
Matt
In that case your 12MZ supports it, but the 12FG still does not.
Mike
Hide Signatures
       Post #: 30
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 3:18 PM
Woketman
Score: 100
Status: offline
quote:
ORIGINAL: HarryC
quote:
ORIGINAL: jetnuno
I was planning to change it to ppm mode to have more channels, but I am a bit affraid to fly jets in ppm mode even with the weatronics. Is any one using it in this mode?
I can't speak for the Weatronic, but I have been flying my jets for 5 years on Multiplex PPM, never PCM, and the only problem I had was on one model due to an aerial installation problem which 2.4Ghz can suffer from too and which I have now sorted, apart from that I have had 5 years of rock solid, problem free flying of metal-coated jets on PPM!
H.
I can echo all that Harry said.  I have been flying MPX PPM with the IPD 12 channel receiver and the IPD 9 channel RX for almost ten years.  NEVER a single issue that I did not cause myself.
Hide Signatures
       Post #: 31
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 3:57 PM
Mokken
Score: 105
Status: offline
I've been running the Weatronic 2.4 system for a month now. I have a JR10x which I converted, have one 10ch micro rx in my 2.6m YAK and an 8ch micro rx in my Eratix. Weatronic will be releasing smaller rx's in the near future.
I'm no expert on this by any means, but I can tell you I've not had a single problem with this system. The programming is amazing, and the telemetry you get back for each flight is very valuable, everything from TX voltage, RX voltage, RX temp, and all other flight telemetry options are saved each second the TX is turned on, and saved to a micro SD card in the module.
There is even a spectrum analyzer built in with the software so you can monitor what's going on at your field, of course you need a laptop to do so. So many other options for programming, of course you can keep the programming in your radio as it and not use the software.
From what Gerhard told me at Joe Nall, they have a setup for just about every radio and yes it uses the PPM mode, PCM at least on my 10x causes the servos to jitter and glitch, but PPM works fine, as it was designed.
I'm glad I waited. I paid $289 for the module and 10ch rx, and $128 for the 8ch rx.
Attached are some photos and I'll be happy to answer any questions.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Woketman)
       Post #: 32
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 4:59 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: Mokken
Ok, since you offered
How's the TX balance changed (if at all), for neckstrap users ?
How much extra power does the RX consume, in order to achieve the bidirectional comms ?
"Facts do not cease to exist because they are ignored." - Aldous Huxley
"He who establishes his argument by noise and command shows that his reason is weak." - Michel de Montaigne
Hide Signatures
(in reply to Mokken)
       Post #: 33
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 6:02 PM
Mokken
Score: 105
Status: offline
quote:
ORIGINAL: Gordon Mc
quote:
ORIGINAL: Mokken
The transmitter feels fine, I use a strap as well. Only thing I'm having to get used to, it not seeing my old metal antenna sticking out in front of me, I've even caught myself going for it before a flight.
I don't see any voltage difference. I'm running A123 batteries in 2.6m YAK and before I switched I would put around 1000ma back into the pack after a full day of flying on 72, the same is going back into the packs after the same amount of flights on the Weatronic.
Hide Signatures
(in reply to Gordon Mc)
       Post #: 34
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 6:56 PM
Edgar Perez
Score: 100
Status: offline
quote:
ORIGINAL: BaldEagel
Matt
Mike
i don't have the 2.4 version, but with the 72MHZ yuo could use the MPDX as long as the signal/servo limits in the weatronic software was 120% (like ATV. Trrid with only 100% and did not work)
Edgar Perez
Puerto Rico
Hide Signatures
       Post #: 35
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 10:44 PM
HarryC
Score: 100
Status: offline
quote:
ORIGINAL: David Gladwin
There is quite a bit of info on the new 2.4 range including the manual for the Micro (although the advanced programming needs the Giga Control software) on the USA site of Weatronic
I found a micro rx manual but it mostly describes installing the tx module, it only refers to setting the rx failsafe.  Is there anything that describes all the other programmability that you say the micro rx has?
H.
Hide Signatures
(in reply to David Gladwin)
       Post #: 36
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 10:57 PM
Mokken
Score: 105
Status: offline
I don't believe there is a manual out yet that explains everything. If you want to download the giga software and see what all is there, just register and then you can download it. Again, you have to register to see the additional downloads.
http://www.weatronic-usa.com/index.php?option=com_docman&Itemid=31
Hide Signatures
       Post #: 37
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 8:36 AM
David Gladwin
Score: 100
Last Login: 11/4/2009
Status: offline
Harry, As of Monday  the main manual including the Giga Contol software, latest version, 2.06,  is in final stages of preparation (it is 90 pages) so SHOULD be released soon.  If you download the software from the USA site you will get a good insight  of the capabilities, including the Spectrum monitor !
After a day with Weatronics on Monday and a day exploring the system yesterday I just cannot speak too highly of this equipment, its capabilities are quite awesome. Alwin is clearly an exceptionally  talented engineer   but his quest for perfection has led to the rather delayed release. My view is that its been very well worth waiting for  and I will be equipping almost ALL of my models with these receivers, they are just SO far ahead and more capable than  anything else  I have seen to date.
Regards,
David.
Hide Signatures
       Post #: 38
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 8:58 AM
Gandalv
Score: 100
Last Login: 11/7/2009
Status: offline
Is the antenna of this unit a directional tx-antenna (since its all flat) ? If so, do you have to point it in the direction of the plane all the time to get the best signal, or is there a round standard antenna lying in there ?
Still this system seems very good, so it will be interesting to see how the long term use will be from several users (since many other manufactures had there problems at first).
Anyhow think I will buy one of this system, just gone wait a little bit longer to see some more feedbacks.
Best regards
editreaon: typo
Truth is, there is no Best - just different
Hide Signatures
       Post #: 39
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 3:38 PM
lov2flyrc
Score: 101
Last Login: 11/6/2009
Status: offline
The transmitter antennas are so called polar (surface) antennas, as they are being used in GPS systems or cell phones. They have a big advantage.
Because of their circular polarization, the characteristic transmission pattern is close to being ideal. They are far superior to the commonly used linear polarized W-LAN rod antennas. Circular polarized antennas create a more stable link, if obstacles intrude into the path of the link. Obstacles absorb some of the signals depending on the materials in different polarization planes, so that signals from polarized antennas are less likely to be absorbed and with that provide a safer link.
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
Hide Signatures
(in reply to Roger M)
       Post #: 40
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 6:23 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: lov2flyrc
Gordon,
I never really found many limitaions I could not work around with the older 72mhz system, although some of the limitations did seem a arbitrary.
The new unit has rectified many of the limitations that preceded the 2.4 unit, you can now assign any servo to any channel... Even drive a single servo by multiple channels. You can gang any servo, regardless of rx port and even reverse a servo when ganged and sync'd. Still playing with the features but have yet to find a limitation period...
Well, I downloaded the s/w and experimented with it a bit... looks like it has the same completely arbitrary restrictions as the old stuff.
Not sure if I'm just doing something wrong with the s/w though, so as a sanity check - can you please try assigning Channel 1 to both Servo 1 and ANY of : Servos 9, 17, 25, and let me know if you can do it ?
So, I am NOT able to "assign any servo to any channel" as suggested above, due to numerous prohibitions introduced by the software. Feels kinda like trying to book a flight on NWA using airmiles - gotta keep shuffling stuff around and around to avoid the "blackouts".
Gordon
Hide Signatures
(in reply to lov2flyrc)
       Post #: 41
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 6:54 PM
tothemax
Score: 100
Status: offline
Do you have 10 operational channels with this configuration?( 10X + 10 ch  DR receiver )
Steve
Hide Signatures
       Post #: 42
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 9:22 PM
gerhardp
Score: 100
Last Login: 11/5/2009
Status: offline
quote:
ORIGINAL: Gordon Mc
quote:
ORIGINAL: lov2flyrc
Gordon,
Gordon
Hi Gordon,
First off, sorry for the long reply. You are the one and only customer who has an issue with the servo assignment "limitations", as you put it, that Weatronic has in the programming. To me, how I understand it, it is safety and feature driven.
Tip: To avoid your shuffeling, you program first, then plug in the servos and then you can play without having to shuffle. simple as that.
The following is based on the 2.4 Dual FHSS system and the R series (big) receivers.
Initially, one can assign any servo to any channel with the first servo. After that, there are two (three for the 30 servo outlet version) blocked out servos which limits the choice of which servos you plug into which outlet for that same channel. The ratio is 2 out of  20 or 28 outlets initially? Now we have one servo per channel and voltage controller, which makes it the safest setup possible.
I will explain it to you again in detail now for the 2.4 system, since this is a 2.4 thread.
It is a programming limitation driven by a physical limitation as I have described to you in another thread. It is there for a reason. It is not "arbitrary or hap hazardous" as you like to put out repeatedly.  We have a design / feature limit of eight servos per channel.
With eight voltage regulators on board, every one of them is limited to a certain peak and continuous load (peak X? Amps, continuous 32 Amps). To share the load of every servo starting (current peaks simultaneously) at the same time on a single channel you have to spread it out to the eight controlers. Else there is no point in having eight smartly sized voltage controllers. To achieve what you want, it would take 8 huge voltage controllers and cooling systems as a current Power Box system uses. Weight and space limitations and staying smart prohibits this.
Each one of the eight columns is powered by one regulator. With that said, "The Weatronic Gods" have two things in their mind.
1.   They want it to be safer. If any servo on any voltage regulator dies and causes the voltage controller to be blocked by the draining servo, all other 7 regulators will still work fine and you can land your model safely.
2.    "The Weatronic Gods" want to make sure that users do not overload the individual voltage controllers in the setup installation for similar reasons (see above). (During prototyping this has lead and would lead to future complaints from more than 1 customer)
This would happen if a customer like you who intentionally or not, ignores or is simply not interested in the safety potential philosophy behind this, would decide to put three high load digital servos of the left wing aileron of a big model on outlets 1, 9, and 17 (column 1) and the right three aileron servos on outlets 2, 10 and 18 (column 2). Now you do a fast roll or a rolling circle and everything reacts sluggish, because you are driving all aileron servos from two regulators at the same time instead of six regulators.
That is not hard to understand. This makes a lot of sense and has nothing to do with "arbitrary or hap hazardous God decisions" as you have put out.
If this is a "no buy limitation" for you, that is ok for me. The last thing I want is an unsatisfied customer. Luckily you have a choice.
Not putting in these safety features (limitations in your world) will naturally lead to complaints from the users that do not want to have to think too much about this sort of a problem.
The choices are:
- One or more crashed customer models which are then very unhappy past customers, with damage to someone elses property etc. etc.  or...
- One customer (YOU in this case) with no sale due to a non functional "limitation" of choices of outlets over all the other features...
go figure -  I will rather not satisfy you and keep the other customers who can live with this "limitation" safe and happy.
I will let the other customers vote by making their choice of weather or not they want to accept such an insignificant (my personal opinion) "safety driven mechanical feature limitation".
Sorry that we can't serve you in this one point.
Also please put out facts and not ambiguous expressions as "numerous prohibitions introduced by the software", because just the opposite is the case. No other system offers so many useful new and never offered features.
e.g. Show me a system where you can make a choice between channel and servo failsafe. I could go on and on.....
It leads me to wonder weather you have an agenda going against Weatronic driven by???
No offense, I really hope this satisfies your questions and sorry for the long detailed reply.
Sincerely,
Gerhard Paasche
Technodynamik-USA
Independent master distributor of Weatronic products in the USA.
P.S. Good luck if one of your servos dies and pulls down the power box.
Hide Signatures
       Post #: 43
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 9:46 PM
gerhardp
Score: 100
Status: offline
Hi Steve,
I reccomend at this time to use the PPM setting in your transmitter. With that you have the features of the transmitter in PPM mode. These might be upgradeable through newer software of the manufacturer of the transmitter. The programming features of the receiver though might allow you to do more and easier than with a tranmitter having more channels. You can use 6 channels (less work load) and use the extra outlets for dual functions or parallel servos (omitting Y-leads),  sequencing or other features.
Regards,
Gerhard
Weatronic-USA
Hide Signatures
(in reply to tothemax)
       Post #: 44
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 9:53 PM
Mokken
Score: 105
Status: offline
quote:
ORIGINAL: tothemax
Yes, I have all 10ch's available. Gerhard at Joe Nall told me that if I bought the 12ch, I could use the other two ch's on the RX with my 10x, as on/off, for lights or something else that did not require a digital ch.
Really cool stuff with Weatronic.
Hide Signatures
       Post #: 45
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 10:40 PM
Gordon Mc
Score: 100
Status: offline
quote:
gerhardp
Fair enough – you are entitled to your opinion. Mine currently differs based on the explanations (or evasions thereof) that I have had thusfar. If I receive any better / more enlightening explanation then I'd be perfectly happy to change that opinion.
You certainly do NOT need any change in cooling systems and all that other guff to achieve what I would like to see from an even more improved Weatronic system. Simply removing / altering some programming limitations would likely suffice.
I have repeatedly asked, and have never received a meaningful answer for this point, so let me try once again … can you please explain to me how me having channel 1 activate both my airbrakes on servo 1 and activate my lights on servo 9 is in any way a safety issue that needs to be prohibited ?
I certainly do appreciate your prior useful info about wanting to spread certain loads around, and as mentioned in the prior thread I adjusted my Weatronics setup accordingly. However, the people who wrote the software for this unit (The Weatronic Gods) don't actually know what function the end user will apply to each and every output. Consequently, the imposition of hard limitations (as opposed to e.g. a simple warning / advisory from the programming tool – which would actually be very useful without being limiting) that are imposed ARE arbitrary – at least based on the definitions I am familiar with for the word.
I'm not trying to put 3 high load servos for the same function on the same regulator – I was trying to drive a teeny-weeny little servo that drives a Robart air-switch, plus activate a light module which has its own power supply. So, once again – WHAT IS UNSAFE ABOUT THAT ? A meaningful answer to this question (for once) would be much appreciated.
I'm fully aware that you are not bothered about "satisfying" me as a customer, and coincidentally I'm also totally OK with not doing business with you. I simply wanted to know whether this new generation RX had removed the limitations of the prior system.
Gordon
Hide Signatures
(in reply to gerhardp)
       Post #: 46
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 10:44 PM
HarryC
Score: 100
Status: offline
I've had a look at the giga control software and it does indeed seem to give the programmability that my Wea 35Mhz 12-20DR has, and more, to the 2.4ghz micro rx.  Why on earth is that not mentioned anywhere on their website, on their leaflets etc?  Is it just an error of the giga software that they have applied full programmability to all types of rx in the giga software and forgotten to limit it when a micro rx is chosen?  If correct though it's fantastic and the prices being quoted are quite a bit less than the prices for Multiplex's 2.4Ghz system Rxs that I was about to convert my Multiplex Tx to.  I may get the Wea system after all.
My big reservation about Weatronic remains though - I expect the next generation of Tx to not use modules but to have a 2.4ghz board built in somewhere deep inside.  There will be no module socket for the wea tx converter to plug into, nowehere for it to get power and nowhere to get a PPM signal from as there simply won't be a PPM stream.  So when we change our Tx to the next one, all the expensive Wea system rx we have become unuseable.  How is Wea going to get around that, because if they can't then they have a limited life remaining?
H
Hide Signatures
       Post #: 47
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/18/2009 11:00 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: HarryC
I didn't really twig to what you were saying the last time you mentioned this - but I guess its certainly a possibility that next-gen TXs from the major players no longer provide modules if they have no further desire to support 72 / 35 / etc Mhz in the way the old systems do. Are there any major countries where 2.4 RC is NOT allowed, that would help convince manufacturers to stick with a modular approach ?
If not, maybe Weatronic have to either offer their own TX, or do a 'send your TX in for conversion' approach. They're innovative enough that they hopefully will be able to plan around any such eventuality.
Gordon
Hide Signatures
       Post #: 48
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 12:10 AM
Woketman
Score: 100
Status: offline
Now that you mention it Harry, exactly WHY have high end transmitters had modules for the past two decades?  Why not just a crystal for frequency swap?  What was the point???
Hide Signatures
       Post #: 49
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 12:52 AM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: Woketman
Swapping Xtals is insufficient for "larger hops" such as 72 <-> 35 or 40 Mhz.
When you take a JR TX e.g. from the USA to Europe, you can not simply switch Xtals, you have to have a complete new module.
Been there, done that. There may also have been additional reasons such as varying power levels per country being handled in the module ? Not sure.
I also recall hearing from a JR service guy that in some countries the authorities supposedly allow / allowed Xtal swaps only to be done by licensed technicians, so Xtals had to be actually soldered into modules, as it was OK to switch entire modules, but not individual components. Not sure how true / accurate that info is.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.984RCU1
