RE: 2.4 GHz Weatronics, PPM or PCM?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
NEW!! Boomerang Nano Landing gear Pro-Lynx - RTF
Seller:  digitech
Details:   $450.00   |  9/24/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: 2.4 GHz Weatronics, PPM or PCM?
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 2:32 AM
lov2flyrc
Score: 101
Last Login: 11/6/2009
Status: offline
Gordon,
Pardon me for asking, perhaps I am missing something.... How exactly are you limited in function by not be able to use ports 9 and 17 off channel 1?? Why couldnt you just use any of the other 17 ports offered for your lights (or whatever you desired to run in conjuction)?  Perhaps it's me, but I fail to see the problem, you literally have a multitude of other ports to choose from?!
Personally, I just do get where your coming from....
_____________________________
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
Hide Signatures
(in reply to Gordon Mc)
       Post #: 51
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 2:38 AM
Mokken
Score: 105
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: lov2flyrc
Gordon,
From what I gather from reading both his posts and Gerhard's reply, this is not something new with him. If I had to guess it's the 'I want it this way, why can't I" kind of mentality, one of the many parts of our wonderful hobby.
You can't please 100% of your customers 100% of the time.
Hide Signatures
(in reply to lov2flyrc)
       Post #: 52
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 2:48 AM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: lov2flyrc
Gordon,
Hi Todd,
The problem is that there isn't just that ONE limitation of output 1 not being able to use 9, 17, etc - there's also that same +8 and +16 limitation onf output 2, 3, 4, 5, .. because each of those extra ports you mention come with their own restrictions that just keep adding up. Do the math and you'll see that a full 12% + of the available combinations are prohibited. When you're trying to find a combination that works for driving all of the functions in a complex model, those totally unnecessary restrictions are nothing but a pain in the you know what, needing a whole bunch of unnecessary wasted time trying to find some combination that is somehow blessed by the Weatronics Gods. So much so, that I gave up in frustration at this nonsense, and installed a matchbox to get around the pointless restriction.
I know it's a hugely powerful system, but it would be even more powerful (and usable) if not for what I can only consider to be misguided design choices. The restrictions simply seem unnecessarily heavy handed.
Gordon
"Facts do not cease to exist because they are ignored." - Aldous Huxley
"He who establishes his argument by noise and command shows that his reason is weak." - Michel de Montaigne
Hide Signatures
       Post #: 53
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 2:52 AM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: Mokken
Indeed - and why CAN'T we have it that way - especially since that (the ability to assign any servo output to any channel) is how it was marketed, and how it continues to be incorrectly described ?
Gordon
Hide Signatures
(in reply to Mokken)
       Post #: 54
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 3:02 AM
lov2flyrc
Score: 101
Status: offline
quote:
ORIGINAL: Mokken
quote:
ORIGINAL: lov2flyrc
Gordon,
Well, perhaps if I did not know Gordon as well as I do, I would not bother to question him but.... Gordon is indeed a highly intelligent individual, thus, my confusion as to why this methodology of design is an issue for him. Either I am missing something in his explanation or indeed, he is getting a bit too nit-picky. Simply planning your requirements and system setup as your programming would eliminate any conflicts in channel/port usage. How exactly does this stop you from achieving your programing goal? have I missed something?
Hide Signatures
       Post #: 55
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 3:06 AM
Mokken
Score: 105
Status: offline
quote:
ORIGINAL: lov2flyrc
quote:
ORIGINAL: Mokken
quote:
ORIGINAL: lov2flyrc
Gordon,
The think it's the nit-picky part and the high intelligence.... and I don't know Gordon at all...
Seriously, I'm confused as well, Gerhard's explanation made perfect sense to me.
Hide Signatures
       Post #: 56
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 3:09 AM
lov2flyrc
Score: 101
Status: offline
Fair enough Gordon... Since I have never has an issue programming a complex model on weatronic, can you provide me a scenario that you could not achieve using this hardware?
FWIW.... I am currently using a Weatronic 72mhz system in our six figure Target Drone for line of site flight testing. I am very confident in the systems performance and function.
Hide Signatures
       Post #: 57
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 3:43 AM
gerhardp
Score: 100
Last Login: 11/5/2009
Status: offline
Hi Gordon,
It is very easy to do programming in the way that Weatronic recommends doing the servo setup. It is like walking downstairs. You start at the top, with channel 1, left click on servo outlet 1, 2 etc until you have the servos accounted for - in that channel. Then you step down to the next channel and continue with the next servos. My niece who has no idea of RC modeling is able to do that. White says you are ok to choose and red says not available.
If you go into the Micro receiver software, you can indeed choose every servo to any outlet. No restrictions there. This is, guess what, - because there is no power management included.
But wait we have another restriction here!!!!! We can only mix five channels This must be another turn off decision for your free spirit. I don't quite understand how you survived with the non programmable receivers over the past umpteen years. What a burden that Weatronic is putting on you.
Please be so kind and give me a servos count to channel setup in which you are not able to achieve what you would desire from functionality.  It will take me or anyone else familiar with the system less than 3 minutes to set up the servo configurations in the receiver and meet the requirements. Your so called restrictions of 12% are outside of the design envelope of the receivers. If you accept the thought that the engineers and programmers put together after a long period of trial and errors (which include the scenario you are wanting to achieve).  In addition it is not fair or maybe disrespectful to the people who put a lot of thought and time into it.
Then please also show me the advantage of a Power box system, which of course has mostly one (rarely two) voltage controllers.  And how about two receivers? Now we get complicated..... Lots of wires and connectors and RF-noise......????  You must be having two different scales of measure going on here...
SORRY..... but I don't get it !! But as Mokken said: You can't please 100% of your customers 100% of the time.
Sorry for my sarcasm,
I'm not out to get you or whatever, but you are stating things in public that are not based on facts.
You are entitled to go and develop your own system that has none of these limitations. Have at it.
Thanks and this was my last response to you on this "limitations issue"
Gerhard
P.S. Sorry again if this offends you, but you are asking for it. G
Hide Signatures
       Post #: 58
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 4:47 AM
Woketman
Score: 100
Status: offline
Sorry guys, but I have known Gordon to be a VERY level headed, middle of the road dude for many years.  He is not one to make wild claims that are not based on fact.  If he is skeptical of the new Weatronics offering from a programming view point, then perhaps some of us should be too!
Perhaps he is dead wrong, but you Weatronics guys have to show us the details!
Hide Signatures
(in reply to gerhardp)
       Post #: 59
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 11:58 AM
NM2K
Score: 100
Status: offline
Gee, a type written infomercial.
Ed Cregger
"Practice makes prefect"
Saito Club Member #52
Hide Signatures
(in reply to Roger M)
       Post #: 60
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 2:44 PM
Gordon Mc
Score: 100
Status: offline
Mark – thanks for the kind words, but I absolutely do NOT want to make other people wary of using a Weatronics product – I really just wanted to know whether this new product had the same limitations as the prior one. That's it. It sounds like a very capable system that will make many people happy.
I'm obviously not doing a very good job of explaining my point here. When I started describing its programming to 2 of my team-mates at work, they quickly zeroed in on the same point and asked 'Why isn't that a guard (A bypassable warning) rather than a hard stop (a total prohibition) ?" So, unless I can find a better way to explain myself, maybe it takes a particular (twisted ? ) mindset to easily understand my point. I'm sure that with your (genuine!) rocket-scientist background there are things that you immediately see that others without your history don't see, and that you sometimes have problems communicating your point.
My frustration here is only partly due the limitations I see – it's at also frustration at my own inability to frame my point in a way that lets others understand what I'm getting at. Usually I am able to come up with a halfway decent analogy that puts my point into terms that make it more accessible for others, but this time I am drawing a blank.
Todd – the Jag is in storage right now, as I am preparing to go out of the country again for a whlie and don't want my toys lying around here in an empty house while I am gone. I can go get it out once I get back, to get the info about the configuration.
Anyway, I absolutely do NOT want to put others off of using this product, so if that is what it looks like then I should just shut up until I can find a better way of explaining what I'm trying to get at. If the Weatronics appeals to you, go buy it - don't be put off by me.
Matt - sorry for hijacking your thread. You can slap me the next time you see me at BW
Gordon
Hide Signatures
(in reply to Woketman)
       Post #: 61
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 3:02 PM
lov2flyrc
Score: 101
Status: offline
No problem Gordon.... As you, I am trying to wrap my head around your specific issue so I can understand how you (and if you) are really being limited by the programing configuration. I have written down multiple complex setup scenarios and used Gigacontrol to (mock) program each. I still have yet to run into a setup where I am unable to achieve my programing goal.
When you have a moment to sit down with the plane, I would be very interested in seeing the programing issue you encountered.
Todd
Hide Signatures
       Post #: 62
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 5:40 PM
gerhardp
Score: 100
Status: offline
quote:
ORIGINAL: lov2flyrc
Todd
Hi Gordon,
I am always here to help as well.
I am offering you to give me a problem that you can not get resolved with Weatronic and I will do my best to help to get it resolved.
Not being able to plug in a servo into one particular outlet, when there are plenty others available is to me and most everyone a very minor restriction and has to do most likely with problems that occurred during testing and as a prevention to avoid to explain to a lawyer that "yeah, it could have been programmed into the software to avoid this setup and consequent failure".  This is a crazy world, where common sense is not a strong legal standpoint.  Remember the lady that "tried to dry her cat in the microwave?" Got a recipie for this?? I don't think so.
Liability insurance in General Aviation accounts for 1/3 of the cost for a new aircraft or product in an aircraft. Some parts of industry don't even touch GA with a ten foot pole, by advice from their legal council.
I'm on board with you if it comes to restrictions, but in nowadays world you often have no choices in that respect.
Bottom line: So this particular restriction does not really hurt and you can still program everything you need, again more advanced than any other system. On top we even give you a tool (data logging) to see where problems occur and analyze it.
I still do not understand the logic behind this one limitation so far and declining the system which you have openly stated.  Again I would like to learn all the other limitations that you mentioned compared to other systems.  I would like to find out, because I want to gather info as feedback to improve the product.
If you compare the 72 MHz software with the new 2.4 software you can see a lot of new features and upgrades that are all based on feedback from all customers.
I am listening,
Sincerely,
Gerhard
Hide Signatures
       Post #: 63
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 6:16 PM
mr_matt
Score: 107
Status: offline
I think sometimes we see a bug magically turned into a feature! We do it all the time at my real work, I am sure Gordon has been in a few of those situations. Not claiming that is what is involved here, I really do not care.
I can see a case when you have a completely set up plane and you add something (a gyro, a light system, etc) that does not draw much current, but its addition forces you to reallocate your channels. This could prove frustrating.
In the end the market decides, if in the end no one cares, then the point is moot.
I would be more worried about the aggressive tone taken towards Gordon in this thread. That does not look good to me as a potential customer.
Matt
JetCat rep
Hide Signatures
       Post #: 64
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 6:50 PM
gerhardp
Score: 100
Status: offline
quote:
ORIGINAL: mr_matt
I read that the Weatronics 2.4 Ghz system is 12 channel.
Anyone know if (and how) they do that on a Futaba radio?
Hi Matt,
I have an old Futaba 7UAP transmitter.  I can only transmit on 7 channels. I can though use the receiver, both micro and the big R series receiver and program any servo to any channel (just a matter of which outlet I program and plug that servo into the appropriate outlet). With slow function, mixing and sequencing etc. there are so many things that can be done and are impossible to do with any other receiver. It is not a waste of money using a 12 channel receiver on a lesser channel transmitter. In extreme you could even program the 12 Channel micro receiver to use one channel to drive all 12 outlets.
I hope this satisfies your question.
On other notes from other thread users:
I reccomend to use the PPM setting for the 2.4 systems for the time being. I have had jitters in PCM setting and I am sure that future Firmware updates will solve this problem.
The websites will also be updated progressively as things get done.
I will also do a series of video to support the manual.
Anyone who has a login and password to download software etc will also get the info-emails that will go out as products get available and other information as software and Firmware upgrades get issued.
Thank you,
Gerhard
Hide Signatures
(in reply to mr_matt)
       Post #: 65
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/19/2009 9:02 PM
Gordon Mc
Score: 100
Status: offline
Matt – thanks, but I didn't see any of the posts as being any more 'aggressive' than I myself am being here in trying to communicate my point. Anyway, I'm totally OK with a heated debate if it helps figure out where the disconnect is, and helps lead to a solution / understanding , etc.
Todd & Gerhard – based on your posts you seem to be reading something different than what I have been writing. If you check my wording, you should see that I'm not saying there ISN'T a way of configuring everything to work on my Weatronic RX – simply that the repeated shuffles htat were required to find an acceptable setup were sufficiently time consuming and frustrating that it was quicker for me to give up and install a matchbox for the last function than keep fussing with the software til I could get an "acceptable" combo. While some may just shrug their shoulders and accept the hassle because they don't know that it can be made quite a bit easier for them, my software engineering background simply makes me frustrated at how a powerful system can be made less powerful by its software.
This isn't a HUGE issue – it's a small problem that just happens to bug me enough for me to want to avoid dealing with it again if at all possible. However, it seems that the longer the debate goes on without us really comprehending each other, the more of a big issue it may seem to be in the forum. Essentially, I'm saying "There's a molehill over here, and I don't like molehills", you guys are saying "There is no molehill", I'm saying "Sure there is – it's right there…" etc … and in our inability to agree whether there is a molehill or not, the disagreement itself (as opposed to the origin of the disagreement) becomes more of a mountain. Again, I don't want this to be something that could lose anyone sales (I doubt that it would, since no-one with any sense gives a hoot about my twisted opinions ), so it's up to you guys whether we should continue to debate this here or take it offline if you think that the continuing public debate looks bad. I'm OK either way.
BTW Gerhard –you told me previously about the need to avoid having the same reg driving multiple high-power servos for the same surface/function, and there being FOUR regulators in my RX, not the 8 mentioned in this thread (I guess that increased # of reg's is new for the 2.4 system? cool.). Based on that, it isn't simply a case of following white and pink squares, since the software was inconsistent in showing pink squares for outputs that share the same reg – it blocks out outputs that are 8 apart, not those that are 4 apart which also (from your prior description) should be avoided for similar major control surfaces etc.
Now, the comments along the lines of "all you have to do is sit and plan your entire RX channel assignment right at the very beginning" may well be fine for e.g. people who only ever want to assemble ARFS whose functionality is completely laid out for you from the get go. The Jag in which I used my Weatronic RX was not such a simplistic project. No kits of this model were built yet, so I was having to figure a lot of the stuff out as I went along. At the point when I was programming the major flight controls, and making up the custom wiring harness for them, I had not yet made all of the decisions as to whether I would have operational airbrakes, whether I would install a lighting kit, or a bomb- or tank-drop, whether I would need additional servos or electronic air-valves to handle the complex interactions of 11 (!!) gear doors that sometimes overlap each other (yuch!), etc., etc. So, the "you should plan every single servo assignment out before plugging the first servo wire in" concept just doesn't cut it IMO, unless Weatronics wants to market the RX as something only suitable for people who never want / need to add any new functionality to their aircraft after the fist servo is plugged in. (Slight exaggeration, but hopefuly you get the idea). Instead, I bought it as something that was marketed as having complete flexibility in channel <-> servo mapping… a promise which it failed to deliver on, and that's the start of my frustration. Maybe a small point to some, but the starting point of cumulative frustration for me, since without this initial issue the follow-up annoyances would not also have arisen.
Now, remember what I said about my custom wiring harness (thanks for the Ashlok stuff Todd – works very well and I will use these again). This means that if it comes to juggling servo outputs around when the software won't allow certain combinations, either I am limited somewhat in which slots I can move certain servos to (easy to move them an inch or so, but not much further, and the RX is what- 5" across ?), or I have to remake parts of the wiring harness – which again was certainly doable, but was annoying when I knew that the limit I was fighting against was completely unnecessary. There's some added frustration.
Next, when I go to move a given servo from slot X to slot Y, I find that too to be unnecessarily time consuming. Now, maybe I'm just a dumb*ss who hasn't figured out how to use the s/w properly yet, but here's the deal – if I could select two servo assignments and hit "switch", and / or cut & paste entire servo assignments to a clipboard / buffer / 2nd aircraft setup, then switching assignments around could be quick and pretty painless. Instead, what I ended up doing was to have to go into each servo's info and write all of its settings down, then re-enter that info in the various screens for the new slot that I will be assigning that servo's location to. Given that things like setting the throws for the servo can't even be done by text entry (why not ??) and instead I had to keep moving the mouse up & down, up & down, overshooting and then undershooting the value I wanted until luck intervened and I got the desired value – that again takes up time unnecessarily, and adds another layer of frustration especially when I have to do it multiple times. The cummulative effect of multiple small annoyances, hit mutiple times each, became enough of an issue that I gave up and shoved a matchbox in instead.
(BTW, the poor control that leads to over / undershoot seems to be a problem on the S/W for the older RXs, but not on the new stuff – so kudos on that improvement.)
If you absolutely must put in the restrictions in such a broad manner (which I believe unnecessary, but you seem stuck on), you could perhaps consider alleviating any hassles associated with that by e.g. treating servos as objects that can be copied / moved in their entirety so as to make the shuffling process go much quicker. In case I'm not being clear here, let's consider an made-up-on-the-spur-of-the-moment example – I have the RX completely set up the way I want it for 16 servo outputs, but then I decide to add a 17th output for bomb-drop. Slot 17 is empty. Due to the way I want to activate it, and the restrictions you want to put on the system, I can't do this without shuffling stuff around. I believe that I can achieve what I need by moving the new servo to 16 instead of 17, move the existing servo 16 to servo 12, and existing servo 12 to 17. (These are arbitrarily chosen numbers, so don't try to read anything into the chosen numbers !). So, I select servo 12 and drag-and-drop, or cut-then-paste it to 17. All of the settings that were associated with servo 12, move to servo 17 without me having to spend a bunch of time manually redoing the whole thing. Then I do the same for moving servo 16 to 12, and then I use slot 16 for my new control.
From a user's perspective that process is pretty painless, compared to the awkward manual stuff I went through. It's also a change that I think ALL of your users would value, even if they are not currently complaining about missing user-friendliness aspects of the UI, and while it isn't as clean a solution to me as removing unnecessary restrictions, it's a compromise that I would personally find usable.
Such copy-paste capability could even be used to do more complex shuffles by making a copy of the model and then using one file as the source and the second as the destination for the rearranged data. If it makes it easier to understand, think of it in terms of an Excel spreadsheet that you want to rearrange ; make two copies of the spreadsheet, and you can copy-paste not only individual cell data (== a single component of a servo's setup), but also an entire row (== a servo's entire setup) from the original sheet to the new, re-ordered, one.
Again, if I'm a dumb*ss who can't see that that functionality is already there, then I'd be happy to be educated in that respect, and I'll publicly 'fess up to how much of an eejit I've been.
Actually … I just compared the S/W for the new RXs and that or the old one – looks like the new one does have a servo-copy capability in it, which the s/w fo rmy old RX does not ? (There's a "Copy Servosettings" button, which I have not yet figured out how to use – no mention of it in the manuals I downloaded.) Does this allow what I just described above ?
Gordon
BTW, I finally remembered a situation from many years ago, that may help as an analogy about what some of my frustration here has been…
In a town (Dunfermline) in Scotland that I used to live next to, I went to an Asda supermarket on a Sunday to buy groceries. As I approached the area where the bread was, I found that there was a barricade (poles + caution tape) right across the main isle at that end of the building, cordoning off the area where the bread was. I asked the Supermarket manager why we were being prevented from getting access to the bread aisle, and he responded "It's for your protection, to prevent you breaking the law".
Dumbfounded, I asked what was illegal about buying a loaf of bread, and he responded that there was an Alcohol aisle adjacent to the bread aisle, and that the law prohibited the sale of alcohol on Sunday. I said "That's fine, I don't want to buy alcohol, just bread ; if you reposition your barricade slightly, it will block off the alcohol but still provide access to the bread." He just looked confused and repeated "The barricade is for your protection, to prevent you breaking the law". I tried several times to get across the point that the positioning of his barricade was unnecessarily heavy-handed in that it prevented perfectly legal purchases, not just the illegal ones, but we were getting nowhere. Eventually, he said "If you'd just do your shopping on Saturday instead of Sunday, there would be no problem". True, but again totally missing the point. The store was heavily advertised as being open on Sundays, so why should I have to change my shopping day to Saturday just because this store manager can't comprehend that there's nothing wrong with me buying bread on a Sunday ?
My frustration was again not just at the unnecessarily broad restrictions that were put in place, but at the fact that I could not seem to adequately explain to this guy, facts which to me seemed blindingly obvious. Whether he was having comprehension problems, or I was having problems in adequately articulating my message, I don't know – but either way the exchange just left us both frustrated.
Hide Signatures
       Post #: 66
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 12:48 AM
gerhardp
Score: 100
Status: offline
Hi Gordon,
I talked to Germany about this issue and they told me, that of course they could go into more development to make every outlet to be connectable to any channel, but that would take an even greater effort of programming and additional hardware etc, which would make the unit heavier and about twice as expensive in production etc.  So - that is not an option.
Thank you very, very much for taking the time and explaining in detail what your frustration is based on.
If you would have given me a call while you were encountering the problem, I would have been able to help you in less than a minute and show you how to copy servo setup settings and curves from one servo to another.  It actually is fairly simple on the 72MHz system. The 2.4 system actually has a copy function programmed in it. For the 72 MHz it is as follows:
-   With an open program file and on the servo settings page  -
1.  You declare the servo that you want to copy from as a master servo.
2.  You declare the servo that you want to copy to as a slave servo. Now the curve and settings of the master servo is copied to the slave servo.
3.  You brake the slave linkage again (set both to single servo) and voila - you have the settings copied.
4.  Always remember to save the settings to the receiver and a backup on your computer.
This is also to be found in the frequently asked questions section on my website.
It takes me less than 20 seconds at most to do that. If I do a mistake, I can always go back to the last saved file and start over. How much easier can it be?
As you already had said in you last response,  you can also use unused servos to create curves and "store them in unused servos (20 backwards) as a basic setup library for a new model and then you can do the same copy routine to set up a new system. It is simple and straight forward and does not take a rocket scientist as you said - to do that.
As I offered before, I am here to help. The systems both the old and the new 2.4 are very powerful.
As you described, you also limited yourself with the wire-bundle. When you add on another new servo or light switch, where is a restriction to plug it into any of the outlets on the 4" X 1/2"  area?  I have a hard time comprehending that. Some of the power boxes have an even bigger area that you have to aproach to make things work.
So you will have to program the new switch / servo anyways.
-  You connect the receiver to the computer, look at the servo settings page and see which of the servo outlets are available for the particular channel that you have chosen.
-  Then you make your choice, program the switch, try it out, and again save the program.
-  Then you route the servo cable or switch and you are done.
I would really be happy to help you understand the system better and get you back on board again. I have nothing to hide and I share all I know about everything in regards to Weatronic systems.
Thanks for keeping the lines open,
Sincerely,
Gerhard
Hide Signatures
       Post #: 67
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 8:30 AM
HarryC
Score: 100
Status: offline
Gerhard, my 12-20R seems to have 4 regulators, so I would have thought that each regulator would supply 5 outputs, which would suggest that output 1 blocks outputs 6, 11, and 16.  Why then does it block outputs 9 and 17 only?
Harry
Hide Signatures
       Post #: 68
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 4:58 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: HarryC
Harry
Harry, that's one of the points I brought up repeatedly in the past, and again in my recent post - though in my (perhaps incorrect) reckoning it would be 1 blocks 5, 9, 13, 17 instead of just 9 and 13 (rather than 6 and 11 as you mention above).
That's also why I found the comment about 'blocking 9 and 17 from being tied to 1 protects our butts in a lawsuit' seemingly misguided. If how you and I are understanding thius is correct, then vased on the instuctions from the judge on a trial I was recently peripheraly involved in, their approach actually makes them MORE susceptible to a lawsuit, not less. The way this would be argued in court is that by the manufacturer saying that "linking servo channels that use the same regulator together is such a severe safety hazzard that it had to be programmatically prohibited altogether", yet having their software only prohibiting HALF of the problem scenarios from occuring, that is in effect considerably more negligent than if they never indicated that there was a big old safety issue at all - especially when no other manufacturer has felt the need to prevent such issues. Now, there's obviously no predicting how some juries may react, but what I'm saying here is that what we were told is that this kind of action actually opens up more doors to successful prosecutions than it closes.
Furthermore, again based on the instructions from that same judge, having a warning about a potential issue, that the user must accept responsibility for bypassing - would likely provide MORE protection. Although manufacturers can not get away with just slapping a warning on such as "Warning - your car may randomly blow up because of a design error", the law does protect cases where the user makes a clear choice to bypass a well explained warning. At least, that's what I got from that particular trial - but I'm not a lawyer, so who knows.
Later,
Gordon
Hide Signatures
(in reply to HarryC)
       Post #: 69
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 5:29 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: gerhardp
Hi Gordon,
What I was advocating (or at least trying to advoate), would not require any more hardware or weight - just a couple of minutes of programming. When a user selects two sero outputs to be driven by the same input, and those are two outputs that you have concerns about driving multiple high-current servos on the same type of surface - pop up a warning box that says e.g. "The chosen servo outputs share a single regulator. This is unadvisable for {explain your concerns} ;" and have user selectable options for (a) Thanks for alering me to the potetnial issue - I'll choose another servo output please, or (b) Thanks for the warning, but these are NOT multipl high-current devices, so please let me continue linking these together.
quote:
ORIGINAL: gerhardp
No problem – I wish I'd been able to do a better job of getting the point across right from the start, but at least we're making progress now. If we should meet up at some point, the beer's on me.
At the time I actually bought the unit, a different group were the Weatronics USA guys (at least based on my understanding of the business setup), and my questions to them were often met with "I dunno". If I had known there was some different people who I could call for help that could certainly have made a difference, and perhaps helped nip a lot of my frustrations in the bud.
Again, sounds workable now that it's explained (will have to try it out next month to be sure)/ As for how much easier can it be – yes, it can be a bit easier : (1) put in an actual copy & paste function [Sounds like you are at least half-way there on the newer systems – I found copy but no paste], and (2) Better to put the info in the actual manual.
Will the newer software be usable at all for the older RXs in order to have this more user-friendly functionality for the old systems ? (Currently it seems not to allow old styles to be selectable)
OK – again I probaby didn't explain the issue in enough detail. Can try again later if necessary, but for now I've gotta run.
Ditto. When I get back from Peru, I'll take another stab at this, plus another look at the 2.4 system.
Gordon
Hide Signatures
       Post #: 70
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 7:13 PM
HarryC
Score: 100
Status: offline
quote:
ORIGINAL: Gordon Mc
Yes, my error, I miscounted.  If each regulator powers 5 outputs then regulator 1 either powers outputs 1 to 5, or outputs 1, 5, 9, 13, 17
H
Hide Signatures
       Post #: 71
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 7:23 PM
gerhardp
Score: 100
Status: offline
quote:
ORIGINAL: HarryC
Harry
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11">Hi Harry,
with 4 approriately sized regulators and the need of 8 servos per channel (part of the initial design concept), there is simply no other way than to allow two servos per regulator.
Gerhard
Hide Signatures
       Post #: 72
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 7:39 PM
Gordon Mc
Score: 100
Status: offline
So, if you are saying that the official position is that 2 servos per regulator is OK, but 3 or more is not, then the programming is poorly implemented because based on this position I should still be allowed to drive both servos 1 and 9 from input 1 just as I wanted to; it makes no sense that 1 and 5 be allowed, but 1 and 9 not be allowed, based on this info.
Instead of the programming immediately blocking out 9 and 17 as soon as I select 1, it should allow everything to remain free, and then once I select 9 it should block out 5, 13, 17 etc.
What am I missing ?
Gordon
Hide Signatures
       Post #: 73
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 9:45 PM
gerhardp
Score: 100
Status: offline
Hi Gordon,
I wrote: "appropriately sized regulators". You are willing to use only one regulator for 20 servos over this 4 or now 8 regulator concept setup. So basically you have discarded this concept because of a limitation that you don't even have a choice of in the system that you are reverting back to. So why exactly are you still picking at this?
Bottom line from me: I will pass on your suggestions. Other than that, I can't and won't do anything about it.
If you are interested in utilizing the system as it is, I will be happy to help you to get it working within the "limits" of the system (weather they are driven by design or the Weatronic God does not matter to me).
That is all I have to offer,
Sincerely,
Gerhard
Hide Signatures
       Post #: 74
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/20/2009 10:06 PM
Gordon Mc
Score: 100
Status: offline
Gerhard, you're very clearly still not getting what I'm trying to say. Harry seems to understand, so maybe he can help explain what I apparently am not able to.
Or - let's take this one baby step at a time.... Simple question : Are the guys at Weatronic HQ happy having 2 servos driven by the same input, be on the same regulator.
Yes or no ?
Gordon
P.S. Don't give up now !
I think we're making progress – you understand at least part of my past frustration, and I've learned from you that there's a hack that I can use to reduce the hassle associated with the current limitations, so we're making significant progress. If we can now follow the current train through to conclusion then either I'll learn more about the restrictions than has been disclosed so far, and hit a Eureka moment, or you may understand at least part of why I see these restrictions as arbitrary – a term which you apparently don't like, but which you might be able to understand with a little more perseverance here.
< Message edited by Gordon Mc -- 6/20/2009 10:37 PM >
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.766RCU1
