2.4 GHz Weatronics, PPM or PCM?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
JetCat P160SE ECU-V6.0
Seller:  ghost_rider
Details:   $370.00   |  10/10/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> 2.4 GHz Weatronics, PPM or PCM?
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
2.4 GHz Weatronics, PPM or PCM? - 6/9/2009 10:29 PM
mr_matt
Score: 107
Last Login: 11/8/2009
Status: offline
I read that the Weatronics 2.4 Ghz system is 12 channel.
Anyone know if (and how) they do that on a Futaba radio?
_____________________________
Matt
JetCat rep
Hide Signatures
       Post #: 1
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 1:03 AM
Edgar Perez
Score: 100
Status: offline
I was told they get the PPM signal from the transmitter, since they were unable to crack the futaba protocols. That's why you don't get 14 channels..
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to mr_matt)
       Post #: 2
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 1:40 AM
lov2flyrc
Score: 101
Last Login: 11/6/2009
Status: offline
quote:
ORIGINAL: mr_matt
Just started testing the Weatronic 2.4 system today, I'll look into what modes they are using with Futaba in the morning....So far, I am HIGHLY impressed with the product. Weatronic has certainly put some serious thought into this 2.4 system. Features and software are astounding! They claim over 2 mile ground range, will find out just how accurate this claim is tomorrow.Gotta love the bidirectional signal which warns the pilot when the battery of the receiver has low voltage or the signal range is reaching the boundaries.
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
Hide Signatures
       Post #: 3
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 1:45 AM
lov2flyrc
Score: 101
Status: offline
Actually, just found it in the manual...
PCM mode will provide 10 channels
PPM mode provides 12
I was also informed a 16 channel unit is in the works.
Hide Signatures
(in reply to lov2flyrc)
       Post #: 4
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 5:05 AM
GJr.
Score: 100
Status: offline
Just to confirm, the unit will give 10 channels using a JR 10SXII/10X series and Graupner MC24 series TXs, it will give 12 channels with a JR12X and Graupner MX22,MX24 series TXs.
What kind of power out put does their TX module have for the USA version?
What series TX will the 16 channel unit work with?
Does Weatronics have plans to offer a transmitter of their own?
Is there FCC certification on the units for the USA?
I sent Weatronics an email, but have yet to receive a reply.
Glen
Hide Signatures
       Post #: 5
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 2:53 PM
mr_matt
Score: 107
Status: offline
Yes Todd I just checked my 12Z, it has a 12 channel PPM mode, I did not know that.
I wonder if the MPDX-1 will work with PPM mode and this new receiver?
I have mutual friends with the engineers at Weatronics, they are top notch guys.
Also, I thought ACT had "cracked" Futaba and JR PCM a long time ago? Seriously it should not be that hard, we reverse engineer stuff like this all the time at my real work.
Matt
JetCat rep
Hide Signatures
(in reply to GJr.)
       Post #: 6
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 5:31 PM
lov2flyrc
Score: 101
Status: offline
Matt,
I certainly am not smart enough understand the technology of the behind the scene function of the weatronic FHSS system, I will iquire with Gerhard as to the reason for the limitation in PCM mode.
The modulation options are shown below from a software screen shot. BTW... If anyone is interested in playing with the Weatronic software and capabilities, you can simply go to www.weatronic-usa.com and register on the website. You can then download the GigaControl software for free. I recommend everyone at least take a look at what this system is capable of, far beyond anything else on the market.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 7
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/10/2009 7:53 PM
mr_matt
Score: 107
Status: offline
I agree, if it is a tight integration with Futaba (G3 or FAAST modulation, or PPM if the MPDX-1 works) this is a very attractive unit for me.
Matt
JetCat rep
Hide Signatures
       Post #: 8
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 9:50 AM
David Gladwin
Score: 100
Last Login: 11/4/2009
Status: offline
I  spent yesterday in Stuttgart with Weatronics getting an in depth tutorial on the Micro and the larger DR. I have flown the Micro (itself a DUAL receiver) in my BobCat as "plug and play " unit with total success, not a single problem, totally rock solid.  There will be a full article in the next RCJI in its plug and play form (no PC required).
Yesterday we went through the advanced features of this unit with the latest firmware loaded into the receivers and the latest software into my PC.   The capabilities of the tiny Micro are just incredible, progammable warning levels downloded and recorded into the Tx (whose performance is also monitored and recorded) PLUS  assignable channels PLUS totally programmable servos PLUS,  coming soon,  twin integral gyros all in a box no bigger than a JR 1221 and much cheaper to boot. This is an extraordinrily capable and advanced unit  way,  way,  ahead of anything else on the market AND it was tested to over 100 deg C and still worked !
The transmitter module is unusual but this a function of its function, including two highly efficient antennae with a radiation pattern far better than the common single rod, one reason for the unit's exceptional range,  and of course the unit has to receive as well as transmit. I am getting quite used to it now, its not a problem in any way and the green light on the unit gives a continuous indication of a solid RF link ( and a warning if you are getting near range limit, or your battery voltage has dropped to a preset level, or your receiver is getting hot !)
The bigger DR expands on these capabiliies even more with huge power handling ability plus GPS plus  3 gyros capable of normal, attitude hold  or constant angular rate, (Wealock) plus even further programability  and vastly enhanced software (and includes a 2.4 spectrum monitor, which immediately picked up the two channels the Spektrum unit was transmitting on during the tests yesterday.  make set up even easier and more precise, (servo adjustment now has 4096 steps !!) There are 22 million set up possibilties    (calculated by Alwin Mueller, the designer) in an  idle moment !)  The failsafe functions, channel and servo,  are incredibly clever.
When I have had a chance to absorb and try  out the info.  I learned yesterday I will do in depth reporting for RCJI on these advanced functions which, I believe, place the new systems on a totally   different level to anything currently available.
I have never been interested in "bling"  but have always sought out the safest, most secure and reliable system for all of my models, jet or otherwise. I think I have found the nearest thing to the Holy Grail !
regards, David Gladwin.
Hide Signatures
       Post #: 9
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 4:11 PM
Gordon Mc
Score: 100
Status: offline
Sounds like a great pair of systems David / Todd ... there again, so did the much-hyped old Weatronics system until I actually started using it.
Have you guys played with it enough to know whether the Weatronics 2.4 system has totally arbitrary limitations in its programming, like the old Weatronics systems have ? (e.g. not being allowed to have output 1 and output 9 driven by the same input, etc., etc) Or have they cottoned on and allowed the true flexibility of their hardware to not be crippled by bogus programing assumptions ?
Gordon
"Facts do not cease to exist because they are ignored." - Aldous Huxley
"He who establishes his argument by noise and command shows that his reason is weak." - Michel de Montaigne
Hide Signatures
(in reply to David Gladwin)
       Post #: 10
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 6:04 PM
lov2flyrc
Score: 101
Status: offline
Gordon,
I never really found many limitaions I could not work around with the older 72mhz system, although some of the limitations did seem a arbitrary.
The new unit has rectified many of the limitations that preceded the 2.4 unit, you can now assign any servo to any channel... Even drive a single servo by multiple channels. You can gang any servo, regardless of rx port and even reverse a servo when ganged and sync'd. Still playing with the features but have yet to find a limitation period...
Click for fullsize
Hide Signatures
(in reply to Gordon Mc)
       Post #: 11
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 7:31 PM
cairoman
Score: 100
Status: offline
So, this is where Axel is hiding  and I can't get him to come to the phone and confirm my order!!!
Chris
quote:
ORIGINAL: David Gladwin
IJMC-Cyprus, JET-TRONICS' REP
WREN'S REP in Cyprus
Hide Signatures
       Post #: 12
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 8:50 PM
David Gladwin
Score: 100
Status: offline
Not quite sure what you were trying to fly if the Weatronics couldnt cope,  but the original Weatronics was much vaunted because it was/is a brilliant system,  light  years ahaead of anything else. Model equivalent of the FMCs fitted to airliners.  With   my  three receivers in three Hawks  I didn't discover any shortcomings,  but a whole raft of huge advantages , credit where its due,  so lets take a balanced view.
Having spent most of today  playing/ experimenting  with the large DR I am just amazed at its capability, withseveral  functions I would never have though of.  I think this thing could easily manage a 747 !  Just how they get so much capabaility  out of the tiny Micro is unbelievable.
Regards,
David Gladwin.
Hide Signatures
       Post #: 13
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 9:23 PM
Gordon Mc
Score: 100
Status: offline
quote:
ORIGINAL: lov2flyrc
Gordon,
That's very encouraging.
With the old system, I could not drive e.g. outputs 1 and 9 (or 17, IIRC) from the same input. The Weatronics support guy claimed it was a safety feature based on the fact that there were only 4 regulators in the unit, but when I pointed out the various flaws in their "it's a feature, not a bug" explanation, they just clammed up and stopped trying to justify the arbitrary limitations.
If I want input 1 to drive both airbrakes and lights, and I have airbrakes on output 1 and lights on output 9, there is nothing unsafe about me doing so. But, the Weatronics guys decided that I should be prohibited from doing so, and so I had to shuffle servo assignments around to split these 2 functions by a number other than 8 ... but shuffling to avoid that one clash caused another clash elsewhere, and so on & on. On my Jag, I got so tired of constantly switching the output assignments around in a desperate attempt to find some combo of output assignments that was actually blessed by the Weatronics Gods, that I eventually gave up and resorted to using a matchbox and leaving outputs unused which is a totally ridiculous thing to have to do IMO.
If the new system has overcome those pointless limitations, then maybe it's worth a closer look after all. I swore off of Weatronics after the above farce, but if they have wised up then they deserve another look.
Thanks for the info.
Gordon
Hide Signatures
       Post #: 14
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 9:33 PM
mr_matt
Score: 107
Status: offline
Will the Futaba MPDX-1 work in 12 channel Futaba PPM mode?
Matt
JetCat rep
Hide Signatures
       Post #: 15
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/16/2009 10:28 PM
jetnuno
Score: 100
Last Login: 11/7/2009
Status: offline
Hi
I have the conventional Weatronics RX and find it rock solid regarding RF link. With Futaba radios it can handle 12ch in ppm mode but the downside of this system is that it can only handle 8 proporcional channels in PCM mode and ONLY in 1024.
I am using it with a lot of internal matches and mixes in the receiver. This receiver works like a top line TX regarding servo programming and can also match servos. If you add intenal gyros and double rx with regulated power supply, you have it all for the price of a top of the line powerbox.
I was planning to change it to ppm mode to have more channels, but I am a bit affraid to fly jets in ppm mode even with the weatronics. Is any one using it in this mode?
It is very sad to me that the 2.4ghz sistem can't work in the fasst mode and as to use a big box on the top of the TX to.
Regards
Nuno
Hide Signatures
       Post #: 16
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 3:14 AM
olnico
Score: 100
Status: offline
quote:
ORIGINAL: jetnuno
Hi
Regards
Nuno
Hello Nuno,
I have 3 12-20R gyro II 35 Mhz units, all fitted in my big jets ( F-84G, F-18F, Me262, etc... ).
Because on the number of channels used ( 10 minimum ) I have gone PPM for all of these jets and logged countless hours of flight.
I find the PPM protocol actually safer than PCM with the Weatronic system. Basically the system acts like PCM ( will enter failsafe mode if the 2 RRSI values drop below noise level ) however your plane will start to "shake" before it reaches this state.
Note that this feature saved my big F-18F on the second test flight. I had the EV-5U controller placed just besides the receiver and this unit started to output much more RMIs than during the range tests. I started to see the F-18F shaking at unusual close distances and brought it back to the ground for an new range test. This subsequent test was not satisfactory anymore with reasonably high RSSI values ( which meant that the noise level or RMIs level had raised ) and it took me only a couple of minutes to identify the faulty equipment. If I would have gone PCM I would have had a failsafe condition and possibly lost the plane in the same circumstances...
The beauty of the system is that you can monitor the number of lost frames and compare it to the RSSI values. This gives you an idea of the ambient noise level. If you have a GPS, you can also identify portions of the flight volume with high RMIs by displaying the 3D view along with RSSI numbers and lost frames...
< Message edited by olnico -- 6/17/2009 2:36 PM >
Oliver
Hide Signatures
(in reply to jetnuno)
       Post #: 17
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 8:40 AM
David Gladwin
Score: 100
Status: offline
quote:
ORIGINAL: jetnuno
Regards
Nuno
Nothing sad, Nuno , its a very different system, its bi-directional with a whole host of facilities not available in FASST so if you used just faast you would lose almost all of the many advantages and facilities created by Weatronics 2.4 so I cant see the point (apart from using Fasst receivers)  The small box, a transceiver,  on the top of the TX is that size and shape because of its dual high efficiency antennae, no more long aerials as on 35/36/72.and the new antennae have  much better radiation pattern than a single rod aerial.  It is also a display unit for the LEDs which warn of any parameter outside of  preset value.  Having flown it  for quite a few flights, I just dont see it as a problem at all, just different to waht we have been used to, and actually I rather like it now, knowing the amazing  and highly valuable capabilities  which it bestows on the system, many of which we have never had available before.  ! !
Regards, David Gladwin.
Hide Signatures
       Post #: 18
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 9:30 AM
HarryC
Score: 100
Status: online
quote:
ORIGINAL: jetnuno
I can't speak for the Weatronic, but I have been flying my jets for 5 years on Multiplex PPM, never PCM, and the only problem I had was on one model due to an aerial installation problem which 2.4Ghz can suffer from too and which I have now sorted, apart from that I have had 5 years of rock solid, problem free flying of metal-coated jets on PPM!
H.
Hide Signatures
       Post #: 19
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 9:31 AM
HarryC
Score: 100
Status: online
David, Weatronic doesn't seem to want to sell its new equipment!  The website hasn't been updated for about 9 months and doesn't tell us anything that we really want or need to know about the new kit.  For example it doesn't even hint that the micro rx are programmable and it says zero about the larger rx.  In fact the website still mostly refers to the Mhz equipment.  Are they going to be bothered to actually market the stuff properly and give us information?
H
< Message edited by HarryC -- 6/17/2009 9:37 AM >
Hide Signatures
(in reply to HarryC)
       Post #: 20
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 9:56 AM
David Gladwin
Score: 100
Status: offline
I agree Harry, I know they are VERY busy finalising the larger DR and its huge manual but the site really does neead urgent update. That said, I saw a very large pile of boxes ready for collection by the shippers !
There is quite a bit of info on the new 2.4 range including the manual for the Micro (although the advanced programming needs the Giga Control software) on the USA site of Weatronic
Regards,
David Dladwin.
< Message edited by David Gladwin -- 6/17/2009 12:23 PM >
Hide Signatures
       Post #: 21
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 10:20 AM
BaldEagel
Score: 103
Status: online
quote:
ORIGINAL: mr_matt
Matt
The MPDX-1's will only work with the 14MZ Tx.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 22
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 12:44 PM
Roger M
Score: 100
Status: offline
Does anyone have any up to date pictures of the Weatronic aerial installation on a non - tray style Tx and in particular how the connection is made between the aerial and the Tx pcb? Do they use an external coax like the Spektrum module system, or have they routed the cable internally?
Roger
Hide Signatures
       Post #: 23
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 12:49 PM
David Gladwin
Score: 100
Status: offline
The manual which shows exactly that on a range of transmitters is all on the Weatronic USA web site.
Regards,
 DG.
Hide Signatures
(in reply to Roger M)
       Post #: 24
RE: 2.4 GHz Weatronics, PPM or PCM? - 6/17/2009 1:02 PM
Roger M
Score: 100
Status: offline
Thanks David.
It certainly looks as though they have thought about the Tx installation.
Roger
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.155RCU1
