funky servos
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> funky servos
Page: [1]
Login
funky servos - 6/11/2009 11:55 PM
hawkman-RCU
Score: 100
Last Login: 11/8/2009
Status: offline
hi all.
i have 2 hs81 servos that buzz and when you use the stick,say 1/2 rudde it will move by it self.been in no crash and are like new.about 5minutes total use on them.
        thank you.
Hide Signatures
       Post #: 1
RE: funky servos - 6/12/2009 4:53 PM
whitecrest
Score: 100
Status: offline
quote:
ORIGINAL: hawkman-RCU
hi all.
thank you.
I'd check your linkages for binding. Try disconnecting the pushrods entirely and see if the buzzing continues. Also, check the receiver voltage supplied by the BEC. It should measure about 5 volts and should not vary as the servos are exercised. If you connect an ammeter between your battery and the ESC, you can measure the current demanded by all the electronics if you don't throttle the motor. You should be able to observe a very low resting current (perhaps 40 - 90 ma) which will spike up to perhaps 150 - 300 ma as the servos are exercised. If you see a lot more than that, something is probably overloaded. I wouldn't attempt flight until any erratic servo operation is resolved.
_____________________________
Tim
Hide Signatures
(in reply to hawkman-RCU)
       Post #: 2
RE: funky servos - 6/13/2009 1:39 AM
hawkman-RCU
Score: 100
Status: offline
hey whitecrest.
thanks for your reply.
                                                 i have heard that the hitec hs81 servos act this way.
Hide Signatures
(in reply to whitecrest)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
