2S A123 1100mah safe charge rate?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> 2S A123 1100mah safe charge rate?
Page: [1]
Login
2S A123 1100mah safe charge rate? - 6/12/2009 1:17 AM
dubluv
Score: 100
Last Login: 11/6/2009
Status: offline
What's the safest maximum rate I can charge a 2s A123 1100mah pack?
Hide Signatures
       Post #: 1
RE: 2S A123 1100mah safe charge rate? - 6/13/2009 4:04 PM
soarhead-RCU
Score: 100
Last Login: 11/7/2009
Status: offline
Can't give you the max rate, but I charge mine all the time at 3 amps which is max for my charger...Seem's like I read on another forum of people chargeing them at 5 amps though.  Mine have been a excellent product, I use them as RX power (2S) and motor power (4S), many cycles and zero problems in almost 2 yrs of use........
Bob
Hide Signatures
(in reply to dubluv)
       Post #: 2
RE: 2S A123 1100mah safe charge rate? - 7/4/2009 7:27 PM
juanjulian
Score: 100
Last Login: 10/25/2009
Status: offline
This info is from Radical Rc
_______________________________________
Specifications:
Nominal voltage 3.3V
Nominal capacity 1.1Ah
Dimensions 18mm(0.72") dia. x 65mm(2.5") ht.
Cell weight 39g/1.4oz.
Cell charging parameters: CC-CV (constant current - constant voltage)
Recommended charge current: 3A
Recommended charge voltage: 3.6V
Recommended float charge and storage voltage: 3.45V
Recommended cut-off current for CV hold: 0.05A
Maximum continuous charge current: 10A
Maximum allowable charge voltage: 4.2V MAX
Fast charge time: 15 minutes
Cell discharging parameters:
Recommended discharge cut-off voltage: 2.0V
Maximum continuous discharge current: 60A
Cell temperature parameters (skin temperature)
Maximum recommended cell temperature 158F)
Maximum allowable cell temperature: (185F)
So the recomended charge is 3 amp but you can go all the way to 10 amp, more than many chargers can handle.
cheers,
Juan
Hide Signatures
(in reply to soarhead-RCU)
       Post #: 3
RE: 2S A123 1100mah safe charge rate? - 7/6/2009 11:30 PM
nick_cool
Score: 100
Last Login: 10/23/2009
Status: offline
2,5A should be ok, I have been charging my 2300ma A123 at 6A for a year without problems
Hide Signatures
(in reply to juanjulian)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
