Homelite 33cc    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Homelite 33cc
Page: [1] 2   next >   >>
Login
Homelite 33cc - 6/13/2009 10:22 AM
av8tor1977
Score: 665
Last Login: 6/19/2013
Status: offline
Could someone post some pics of the commonly converted Homelite 33cc engine, along with some prop/rpm numbers??  I scored a Homelite 33cc engine the other day, but I think it is different from the ones usually converted.
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 1
RE: Homelite 33cc - 6/14/2009 1:59 AM
flyguyeddy
Score: 100
Last Login: 6/12/2013
Status: offline
post up a picture of it!
mine looks like the 45cc homey and the poulan saws, but it has a weedeater style mount on the bottom crankcase half.  im going to go ahead and use it cause i'd rather not use beam mounts if i have an already made radial mount solution.
Hide Signatures
(in reply to av8tor1977)
       Post #: 2
RE: Homelite 33cc - 6/14/2009 5:45 AM
combatpilot
Score: 100
Last Login: 6/14/2010
Status: offline
Post a picture of it.  I am wondering how it compares to the poulan 32 cc which i have 3 of and am considering using that for my next project.
Hide Signatures
(in reply to flyguyeddy)
       Post #: 3
RE: Homelite 33cc - 6/14/2009 5:49 AM
J-3
Score: 100
Last Login: 4/24/2013
Status: offline
I have a Homelite 33cc I took out of a reconditioned chainsaw. I will look for my camera and post a few pictures tomorrow morning....Brian
Photos: The only mod done so far is to cut off the aft side crank shaft that sticks out.
33cc, 2.0-cu.-in. PowerStroke™ engine
Bandit 33cc 14" Chain Saw ZR10901 (UT10901)
Power Stroke Engine
Cummins Industrial Tools Number 6101 $79.99
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by J-3 -- 6/14/2009 7:04 PM >
Hide Signatures
       Post #: 4
RE: Homelite 33cc - 6/15/2009 8:30 AM
KI8FR
Score: 100
Last Login: 11/22/2011
Status: offline
i can see if i can get some pics of mine.  i will have to take off my cowl to do it.
This is on of the best egnines i have done.  mine terns a 18X8 prop at 8200.  i have mine on CH Igniton.
Paul
Hide Signatures
(in reply to J-3)
       Post #: 5
RE: Homelite 33cc - 6/15/2009 9:54 AM
av8tor1977
Score: 665
Status: offline
Thanks for the pics.  Mine is different.  I'll try to get some pics of it posted tomorrow.
AV8TOR
Hide Signatures
(in reply to KI8FR)
       Post #: 6
RE: Homelite 33cc - 6/15/2009 11:20 AM
av8tor1977
Score: 665
Status: offline
Yeah, mine is different.  It has a differently shaped cylinder and the carb manifold is a spigot type mount.  I will have to make a manifold for it.  The engine seems a bit heavy too, at a tad over 3 lbs. without muffler, magneto or prop adapter, but with the carb.  It will lose a few ounces however, when I cut off the original oil pump and use shorter crankcase screws....
Here's a couple of pics.
AV8TOR
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Homelite 33cc - 6/15/2009 5:45 PM
flyguyeddy
Score: 100
Status: offline
are you going to turn a bunch of those fins off?  i dont know if i want to do much cutting on mine but it sure has alot of fin area that probably isnt needed on an airplane
Hide Signatures
       Post #: 8
RE: Homelite 33cc - 6/15/2009 7:42 PM
av8tor1977
Score: 665
Status: offline
Yeah, I've thought of cutting those fins down some.
AV8TOR
Hide Signatures
       Post #: 9
RE: Homelite 33cc - 6/15/2009 9:07 PM
Team_Monkey
Score: 100
Last Login: 6/14/2013
Status: offline
I did a 33cc Ranger saw from Depot last year. What Vintage is your saw? It is very different
Here were my initial numbers posted on another site of the first runs using a MAS classic 18x8:
She'll idle happliy along at 13000-1400RPM and I had 8300 RPM at WOT once, but can't get it back since I improved the mid range (tiny bit it did improve) but it will do a consistent 7700 rpm @ WOT.
I can't check the link from work but here's the old link to the walk around. About 1:30 intro and description of the bits.
http://media.putfile.com/Walk-around-of-converted-homelite-33
- In the vid I say "Hayes is ready to go for the glow" of course I meant gas, sorry.
Last time I checked they had another one but do I need another saw engine?
Hide Signatures
       Post #: 10
RE: Homelite 33cc - 6/15/2009 9:57 PM
av8tor1977
Score: 665
Status: offline
The decal on the engine says "Displacement 33cc Family 6HCPS.0338AA and the Homelite number is UT-10532, serial number ATJ2171262 and has a date of 08-05-06.
So the question is, what year(s) are the better 33cc engines?  Newer or older?  I was hoping mine was going to be like "J-3's" pictures.
AV8TOR
Hide Signatures
(in reply to Team_Monkey)
       Post #: 11
RE: Homelite 33cc - 6/16/2009 2:23 AM
captinjohn
Score: 247
Last Login: 6/20/2013
Status: offline
quote:
ORIGINAL: KI8FR
Paul
Paul...did you weigh your 33cc engine?  Seems like real good RPM TOO!!!   Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to KI8FR)
       Post #: 12
RE: Homelite 33cc - 6/16/2009 3:43 AM
flygilmore
Score: 131
Last Login: 5/16/2013
Status: offline
The 33cc Powerstroke engines from the Ranger and Bandit saws are the very best in this size range period!!!!!!  I have done a couple myself and they are true powerhouses!!  I run mine on the stock mag. ignition and can hand start them very, very easy....just have to know the right technique.  Mine will turn a Xoar 18x6 @8800+ and the Xoar has a pretty good load compared to most "cheaper" props.
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
(in reply to captinjohn)
       Post #: 13
RE: Homelite 33cc - 6/16/2009 7:07 AM
KI8FR
Score: 100
Status: offline
no i did not. i do know that it is less then my Quadra 35. i do have one here that is not done yet.  i can put all the part on a scall and see what it comes out as.
The last time i did a RPM run i got 8200 with a 18X6 prop.  but that was with the old mufler.  i made one last year and did not do a RPM check.
So i did one to day with the mufler i made.  The RPM came out to be 8652.   not bad at all.
Paul
Hide Signatures
(in reply to flygilmore)
       Post #: 14
RE: Homelite 33cc - 6/16/2009 8:10 AM
combatpilot
Score: 100
Status: offline
Wow all stripped down it looks to be a pretty sharp engine.  With the performane numbers you guys are getting out of them it makes me mad im so damn broke or i would go get one of these.  Maybee i will get luck and find one in the recycle bin at the lawnmower shop.
What size carb are you guys using to get the 8200 rpm on an 18-8 prop?
Hide Signatures
(in reply to KI8FR)
       Post #: 15
RE: Homelite 33cc - 6/16/2009 8:14 AM
KI8FR
Score: 100
Status: offline
i got my egnine out of a dump at the saw shop.  i got the ring for 13 bucks from ring master.  The prop hub i took off of a old quadra.(it fits)
I ran the stock carb.  It had a 28 in the carb. not sure one what carb it is.
Paul
Hide Signatures
(in reply to combatpilot)
       Post #: 16
RE: Homelite 33cc - 6/16/2009 8:57 AM
av8tor1977
Score: 665
Status: offline
"28" in the carb throat means a venturi size of 28/64".  64 divided by 28 equals .4375".  .4375" x 25.4 equals a venturi size of  11.11 mm.  It is an 11mm carb.  It would probably run a bit better with a 12.7mm carb, which would have a "32" casting number in the carb throat.  This would especially be true if you are running a smaller prop.  If you want to run as large a prop as possible for your application, it might do just as well with the 11mm carb, but only experimentation would tell....  I suspect the 12.7 carb would be better for most applications.
AV8TOR
< Message edited by av8tor1977 -- 6/16/2009 8:58 AM >
Hide Signatures
(in reply to KI8FR)
       Post #: 17
RE: Homelite 33cc - 6/16/2009 7:44 PM
combatpilot
Score: 100
Status: offline
Avi8tor i think it was you that told me tht the number in the venturi of a carb is the venturi size in 64ths.  Man I got to thank you for that.  it makes carb identification so easy.
I dont come across many chain saw engines at the engine shop bin.  i did score a 46 cc tht im hanging onto lol.  I do hope i can get lucky like you and score one of these.  i really like how they have the carb on the side.   the ryobis are such a pain with them on the rear.
Hide Signatures
       Post #: 18
RE: Homelite 33cc - 6/16/2009 10:00 PM
av8tor1977
Score: 665
Status: offline
I have pretty good access to engines.  If you want, I'll sell you my Homelite 33cc for 30 bucks plus shipping.  The piston, cylinder, and rings look like new.
AV8TOR
< Message edited by av8tor1977 -- 6/16/2009 10:02 PM >
Hide Signatures
       Post #: 19
RE: Homelite 33cc - 6/16/2009 11:25 PM
combatpilot
Score: 100
Status: offline
Man i would love to do that but if i had to write you a check for that amount right now it would bounce lol.  Im that bad off at the moment.
Hide Signatures
       Post #: 20
RE: Homelite 33cc - 6/17/2009 6:35 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: flygilmore
Thanks gilmore...I am going to be looking for one of the 33 cc like you talk about!   Capt,n
Hide Signatures
       Post #: 21
RE: Homelite 33cc - 6/17/2009 11:30 PM
av8tor1977
Score: 665
Status: offline
This one I have will make a good (and easy) conversion engine; but I have a bunch of engines.  If anyone wants it for $30.00 plus actual shipping cost, just PM me.  As I mentioned, it is like new inside, with no carbon and no evident wear.
AV8TOR
Hide Signatures
       Post #: 22
RE: Homelite 33cc - 7/7/2009 4:10 AM
ScaleNVYflyr
Score: 100
Last Login: 6/19/2010
Status: offline
Help .. I Have a 33 cc conversion (from a chain saw) that I've done. The engine ran before I took it apart but now with it all together and mounted on the plane I can get it even to burb.. It has a blue spark.. but I'm not sure its getting fuel, but I don't have much experience with these engines. I've turned it over with a drill @ 2500 rpm both directions counter and clockwise and it wont even try to fire.
I'm wondering if I screwed up the compression somehow, turning it over by hand with a 18" prop on it doesn't take any effort. I feel kinda dumb, these things are suppose to be fool proof.
Any help or advice will be appreciated.
Derek
Click for fullsize
Click for fullsize
< Message edited by ScaleNVYflyr -- 7/7/2009 4:12 AM >
Fly it like a rental
Hide Signatures
       Post #: 23
RE: Homelite 33cc - 7/7/2009 5:07 AM
rangerfredbob
Score: 115
Last Login: 6/15/2013
Status: offline
first, did you happen to rotate the carb 180*? if so, you might not have the pulse hole in the carb lined up anymore, I've had that problem before.
second, I see that's not a final setup since the plane isn't covered, but that silicone line isn't going to live more than a few minutes with gas in it.
there's a possibility that the fuel lines are backwards, I don't remember off the top of my head.
Hide Signatures
(in reply to ScaleNVYflyr)
       Post #: 24
RE: Homelite 33cc - 7/7/2009 5:23 AM
captinjohn
Score: 247
Status: offline
I see 2 wires that go to maybe the coil...try to see if you get spark when you unhook them. Turn the engine over fast as you can with sparkplug on engine so you can see if it has spark. I 2nd changing the glow fuel line ot a gas line to carb. Best Regards Capt,n
< Message edited by captinjohn -- 7/7/2009 5:24 AM >
Hide Signatures
(in reply to rangerfredbob)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Homelite 33cc
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.234RCU1
