RE: OFFICIAL 1/16 VXL Slash thread.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: OFFICIAL 1/16 VXL Slash thread.
Page: <<   < prev  6 7 8 9 10 11 12 13 [14] 15   next >   >>
Login
RE: OFFICIAL 1/16 VXL Slash thread. - 1/14/2011 4:42 AM
Lurp06x
Score: 101
Last Login: 3/1/2011
Status: offline
well if anyone cares or not but i have had my mini slash vxl for over a year now and just fixing everything that has loosened up or needs to be replaced. well first thing that i am replacing is the tires. the two rear are bald out, and one of the front tires shredded apart. then theres the body. the rear part where you put the body clips in have been ripped and cracked to heck. plus other various cracks and dings through out the body. need to replace the axle carriers on all four sides, they are a bit loose from wear and tear, plus the push rods and toe links need to be replaced from wear and tear too. i got alum. toe links because they were the worst so in the futur i would only need to replace the ends, the push rods werent too bad so i just got stock ones to replace. i am replacing the the front upper and lower a-arms, they arent broken or cracked they are just worn down so much on the outside from srcapping the ground that any more abuse could mean a wreck. also the front skip plate needs to be replaced it is scrapped and worn out plus a little bent out of place i lost a suspension pin because of how bad of condition of the front skid plate is in. i am getting pivot balls too for the heck of it.
other wise before this i have replaced the servo on it with a hitec micro servo or something of hitec cant remember an too lazy to look. i have had to replace the back bumper. the thing i have replaced the most probably replaced this part about 5 times is the front body mount. the part that breaks on them is the front of them were they attach to the front bumper. it always cracks or breaks apart at that spot.
otherwise this is still my favorite rc i have so far. my blitz is haveing ball cup issuses, my jammin x1 is sitting in pieces and needs to be worked over. and my stampede looks like a hack job of various electrontics slapped on it and the axle carriers and ball barrings need to be replaced badly on it.
sorry i didnt post any pics i dont have a camera
Hide Signatures
(in reply to t9dragon)
       Post #: 326
RE: OFFICIAL 1/16 VXL Slash thread. - 1/25/2011 4:31 PM
domizgood
Score: 100
Last Login: 3/27/2013
Status: offline
hi guys
iv started a new thread called OFFICIAL MINI BLING CAR THREAD its purly about blinging up your cars so feel free to post any pics and vids
cheers dom
_____________________________
SCREW NITRO..........GO LIPO!!!!!!!
I HATE PLANKING.
Hide Signatures
(in reply to Lurp06x)
       Post #: 327
RE: OFFICIAL 1/16 VXL Slash thread. - 1/26/2011 2:48 PM
slashobob
Score: 100
Last Login: 8/23/2011
Status: offline
well sorry it took me so long my cpu broke and lost my job but to run on road you can use zipties to limit suspension travel  and take all of the preload out of you shocks or do what i did was put a 3mm piece of nitro fuel line inside the shock house and use thicker  shock oil and a good set of on road tires like hpi sedan rims and foams,and scruffed up drift tires most are 12 mm hex and easily fit
Hide Signatures
(in reply to slash116vxl)
       Post #: 328
RE: OFFICIAL 1/16 VXL Slash thread. - 2/14/2011 6:06 PM
NitroNuisance
Score: 100
Last Login: 9/27/2011
Status: offline
Sorry if this has already been talked about but I don't wanna read this whole thread.lol Has anybody found any aftermarket rear bumpers with mudflaps? I like the way they look on like the sc18 and other sc trucks. They look more scale
T-Maxx 2.5, Mamba Maxed 5700 Rustler, Nitro Rustler 2.5, Losi XXX-NT, DTX Maximum ST Pro, losi Mini-t, Mini-v, Supervee 27.
Hide Signatures
       Post #: 329
RE: OFFICIAL 1/16 VXL Slash thread. - 2/15/2011 2:23 AM
NitroNuisance
Score: 100
Status: offline
Does anybody know if the futaba 3pl reciever R2004GF will fit in the rx box? Or does anyone know the dimentions of the rx box? The RX is (39 x 26 x 10mm)
My mini slash will be here Wed and my 3pl will be here like thursday.
Hide Signatures
(in reply to dacaur)
       Post #: 330
RE: OFFICIAL 1/16 VXL Slash thread. - 2/17/2011 3:24 PM
NitroNuisance
Score: 100
Status: offline
quote:
ORIGINAL: Foam Crazy
... and here is one more set of images. these just arrived. the wheels and tires are HPI nitro off-road types with matching 12mm hex mount parts. as you can see, the wheels are diameter sized somewhere in between the slash and erevo wheels dimensions and the width too is somewhere in between.
i haven't glued them in yet, as they are a pretty tight fit. i'm going to run them unglued and see if that might work okay for bashing.
the grey wheel is also the same type of wheels and only different in the way it looks.
Cool, I like the way those black wheels look and the lifted body actually does look pretty good also with those big wheels.I however am going in the other direction. I want to tighten up my suspension and lower it a bit. Do they make road tires for those wheels though? I really like the size and look of them and want a pair with some low profile tires. Also I read that u put the 3pm in yours. How did the reciever fit? I just ordered a 3pl and am hoping I can get the reciever in the rx box so I don't have to get rid of it and use a baloon. I can't find the specs for the origional rx or the rx box anywhere? My radio is suppose to be in the mail today but I just can't wait to see if it will fit.lol
i'm using the wheel wideners on this setup. gonna run em tomorrow and will let you guys know how it works...
Hide Signatures
(in reply to Foam Crazy)
       Post #: 331
RE: OFFICIAL 1/16 VXL Slash thread. - 2/17/2011 5:10 PM
BigTb17
Score: 136
Last Login: 9/23/2012
Status: offline
quote:
ORIGINAL: NitroNuisance
It will probably be a tight fit, but I think it will work. I recently bought a Brushed Mini Summit, which I believe has the same radio box with a slighly shorter cover to allow room for the larger 550 Titan motor. My receiver is listed as 41 x 27 x 15 and it fit. Just barely, and I had to make a tiny modification to the inside of the cover, but your cover should be a tad bigger, and your receiver is a bit smaller, so I would think it will work.
Hide Signatures
(in reply to NitroNuisance)
       Post #: 332
RE: OFFICIAL 1/16 VXL Slash thread. - 2/17/2011 6:12 PM
NitroNuisance
Score: 100
Status: offline
Great news and thanx for your help.
Hide Signatures
(in reply to BigTb17)
       Post #: 333
RE: OFFICIAL 1/16 VXL Slash thread. - 2/17/2011 9:25 PM
NitroNuisance
Score: 100
Status: offline
2 more ?'s anyone tried putting a revo wing on the slash for speed runs on a road setup? Also does anyone know an any higher torque metal gear servo's that will drop right in?
Hide Signatures
       Post #: 334
RE: OFFICIAL 1/16 VXL Slash thread. - 2/20/2011 7:12 PM
Lurp06x
Score: 101
Status: offline
people have put revo wings on before i think all you have to do is some trimming of the body.
with the servo i think hitec has a few that will drop in i have an hs-81 in mine right now and its working fine
Hide Signatures
       Post #: 335
RE: OFFICIAL 1/16 VXL Slash thread. - 2/20/2011 9:26 PM
NitroNuisance
Score: 100
Status: offline
ok cool. I just got my vxl slash in the mail on Wed along with 2 3s lipo's and I have to say this thing is a blast! I love it. I was a little worried about it sucking after reading all the posts on here of people complaining about how unstable it is but with a little dual rate adjustment to turn down stearing sensitivity on my new futaba 3PL radio it's awesome. Sure if you crank the wheel when ur wide open it's going to flip but you have to take into consideration that this thing is doing like 960 mph scaled down at wide open throttle on 3s or 12 ni/mh cells. I have no problems keeping it shiny side up. Now my question is will the esc handle the 2-2s lipo's I ordered running in series as 4s? It handles 3s with the stock gearing easily without anything getting barely warm. And I know it handles 2 ni/mh packs so I'm thinking it should be ok? Anybody else running 4s?
< Message edited by NitroNuisance -- 2/21/2011 1:26 AM >
Hide Signatures
       Post #: 336
RE: OFFICIAL 1/16 VXL Slash thread. - 11/2/2011 6:43 PM
350TacoZilla
Score: 100
Last Login: 1/1/2012
Status: offline
you guys are asking alot the same questions I have so i thought I would chime in..
anyone ever try the losi 1/18th buggy tires? i cant find the size listed anywhere for them other than their width (28mm rear 20mm front)
saw where driven products said they used 1/18th losi paddles
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 337
RE: OFFICIAL 1/16 VXL Slash thread. - 11/2/2011 7:07 PM
t9dragon
Score: 328
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: 350TacoZilla
The 1/18 Losi wheels and tires are to small for the Slash.
Hide Signatures
(in reply to 350TacoZilla)
       Post #: 338
RE: OFFICIAL 1/16 VXL Slash thread. - 11/6/2011 10:29 AM
itsfishi
Score: 105
Last Login: 5/20/2013
Status: offline
hey guys mine dont work on 4s,
dont know if you know or not but 2200mah nanotech 25-50c batts fit better than turnigy or zippy 2200 batts. dont know who does the measuring at HK but someone should tell em to get a new tape. hope this helps.(still have to cut door for wires)
Hide Signatures
       Post #: 339
RE: OFFICIAL 1/16 VXL Slash thread. - 11/7/2011 4:57 PM
9five9
Score: 137
Last Login: 5/10/2013
Status: offline
Have you run it with that setup yet?
Thinking outside the box of traditional RC
Hide Signatures
(in reply to itsfishi)
       Post #: 340
RE: OFFICIAL 1/16 VXL Slash thread. - 11/7/2011 5:50 PM
t9dragon
Score: 328
Status: offline
quote:
ORIGINAL: itsfishi
What do you mean? "dont work on 4s"
When I had my mini slash/revo, I cut open the rear vents and ran the wires through there because otherwise they rub on the wheels.
Hide Signatures
       Post #: 341
RE: OFFICIAL 1/16 VXL Slash thread. - 11/7/2011 9:16 PM
itsfishi
Score: 105
Status: offline
nitronuisance asked if could run 2 2s in series so 4s i tried on mine but esc would not arm. admittedly i have not read the manual or anything just tried hooking the batts up. let me know if it can be done, just wanted a laugh not to run it like that all the time.
Hide Signatures
       Post #: 342
RE: OFFICIAL 1/16 VXL Slash thread. - 11/16/2011 3:36 AM
9five9
Score: 137
Status: offline
Just bombed through a bunch of snow with the mini slash. This is what I bought the truck for,and it's putting more smiles on my face than any other vehicle has. The truck works amazing on hard packed snow. The stock tires have just enough traction to get the truck moving, but enough slip to allow the truck to drift perfectly anywhere I want it to. As we get more snow, I'll be making a backyard short course snow track for the truck,and I'll be making lots of videos.
Hide Signatures
       Post #: 343
RE: OFFICIAL 1/16 VXL Slash thread. - 9/28/2012 3:00 AM
hound54
Score: 105
Last Login: 5/11/2013
Status: offline
been almost a year since the last thread in here
anyways
just ordered a losi mini late model body for my slash
also ordered a hitec hs 82 servo
i`ll post when im done
2 slash''s 1 has the outlaw lcg the other xtreme racing lcg,venom 3300 kv and esc.vxl 4x4 stampede,mini summit,and mini e re
Hide Signatures
(in reply to 9five9)
       Post #: 344
RE: OFFICIAL 1/16 VXL Slash thread. - 9/28/2012 5:32 PM
9five9
Score: 137
Status: offline
I'm curious to see how that looks. What tires will you be running with that body? With the right setup, that could be really cool on a dirt oval track! Post pics.
BTW thanks for dusting this thread off. I just realized I was the last poster before you. We didn't end up getting enough snow all last winter to make the snow track I was wanting to make. Hopefully we get some snow this year.
I wanna see some more mini slashes out there ripping it up. With the right set up and a little practice, these trucks stinking fly.
Hide Signatures
(in reply to hound54)
       Post #: 345
RE: OFFICIAL 1/16 VXL Slash thread. - 10/2/2012 1:47 AM
hound54
Score: 105
Status: offline
The losi body fit like it was made for it
I'm on my iPad o I can't post a pic I'll get one up later
Hide Signatures
       Post #: 346
RE: OFFICIAL 1/16 VXL Slash thread. - 10/5/2012 5:10 AM
9five9
Score: 137
Status: offline
do you run on dirt ovals much? I'd give that a try.
Hide Signatures
       Post #: 347
RE: OFFICIAL 1/16 VXL Slash thread. - 10/11/2012 5:31 PM
trx1
Score: 123
Status: offline
I just got a mini slash vxl. got a new servo and body on it.
will post pics sooon
< Message edited by trx1 -- 10/12/2012 6:35 PM >
micro high roller,
1 indoor fun truck
Hide Signatures
       Post #: 348
RE: OFFICIAL 1/16 VXL Slash thread. - 10/13/2012 5:42 PM
trx1
Score: 123
Status: offline
what parts(if any) should be aluminum on the mini slash??
link to said items
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=mini+slash&_pgn=7&_skc=300&rt=nc
micro high roller,
1 indoor fun truck
Hide Signatures
(in reply to trx1)
       Post #: 349
RE: OFFICIAL 1/16 VXL Slash thread. - 10/13/2012 5:59 PM
9five9
Score: 137
Status: offline
quote:
ORIGINAL: trx1
link to said items
In my opinion, you want as many flexible parts as possible on the mini slash. I've had mine cartwheel down the street several times (accidentally of course), and the two battery covers are the only things that have broke on mine. with those kinds of crashes that the truck is capable of, I'm afraid metal is going to bend like crazy. also, plastic will absorb impacts. metal parts that don't bend won't absorb impact, thus stressing connected plastic parts even worse.
That's my two cents. I've had the truck for a year now, and drive it as hard as ever. The thing is extremely powerful, and once you learn to harness the power with the right driving and set up, it's an absolute blast to run.
If you do go with any metal parts, keep this thread updated with how they work out. I could be wrong.
Hide Signatures
(in reply to trx1)
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.297RCU1
