RE: OFFICIAL 1/16 VXL Slash thread.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: OFFICIAL 1/16 VXL Slash thread. Page: <<   < prev  6 7 8 [9] 10 11 12 13 14 15   next >   >>
Login
RE: OFFICIAL 1/16 VXL Slash thread. - 1/15/2010 12:48 AM
Ttam Says Blarg
Score: 186
Last Login: 5/19/2013
Status: offline
^ I know just not willling to drop 120 on a new esc and motor.
Finally got a response from RPM about parts for the slash.
"Dear Matt,
Unfortunately, there aren't any plans for 1/16th scale Slash a-arms just yet (they aren't the same as those found on the Mini E-Revo). We're using the Mini E-Revo a-arms as a feeler to see if the 1/16th scale market is strong enough to support a line of RPM products. Please give us some time to see how the market holds up and if it does well, I'm sure you'll see quite a number of new parts in 1/16th scale from RPM in the not too distant future.
Take care and thank you for your interest and support of RPM products. If you have any other questions or comments, please feel free to send us another e-mail."
_____________________________
Aint nothin but a thang
Slash 1/16 - DB-01 - TT-01 - RC18B and a Super Cub!
Hide Signatures
(in reply to t9dragon)
       Post #: 201
RE: OFFICIAL 1/16 VXL Slash thread. - 1/15/2010 4:08 AM
patatchim
Score: 100
Last Login: 6/16/2011
Status: offline
Hope they do parts for them soon. Although the car seem pretty resistant to hard bashing!
I have currently all my cars in the shelf, only using the slash!
It is quite awesome. Looks like a real truck and it seems like a real car when driving.
Kind like the need to reduce throttle input so the car won´t flip when hard turning.
hk-t500;Mini titan;mosquito | 1/16 slash brushed ; wheely king | in the shelf: Tl-01b;Rc18b ;Xray m18mt;
Hide Signatures
(in reply to Ttam Says Blarg)
       Post #: 202
RE: OFFICIAL 1/16 VXL Slash thread. - 1/15/2010 5:29 PM
Lurp06x
Score: 101
Last Login: 3/1/2011
Status: offline
i bent my slipper pin and also ripped off my front body mount . broke the third one . but my question is how do you bend the slipper pin when its buried in the the middle of the chassis an has a receiver box an motor protection it on both sides.
Hide Signatures
(in reply to patatchim)
       Post #: 203
RE: OFFICIAL 1/16 VXL Slash thread. - 1/16/2010 2:19 AM
008
Score: 100
Last Login: 1/17/2013
Status: offline
I hear you ... we need a tire selection for this truck.
Hide Signatures
(in reply to BuzzBomber)
       Post #: 204
RE: OFFICIAL 1/16 VXL Slash thread. - 1/16/2010 3:50 AM
Lurp06x
Score: 101
Status: offline
Yes agree tire selection for the mini slash would be nice. i think that the main reason why this thread is so dead. at first when the mini slash came out it was all the rage, but since the merv an no hops or new bodies or tires have come out for the mini slash its kind of a downer an makes people want to find something else were they can continue to drive an build up there rc. but the mini slash so far is just a stock rc an thats all you can do for it except put Aluminum parts on an up grade the battery an charger.
Hide Signatures
(in reply to 008)
       Post #: 205
RE: OFFICIAL 1/16 VXL Slash thread. - 1/16/2010 10:31 PM
Ttam Says Blarg
Score: 186
Status: offline
I thought that this truck would have way more support behind it.
Hide Signatures
(in reply to Lurp06x)
       Post #: 206
RE: OFFICIAL 1/16 VXL Slash thread. - 1/17/2010 6:22 PM
combatman
Score: 100
Last Login: 2/23/2013
Status: offline
Has anyone tried applying thin CA glue to the sidewall and part of the outer tread of the front tires to reduce traction roll? This is a trick used by carpet racers to avoid traction roll. So, the parts of the tires with CA will be hard and smooth, and the front end of the truck will "push" through the turns a little instead of grip the road, thereby preventing traction roll. How far along the outside edge you would need to apply CA glue, and not completely lose steering, requires some experimentation...
My video channel for RC tutorials:
http://www.youtube.com/user/LowBudgetRC?feature=mhee
Hide Signatures
       Post #: 207
RE: OFFICIAL 1/16 VXL Slash thread. - 1/17/2010 8:05 PM
srt10
Score: 318
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: combatman
Has anyone tried applying thin CA glue to the sidewall and part of the outer tread of the front tires to reduce traction roll? This is a trick used by carpet racers to avoid traction roll. So, the parts of the tires with CA will be hard and smooth, and the front end of the truck will ''push'' through the turns a little instead of grip the road, thereby preventing traction roll. How far along the outside edge you would need to apply CA glue, and not completely lose steering, requires some experimentation...
most CA glue will crack and flake off with rubber tires.. if your talking the stock tires
CAing foams on a short side wall will help for a race and also it can wick into the foam vs rubber for a better bond
this would help with foams on the mini
first to own the Mini Slash!
Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
Hide Signatures
(in reply to combatman)
       Post #: 208
RE: OFFICIAL 1/16 VXL Slash thread. - 1/17/2010 8:41 PM
BuzzBomber
Score: 100
Last Login: 12/17/2012
Status: offline
I just tape the tires instead. Cut a length of electrical tape long enough to go around the tire and have a little overlap, then lay it on a sheet of glass and slice it down the middle so it's 1/2 width. Then wrap the outer edges of the tires with this, seems to be just about the right balance so that you can slide without traction rolling, yet not turn it into a drifter.
Matt Smith
If you''re not having fun, you''re missing the point.
Hide Signatures
(in reply to srt10)
       Post #: 209
RE: OFFICIAL 1/16 VXL Slash thread. - 1/17/2010 10:35 PM
combatman
Score: 100
Status: offline
I've used CA on rubber tires before, and it lasted for a few weeks. I wonder if anyone tried either the CA or tape on the stock tires when racing their 1/16 Slash on carpet.
Hide Signatures
       Post #: 210
RE: OFFICIAL 1/16 VXL Slash thread. - 1/18/2010 11:19 PM
BuzzBomber
Score: 100
Status: offline
quote:
ORIGINAL: combatman
That's where I was running my slash with the taped tires last weekend. In between the heats, I was goofing off with that truck on the carpet oval track.
Matt Smith
Hide Signatures
       Post #: 211
RE: OFFICIAL 1/16 VXL Slash thread. - 1/19/2010 7:20 AM
Gyronator
Score: 100
Last Login: 10/10/2010
Status: offline
Guys just bought some down stops the other day and was wondering how to install them. Packet came with these http://www.horizonhobby.com/ProdInfo/ASC/100/ASC6466-100.jpg 8 smaller/shorter ones clear ones. Dont know witch one goes in what order and how many to put in each shock.
Hide Signatures
       Post #: 212
RE: OFFICIAL 1/16 VXL Slash thread. - 1/19/2010 8:58 PM
katzcratch
Score: 100
Last Login: 8/31/2011
Status: offline
I changed the pinon on the slash for the series connector..now its raining of course
Why dont all compaines make their system like traxxas. that motor fits so nicely against the spur, and the boolt on the pinion is fat...and the motor shaft has a flat spot!!
I raced some skateboarders down a steep hill, it crushes them but I kept running into the curb...
Hide Signatures
(in reply to Gyronator)
       Post #: 213
RE: OFFICIAL 1/16 VXL Slash thread. - 1/20/2010 6:59 AM
Foam Crazy
Score: 100
Last Login: 3/14/2012
Status: offline
alright guys. i am definitely agreeing with you all here, in saying that the mini slash needs more wheel and tire options.
i just came back from testing a set of hpi 2.2" wheels with 6mm offset, paired with traxxas mini erevo tires. while this combo gets rid of the tires rubbing on the frame, due to the 6mm offset, mounting the wheel to the axle is not as secure. i bearly run out of axle thread when mounting these wheels, and i wish i could turn 2 more times to be absolutely secure. and, while it works for short burst runs and general bashing, the tire to wheel is not a perfect match, and can wobble after a while. as the wheels are failry exposed, they do get scuffed up pretty badly in short order. net net, i would not recommend this direction.
added a couple more tweak mods to my mini slash.
- turned the bent AM receiver antennae tube to face forward (this antennae setup works great, as it hides under the body, and still gets good radio reception.)
- added small nylon washers to keep the body from rattling so much
oh, and i have one more mod, well, this time, to the stock radio. i saw another basher here mount his camera to the radio using rubber bands. i thought, well, maybe my mini tripod might work here. and it does! i'm happy that it came out kind of nice and clean. the mini tripod, i think named "ultra pod", has this tree-hugging velcro strap feature already built in. i thought, "wow what an unimpressive feature" when i first bought this thing a few years ago. who would've thunk it will work so nicely here? for the most part, my wife helps me with my RC stuff only on my birthday (sob sob). so, this self-film feature might be fun to play with. we shall see.
keep bashing, guys.
-foam crazy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to katzcratch)
       Post #: 214
RE: OFFICIAL 1/16 VXL Slash thread. - 1/21/2010 3:06 AM
Lurp06x
Score: 101
Status: offline
thats a pretty sweet
for now i am going to wait on modding until stuff breaks, i thought about buying a bunch of tires and rims an seeing what works but i will wait on others to do that. but i have been doing some snow bank bashing and mastered the wall run on the side of a 6ft snow bank. wish i had a video camera to show . funny thing is i get some weird looks from people as they see a grown man playing with a mini slash. but all the kids in the neighborhood love to watch and i dont mind letting them drive it either because its fairly bashable. this mini slash keeps getting better each time i drive it. cant wait until summer to take it out to the track. well during the summer my wife has claimed it as her rc to drive while at the track.
Hide Signatures
(in reply to Foam Crazy)
       Post #: 215
RE: OFFICIAL 1/16 VXL Slash thread. - 1/21/2010 5:17 AM
HidosDeBrazil
Score: 100
Last Login: 4/25/2011
Status: offline
Hey Crazy, whats that on your radio?
www.Michiganrc.net
Hide Signatures
       Post #: 216
RE: OFFICIAL 1/16 VXL Slash thread. - 1/21/2010 7:32 AM
cul8tr
Score: 100
Last Login: 3/4/2013
Status: offline
Looks like a camera mount I think.
Hide Signatures
(in reply to HidosDeBrazil)
       Post #: 217
RE: OFFICIAL 1/16 VXL Slash thread. - 1/21/2010 7:53 AM
Lurp06x
Score: 101
Status: offline
yes it is i think thats what he said in his post
Hide Signatures
(in reply to cul8tr)
       Post #: 218
RE: OFFICIAL 1/16 VXL Slash thread. - 1/22/2010 5:45 AM
combatman
Score: 100
Status: offline
quote:
ORIGINAL: Foam Crazy
hello everyone,
this is i think my first post in the cars / trucks area. i'm normally a plane and heli guy. and so this is my first truck. my 1/16 slash is pretty much stock, other than a few mods here and there.
i am still looking for that perfect on-grass off-road wheel / tire combo. for now, i've settle on using the 1/16 e-revo wheel / tire combo as it does really well on the thick heavy grassy stuff. i'm very happy with what this combination can do in my front yard. i'm a beginner at bashing, and i don't really like to try to break this thing too much. after all, i've invested good money in this thing, so i like to take it fairly easy.
here is my mods list:
- stock 1/16 e-revo wheels and tires (let's me run on thick grass)
- trimmed body around the wheels to allow more clearance
- deans ultra connectors all the way around (an old habit. traxxas connectors look to also do the job just fine.)
- deans ultra parallel connector (i almost always run a single battery pack though)
- velcro wrap on speed controller wires to parallel connector to keep the wires from banging around (airplane / heli habit)
- ace hardware springs (no more sagging and bottoming out even under heavy acceleration and medium jumps)
- coiled antennae (stays inside the body shell which is good for when the truck flips. this is the stock AM radio system.)
- trimmed battery door (i've opened up the front of the battery door to allow the battery wires to run out the front.)
- 2s 2200mah lipo battery (i think these are the hobby-king zippy flight 25c packs)
- battery bay foam padding (keeps the battery from banging around inside the compartment)
- traxxas speed pinion
this setup is an absolute riot, and this thing is a wheelie machine. i can readily go even slight downhill, at about 10mph and still flick the trigger to bring up the front end. i do my share of sliding it on its roof and end-to-end cartwheels down the street. i'm very pleased at how well this thing holds up in tumbles.
keep having fun, guys!
- foam crazy
Hey Foam Crazy,
Can you provide any specifics on those Ace Hardware springs? Stock number, or anything else? Were they an exact fit, or did you have to trim them? Thanks!
Hide Signatures
       Post #: 219
RE: OFFICIAL 1/16 VXL Slash thread. - 1/22/2010 5:24 PM
Foam Crazy
Score: 100
Status: offline
i believe they were #93 compression springs. best way is to take your shock with you to ace hardware and try it on. it was an exact fit with no mods. try the link below also for more info. i lurk both sites for info.
http://monster.traxxas.com/showthread.php?t=492114
Hide Signatures
       Post #: 220
RE: OFFICIAL 1/16 VXL Slash thread. - 1/26/2010 1:11 AM
Foam Crazy
Score: 100
Status: offline
okay. i recently bought this painted castrol GTX body off of ebay. while i will probably never bash with this lid, it is an absolute joy to stare at, and worth every penny i paid. i wanted to show it to you guys. cheers.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 221
RE: OFFICIAL 1/16 VXL Slash thread. - 1/26/2010 2:37 AM
HidosDeBrazil
Score: 100
Status: offline
Looking to get a less towering steering servo for my 1/16 slash. Is there a shorter one on the market?
www.Michiganrc.net
Hide Signatures
       Post #: 222
RE: OFFICIAL 1/16 VXL Slash thread. - 1/26/2010 10:22 AM
Ttam Says Blarg
Score: 186
Status: offline
I broke my steering arm. Where do I go to replace it..??
Hide Signatures
       Post #: 223
RE: OFFICIAL 1/16 VXL Slash thread. - 1/26/2010 8:24 PM
Lurp06x
Score: 101
Status: offline
http://www.amainhobbies.com/product_info.php/cPath/1_25_1232/products_id/139500/n/Traxxas-Upper-Lower-Steering-Arm-Set
GO HERE
otherwise if you have a lhs and if they carry traxxas products they should be able to get you any part you need for any traxxas rc.
Hide Signatures
       Post #: 224
RE: OFFICIAL 1/16 VXL Slash thread. - 1/27/2010 7:42 AM
Lurp06x
Score: 101
Status: offline
well its been a full month now since i got my mini slash. and i have broken 3 front body/bumper mounts and one rear bumper. not bad since i drive like i am trying to break. oh an the body is starting to show its weak points and is cracking in 4 different places. otherwise i have gone through 5 body pins from having them get all mangled up. pretty much this thing is a beast.
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
