Mike Emilio
Joined: 3/17/2003 From: TorontoOntario, CANADA Status: offline
quote:
ORIGINAL: kirkj do you have a recommended wood cutter for your plans? will the laser lizard short kits work if we have him adjust them to your scale? i assume yours are scaled avonds plans? what are people doing for gear and canopy for your sizes listed? 1). do you have a recommended wood cutter for your plans? I have no contract arrangement with any cutter. Regardless of my plans all being very large, it's no big deal to simply tack glue any part to your wood, and cut to the line with a simple scroll saw, I use a small Dremell with only a 3" blade. Since the paper is only tack glued, it's easilly stripped off when your done. Some cut be hand using this method, others laser cut, regardless, it will cost you a bunch more if you pay someone to do it for you. Some of these parts are big, and might go beyond the working table size of some laser machines, thus hand cutting might be better. Ya, , the laser guy will tell you that he can notch, or "puzzle" large parts together. But that means breaking the wood grain and a massive glue joint! The smaller the table size, the more breaks and glue joints. 2). will the laser lizard short kits work if we have him adjust them to your scale? No! The frame sections are different. Most especially in the area of the turbine. If I recall, it's all metric parts and material, mine is all Imperial "inch". 3). i assume yours are scaled avonds plans? Some areas are similar and others are not. You can't get away from the fact that any F-14 will have similar sections, after all, that's what makes it look like an F-14, but at the larger scales there's alot of changes other than material thickness. 4). what are people doing for gear and canopy for your sizes listed? The guys that buy this big stuff know up front that they have to make their own. So far, this is the first time anyone has asked. It's highly unlikely that any company would set up for this just to sell maybe 1-2 a year. And that's only if the builder stumbled across them. Face it guys, we're a dying breed! An experienced guy usually has no problem with the canopy, but the gear requires a bit of a machine shop. Not too long ago, I sent a pm to Matrix. I asked if he would be interested in these scales, and if so, I would put a link to his site on my web page. His only response was, to put a link to his site if I like, but nothing about being interested in these scales. From his response, I gathered that he was either not interested or simply too busy. On the Matrix web site, none of his gear state to which manufacturer the gear will fit. So you might buy a gear and it doesn't fit, then what. Then you find out that it's designed for a DCU, too late after you spent your money.
< Message edited by Mike Emilio -- 10/2/2008 11:34:36 PM >
