no spark hand proping
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
RCGF 100CC Gas Engine (Side Intake CNC Crank Case)
Seller:  Furyflyer2
Details:   $699.99   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> no spark hand proping
Page: [1]
Login
no spark hand proping - 6/15/2009 1:07 AM
robm2007
Score: 100
Last Login: 10/20/2009
Status: offline
I cannot get a stihl 056 ( 80cc ) to produce any spark when hand proping. it has the magneto ignition system. i checked that the kill button is not grounded.  If i use my electric sullivan starter with out the spark plug in, i get spark about when the electric motor is at its peak rpm. the sullivan wont budge it when the plug is in.
I saw the jump starter system listed on the c&h web site but if i buy that, might as well getthe whole cdi ignition system.
how can i get it to produce spark by hand proping?
< Message edited by robm2007 -- 6/15/2009 6:58 PM >
Hide Signatures
       Post #: 1
RE: no spark hand proping - 6/15/2009 1:22 AM
Jester241
Score: 103
Last Login: 11/5/2009
Status: offline
I'm not sure if its even possible to hand start an engine with flywheel/magneto. I'm sure someone here will say its easily possible,but I've never seen it done. Thats a BIG reason most of us use Electronic Ignitions. The only engine I ever ran that had flywheel/magneto had a spring loaded started mechanism built in. Your probly gonna have to invest a big chunk of money into a massive starter for that big of an engine or simply put an EI on it for $40.00-$80.00. Its honestly really worth it to go with EI because of the conveince of it.
Hide Signatures
(in reply to robm2007)
       Post #: 2
RE: no spark hand proping - 6/15/2009 1:48 AM
jeffy
Score: 100
Last Login: 11/8/2009
Status: offline
you said that so well and you are right............
_____________________________
gee I dont have a silly sig because Its the same thing all the time........
Hide Signatures
(in reply to Jester241)
       Post #: 3
RE: no spark hand proping - 6/15/2009 1:53 AM
captinjohn
Score: 135
Status: offline
There are a lot of engines that will hand start with stock ignition.  My Zenoah G38 will hand start and idle as slow as any average ignition engine.  You have to have everything just right and know how to start them by hand.  It is something you learn in time....that is if you stick with it.  When I get time...I will post a video for proof.    Capt,n   PS...did you  poke that poor guy in the eyes enough by now!!!
I never met a engine I did not like!
Hide Signatures
       Post #: 4
RE: no spark hand proping - 6/15/2009 4:27 PM
pe reivers
Score: 111
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: Jester241
If you put the piston just BEFORE compression starts and then slap the prop, hand starting is relatively easy. I have seen it done many times.
I even succeded myself in starting a zenoah....ONCE! I like EI systems better.
Pe, Dealer for MVVS, MTW, Xoar and Mejzlik
There is sanctuary in analysis.
Hide Signatures
       Post #: 5
RE: no spark hand proping - 6/15/2009 4:42 PM
Nosedragger
Score: 100
Status: offline
I agree with captinjohn, technique is everything , the zenoah manual explains how to properly start a zenoah by hand.
Hide Signatures
(in reply to pe reivers)
       Post #: 6
RE: no spark hand proping - 6/15/2009 4:53 PM
jeffy
Score: 100
Status: offline
quote:
ORIGINAL: Jester241
I'm not sure if its even possible to hand start an engine with flywheel/magneto. I'm sure someone here will say its easily possible,but I've never seen it done. Thats a BIG reason most of us use Electronic Ignitions. The only engine I ever ran that had flywheel/magneto had a spring loaded started mechanism built in. Your probly gonna have to invest a big chunk of money into a massive starter for that big of an engine or simply put an EI on it for $40.00-$80.00. Its honestly really worth it to go with EI because of the conveince<meta content="text/html; charset=utf-8" http-equiv="CONTENT-TYPE" /><title>
I have also started g23 and g38,s by hand but you have to remember, Its all about flying and enjoying the sport so try to  make it easy on yourself
use a hand starter and EI works and your shoulder won't hurt so much
we are getting older and we should not have to make things hard on ourselves
ever have a engine that wont start and after a while someone says here use my starter and whamoo the engine starts.....its all about flying and enjoying the hobby....
Hide Signatures
       Post #: 7
RE: no spark hand proping - 6/16/2009 12:52 AM
flygilmore
Score: 100
Status: offline
Rather funny when you read all these folks who say that mag. engines can't be flip started/started easily!  As allready stated, you have to have a bit of knowledge about prop oreintation etc. before you just go out and start flipping.  I have seen many, many people who were either afraid or just wimps that could hardly get the prop to make it past the compression stroke.  Point is, I have not met a mag. engine that I could not start yet... I start all my Zenoahs from G-62's down to the G-26 with absolute ease-conversion engines too.  To me, it is fun to go out and start these engines-especially for someone else who says it can't be done.  Oh, and I have my EI engines too BTW.
I didn''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
(in reply to jeffy)
       Post #: 8
RE: no spark hand proping - 6/16/2009 3:29 AM
Joe Butch
Score: 100
Status: offline
He He He, yes, I fly mags and electronic ignitions.  I love them both, and I don't  even have a starter.  A G-38 has the neat three legged coil and it hand starts as easily as an electronic set up.  On my mag engines I use a heavy leather glove wrapped in a towel wraped in tape.  Have the engine coming up on the bump of compression with the prop blade between 12:00 and 1:00. SLAP the engine to start it ,and I mean SLAP.  With the prop in the right position you don't push the plane sideways or lift the plane.  The slap force is across and down.  To make the glove, put one of those brown cotton gloves on your hand first, then a leather glove.  Fold a small towel til it's about 4 inches wide, then wrap it around the glove.  Then wrap it with tape.  I use the heavy medical stuff, it is like cloth.  The glove will be too tight to get off and on easily if you don't wear the brown one then take it out when when your done taping.  No batteries or wiring to mess with on the mag and no batteries or wiring to mess with for the starter.  Choke it til you get the carb pretty wet,  full throttle, pull the engine over about 3-5 times to get the fuel up in the cylinder.  the squeeze and release of the 3-5 pull throughs get the fuel vaporized real well.  Set throttle to fast idle.  1  to 5 slaps and your running.  I'm not a big strong guy, believe me but SISSIES carry starters.
Hide Signatures
(in reply to flygilmore)
       Post #: 9
RE: no spark hand proping - 6/16/2009 3:59 PM
flygilmore
Score: 100
Status: offline
 WORD!!!!!
Hide Signatures
(in reply to Joe Butch)
       Post #: 10
RE: no spark hand proping - 6/17/2009 2:51 AM
adrian222
Score: 100
Status: offline
Or you could pull a starter motor out of a ride on mower or a old outboard engine which I use.
Adrian.
Hide Signatures
       Post #: 11
RE: no spark hand proping - 6/17/2009 3:22 AM
Edwin
Score: 110
Status: offline
Make sure your prop is in the right position first and foremost.  With the magnets just before the coil set your prop to about 2 o'clock.  Then the slap method works.  It CAN be a little hard if the carb is just a tad lean.
Edwin
Hide Signatures
(in reply to adrian222)
       Post #: 12
RE: no spark hand proping - 6/17/2009 3:29 AM
captinjohn
Score: 135
Status: offline
I never had to slap my G38 with stock mag....what you guys have is a poor tunned engine or slow arm or both.    Maybe even slow brain!!!!!    Capt,n
Hide Signatures
(in reply to Edwin)
       Post #: 13
RE: no spark hand proping - 6/17/2009 5:29 AM
Joe Butch
Score: 100
Status: offline
I'll type this slowly so the cap can read it.  I said a  G-38 has the three legged coil and hand starts easily.  Everyone has been trying to help then the cap comes on telling us we're tuned ( one n ) improperly and slow physically and mentally.  Thanks cap
Hide Signatures
(in reply to captinjohn)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.109RCU1
