Saito stack so close to the fuse.....
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Saito stack so close to the fuse..... Page: [1]
Login
Saito stack so close to the fuse..... - 6/15/2009 9:30 PM
Ernie Misner
Score: 100
Last Login: 11/6/2009
Status: offline
Hi Mike, if I use the velocity stack on my Saito 82 (on the Edge 540 ARF) it only gives 1/8" or less clearance for breathing between it and the fuse.   How much structural strength would I loose if I ground a bit of a crater  in that area behind the engine mount.    Someone said they drilled a hole clear through the fuse.   The stack area is about 3/8" behind the upper part of the engine mount cutout area.
Thanks loads,
Ernie
Hide Signatures
       Post #: 1
RE: Saito stack so close to the fuse..... - 6/15/2009 11:13 PM
hkilian
Score: 100
Last Login: 10/11/2009
Status: offline
I'm not Mike but the clearance should be plenty to keep your plane from coming down in flames.  Have to use my infrared thermometer on my YS 1.10 exhaust but I doubt very much I'll see temps that would ignite the wood structure.  Stick a piece of good aluminum tape ("real" duct tape) over the area that's close.  Also, carve additional clearance space up to a quarter inch if you feel so inclined.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 2
RE: Saito stack so close to the fuse..... - 6/15/2009 11:16 PM
daveopam
Score: 109
Last Login: 11/7/2009
Status: offline
Ernie, Notice in the pics I notched the rear area. I did not go all the way through. Also what the pic does not show is my notch is run at an angle. In other words, the left side of the fuse shows no notch at all. Even without the stack the notch would be needed in my application. The carb would have been to close to the fuse to get a good draw.
  On your servo question. I have never had one go bad from oil getting in it. Most of the electronics are in the lower half of the case. It would be very difficult for oil to get past the gars and do damage in the lower part of the case. Not saying it can't happen, but it would be difficult.
  Mike, sorry if I stepped on toes, but Ernie sent me two emails before this post. I always prefer the answers go on hear for all to see anyway. That way more then one can learn a little something.
David
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"Never use a big word when a little filthy one will do"
Johnny Carson
Hide Signatures
       Post #: 3
RE: Saito stack so close to the fuse..... - 6/16/2009 2:47 AM
AFSalmon
Score: 100
Status: offline
Heck no and thanks Dave!  Actually I don't have any experience with that engine and the velocity stack.  My first question is will the engine run ok without it?  If not I think what Dave describes above is a good suggestion.  Only cut as much as you need and no more.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: Saito stack so close to the fuse..... - 6/16/2009 3:14 AM
daveopam
Score: 109
Status: offline
The engine runs fine without it. What it is supposed to do is suck back in the droplets of fuel that come out of the carb during a certain point in the engines timing. This is supposed to keep the plane cleaner and help with fuel economy. Does it work? Some swear by it. Others say it's BS. For me I can't tell any difference in Saito 72s with and without it.  And , if it is such a great aid for the Saito engine, how come some come with it and others don't? At one time the only way to get the stack on a 72 was to buy the GN version. This is the one with the black crankcase and gold rockers. Or you Had to buy one from Horizon and add it.
    On the 67" Fusion like mine. I needed some clearance in that area anyway. So why not leave it on? The Tetherite thrust plate I got from OMP tilted the engine away a little. But the back half of the carb was still going to be really close to the fuse.
David
Johnny Carson
Hide Signatures
(in reply to AFSalmon)
       Post #: 5
RE: Saito stack so close to the fuse..... - 6/16/2009 3:50 AM
icepunk
Score: 100
Last Login: 11/3/2009
Status: offline
I found this intersting as I am having the same mounting problems with the new OS FS 81a and it's new 'venturi' intake
http://saito-engines.info/special_tricks.html
in regards to removing it all together....
Hide Signatures
       Post #: 6
RE: Saito stack so close to the fuse..... - 6/16/2009 9:25 PM
Ernie Misner
Score: 100
Status: offline
What's interesting about icepunk's Saito link, is that being on the Saito website, this fellow suggests going to a hardware store to buy the o-ring for the accessory stack.   It's true that the stack doesn't come with the necessary o-ring.
About the efficiency of the stack,  the new Alpha series of OS 4-strokes have added the stack and they talk it up big in their advertisements.
Thanks for all the good info!
Ernie
Hide Signatures
(in reply to icepunk)
       Post #: 7
RE: Saito stack so close to the fuse..... - 6/17/2009 8:51 PM
AFSalmon
Score: 100
Status: offline
Hmm, maybe I need one of these for my Saito 100.
Ohio Model Planes
Hide Signatures
       Post #: 8
RE: Saito stack so close to the fuse..... - 6/17/2009 10:19 PM
daveopam
Score: 109
Status: offline
Just get a 1.25 and a MA Scimitar 16x6. It has the stack on it.
David
Johnny Carson
Hide Signatures
       Post #: 9
RE: Saito stack so close to the fuse..... - 6/24/2009 8:39 AM
Ernie Misner
Score: 100
Status: offline
Was that the KG version David? I'm thinking the stack doesn't come on the standard version unless you add it. I like those Scimitar props. The 13x6 works great on the OS 55 and the 14x6 works great on the Saito 82.
Ernie
Hide Signatures
       Post #: 10
RE: Saito stack so close to the fuse..... - 6/24/2009 3:32 PM
daveopam
Score: 109
Status: offline
I made I typo talking about the GK version. I put GN. The GK stands for Golden Knight. I don't know if a GK was ever made in the 82. On the 72 they made both and for some reason the GK had the stack. The GK cost $20-$30 more but I assumed this was for the powder coating. Maybe part of the money was for the stack? I'll put pic in the next reply.
I am a huge fan of the Scimitar props on the 1.25. I have not tried one on anything else. Once I find a good prop I stick with it. I am running a Zinger Pro Series 15x4 on my .82. When i break my spare I will have to try a Scimitar.
David
Johnny Carson
Hide Signatures
       Post #: 11
RE: Saito stack so close to the fuse..... - 6/24/2009 3:38 PM
daveopam
Score: 109
Status: offline
Ernie, here are a few pics of a GK. As you van see the muffler is standard finish. As is the drive washer. The rest of the metal is black or gold.
David
Click for fullsize
Click for fullsize
Click for fullsize
Johnny Carson
Hide Signatures
       Post #: 12
RE: Saito stack so close to the fuse..... - 6/25/2009 7:30 AM
Ernie Misner
Score: 100
Status: offline
Hi Dave, what plane is that the GK is on? Looks like fun. It's my understanding that all GK's came with a stack and the standard versions without.
Ernie
Hide Signatures
       Post #: 13
RE: Saito stack so close to the fuse..... - 6/26/2009 8:58 PM
daveopam
Score: 109
Status: offline
Ernie, That's a Sig Somthing Extra. Very nice sport plane. Some say it's one of the best sport planes out there. I don't fly it much. Just because I have been doing all 3D the last couple of years.
David
Johnny Carson
Hide Signatures
       Post #: 14
RE: Saito stack so close to the fuse..... - 9/8/2009 4:47 PM
daveopam
Score: 109
Status: offline
BUMP
Johnny Carson
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU1
