RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) Page: <<   < prev  27 28 [29] 30 31 32 33 34 35 36   next >   >>
Login
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 12:33 AM
SunDevilPilot
Score: 147
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: cannonball200
You have inspired me to finish my arf Hanger 9 1/4 J-3 Cub. It has a Dle 20 installed already. I ordered the tail braces you used to put on it. You have done an awesome build and I have really enjoyed it.
Eddie
of OKC
The H9 Cub really flys nice.  My friend has that with a Zenoah 26 on it.  A lot of fun to fly!
Thanks for the compliments.
SunDevilPilot
_____________________________
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
(in reply to cannonball200)
       Post #: 701
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 12:42 AM
HoundDog
Score: 178
Status: offline
quote:
ORIGINAL: SunDevilPilot
Eddie
of OKC
SunDevilPilot
That's When it's in "ONE PEICE" he he he ... Naughty ....
Remember ... Every one of these Things we fly has a Termination date, The more expensive The bigger the tears.
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 702
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 1:24 AM
SunDevilPilot
Score: 147
Status: offline
Despite the setback with the windshield the work continues..   I got a good start on the instrument panel and decided to roughly copy one I found on the internet.  More of a blend of two panels. The red one is a PA-18 and the black one is a PA-12...  So, like my plane, the panel will be a mix of the two.  Mine will be much more simple but the basic idea is from the attached photos.  So far I have drilled all the holes for the gauges.  I omitted the smaller gauges on the right side and will substitute something else in it's place, likely some simulated switches.
The sizes of the gauges were made based on the forsner bits I already had and not a scale size (Thanks Ron, one of the sizes was from the bits you purchased for your 1/3 Cub).
Next I will scan the panel into my computer and create the printed gauges.
More to follow on the subject......
SunDevilPilot
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
(in reply to HoundDog)
       Post #: 703
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 2:53 AM
HoundDog
Score: 178
Status: offline
SunDevilPilot
Check this out for Instruments ... http://www.inzpan.com/1_3_Accessories_s/98.htm
Hide Signatures
       Post #: 704
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 4:25 AM
SunDevilPilot
Score: 147
Status: offline
Here is what I came up with...
Not all the gauges are correct for the plane but at the scale they will print, in conjunction with "Who Will Notice", it should not be a problem.  At least not a problem for me.
As you can see I scanned in the wooden panel....  Made it slightly opaque in photoshop....  Then imported the gauges into photoshop and using the opaque panel lined them all up..
Now I just need to print the gauges out and they will all line up with the wooden panel.
Because I have no ink in my printer I will just send the file to Wal-Mart and have the panel printed on some photopaper.  (I never print anything out at home anymore).
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 705
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/5/2012 2:38 PM
HoundDog
Score: 178
Status: offline
SunDevilPilot
Where's the Artifical Horizon  and you Need a radio at least one. As good as the plane looks a little acurate detail goes a long long way.
Hide Signatures
       Post #: 706
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 5:40 PM
SunDevilPilot
Score: 147
Status: offline
This morning I started working on the windows.
Because I have never done it this way I decided to start with the windows on the door.  The windows are cut from the supplied material at a slightly smaller size than the opening.  Then the Fourmost U-Channel is applied to the edges making each window the same size as the opening.  After the U-Channel dries I will glue the window to the frame.
The U-Channel provides an area / frame that will obscure the glue from the exterior view.
In the photos the windows are just sitting in the frame waiting for the U-Channel to set up.
Unfortunately our cat is diabetic which requires him to have insulin injections two times a day.  Because of this I have a continuous supply of tiny syringes.  I took a couple used ones and cut the sharp end off the point.  Then I filled the syringe with some canopy glue.  I used the syringe to "Inject" the glue into the bottom of the U-Channel.  Then I applied the U-Channel to the windows and wiped / washed away any glue that oozed out.  Worked nicely.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/6/2012 6:27 PM >
SunDevilPilot
Hide Signatures
       Post #: 707
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 7:23 PM
SunDevilPilot
Score: 147
Status: offline
Crescent window went without issue.  For now all but the door windows are getting their trim installed but they are not being glued into the fuselage.  I'm waiting until I get my arch nemesis (AKA the Windshield) installed.  The door windows were glued in.
Having never done windows this way I can tell you it is a little finicky with the small trim but quite simple to do.  I think it really looks really nice.
The manual instructs you to just cut the windows, in one piece, to the rough shape and glue the entire piece to the side of the fusealge.  That sounded a little lazy to me and I would not have been happy with how it looked.
SunDevilPilot
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 708
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 8:20 PM
SunDevilPilot
Score: 147
Status: offline
Sorry I missed you Ron...  Thanks for the bungee cover plans.  I was at Walmart picking up the printed gauges.  Here is what they look like..
I still need to put a couple details onto the wood portion of the panel and polyurethane it but so far it is looking like I wanted.
SunDevilPilot
Click for fullsize
< Message edited by SunDevilPilot -- 3/7/2012 1:34 AM >
SunDevilPilot
Hide Signatures
       Post #: 709
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 8:28 PM
roncannell
Score: 103
Last Login: 5/20/2013
Status: offline
The windows look good, the instrument panel color copy turned out well also.
Hide Signatures
       Post #: 710
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 9:28 PM
HoundDog
Score: 178
Status: offline
I still need to put a couple details onto the panel and polyurethane it but so far it is looking like I wanted.
SunDevilPilot
SDP ... Not to be pickey ... BUT  the right 2 instruments the Altimiter and the DG are missing their Knobs ... The Air Speed Being a TAS indicator should also have a knob ...  Sorry he he he
Hide Signatures
       Post #: 711
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 9:40 PM
AmishWarlord
Score: 121
Status: offline
That's just wrong.
Now he'll be up all night crafting some knobs.
Hide Signatures
       Post #: 712
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/6/2012 10:00 PM
HoundDog
Score: 178
Status: offline
quote:
ORIGINAL: AmishWarlord
That's just wrong.
Not the SDP, He's on Patrol to early for that ... Boy, Then it's a Good thing I didn't say anything about a Wiskey Compass   Shame shame I have NO Shame. he he he LOL
OOPs Missed it ... The DG has 2 Knobs ... so sorry!
Hide Signatures
(in reply to AmishWarlord)
       Post #: 713
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/7/2012 11:16 AM
TomCrump
Score: 116
Last Login: 5/22/2013
Status: online
The Ip is a nice touch. It will look even better, once installed.
Tom C
Hide Signatures
       Post #: 714
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 3:13 AM
SunDevilPilot
Score: 147
Status: offline
I'm still waiting on the plastic from Balsa USA.  I received my plastic order from Sig but I want to see what the thinner stuff from Balsa USA is like before I made my decision on which to use.  It will be here Monday.
Today I went to an open house at the local airport but I did manage to get the radio installation into the fusealge completed.  Here is what it looks like now.
The switch is failsafe style from Fromeco, the battery is a two cell lipo (Unregulated), running into a Futaba 6208 HV receiver.  All the servos are rated for high voltage (8.4V).
The battery and receiver are attached via sticky back velcro and a velcro strap.  The battery will be removed when the plane is stored due to safety concerns with Lipo batteries.
You can see in the photo the antenna guide tubes I just installed.  I used some canopy glue to secure the tubes into place.  The vertical antenna is still wet but the glue will go clear when it dries.
The antenna guides were bent with a heatgun making the antenna enter the guides at a natural angle preventing the chance of breaking an antenna.
I also messed around with another new tool, a mini wood lathe.  Usually I get a new tool per plane but this plane is seeing a whole new collection.  I have never turned wood, and having played a little with it today, I can tell you it is quite a bit of fun.  The lathe should come in handy on certain aspects of model building.
Now, if only I had enough money for a metal lathe!
Tomorrow I will likely put the wings on, find the balance point, and create the main battery tray.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/11/2012 4:12 AM >
SunDevilPilot
Hide Signatures
(in reply to TomCrump)
       Post #: 715
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 5:14 AM
Zor
Score: 181
Status: offline
SunDevilPilot,
With a wood lathe goes a good shop-vac.
You have one already ?
Zor
Hide Signatures
       Post #: 716
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 2:00 PM
AmishWarlord
Score: 121
Status: offline
SDP if you give up RC to turn pens where going to come after you!
Here is a sweet gum ball ped that one of our members turned.
Click for fullsize
Hide Signatures
(in reply to Zor)
       Post #: 717
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 3:25 PM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: Zor
SunDevilPilot,
Zor
One of my friends got into woodworking for a short time.  He purchased a dust collector then it sat in his garage taking up space.  He basically made me take it from him so he could get some space back in his garage.  When I got it there was more dust on it than in it.  I have used it many times and it is really nice.  It hooks up to most of my tools.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
(in reply to Zor)
       Post #: 718
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 4:12 PM
HoundDog
Score: 178
Status: offline
quote:
ORIGINAL: Zor
SunDevilPilot,
Zor
SunDevilPilot
Looks more like an Hospital Operating Room  ... ya gota Make some chips
Hide Signatures
       Post #: 719
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 4:57 PM
Zor
Score: 181
Status: offline
SunDevilPilot
That is a nice unit ........ at a good price
HounDog
Right on man. Where we do the surgery on our models.
Zor
Hide Signatures
       Post #: 720
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/11/2012 5:32 PM
SunDevilPilot
Score: 147
Status: offline
I decided I would like to make up a faux GPS for the open side of my Panel.  So, for now that area is blank.  I have, however, started to finish up the panel.  I drilled some holes on the lower left side for some knob style controls.  I am making the controls from some servo style screws and metal spacers painted red, grey, and black.
After the holes were drilled I put on a couple coats of gloss polyurethane to complete the wood portion of the panel.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/11/2012 7:17 PM >
SunDevilPilot
Hide Signatures
       Post #: 721
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 12:30 AM
SunDevilPilot
Score: 147
Status: offline
I didn't get much accomplished today but I did determine the plane's balance.  I put the wings on the plane and with the main motor batteries up against the firewall the plane balances.  So, it looks like I got lucky with this one and will not need any lead to balance.
I also took the chance to weigh the plane with everything on it.  In a ready to fly configuration I'm at 19.5 pounds, batteries and all.  From what I see on the internet the H-9 1/4 Cub comes in at about 17 lbs dry with a gas motor so they should be comparable.  The batteries alone are 3 lbs so I guess the plane is at the target weight per the plans.   A little on the porky side but it should fly good at that weight.  I would have liked it to be a few pounds lighter but there wasn't much I could change during the build.
Tomorrow I'm going flying and I will pick up the needed wood for the battery tray on the way home.  I should also be receiving my plastic for the windshield tomorrow and I hope to get installed Tuesday.
Now that I know the main batteries will be up against the firewall I can start planning for the slide in / bolt down battery tray.  I am going to make a simple rail system that the battery tray can slide into and be secured via a single bolt.  Kinda like a quick change battery tray.
SunDevilPilot
< Message edited by SunDevilPilot -- 3/12/2012 1:04 AM >
SunDevilPilot
Hide Signatures
       Post #: 722
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 1:13 AM
spaceworm
Score: 143
Status: online
Just for reference, the Hangar 9 1/4 Cub molded windshield is a close fit to the Sig, and cost only about $5.00 It is a little wider so I cut the parts of the WS where it would fit between the wing halves so it overlaps the wings on each side. Be careful trimming the H9 WS, cause it is thin and cracks easily. Good luck. I fly my Sig Cub with an electronic ignition modified Zenoah G23. Loops easily from level flight and does a nice prototypical roll.
Hide Signatures
       Post #: 723
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 4:14 AM
SunDevilPilot
Score: 147
Status: offline
Thanks for the idea of the H9 Windshield but it will not work with my model, based on the lack of the "Eyebrows" on a Super Cub.  Had I left it a J3 that would be a great option.
The Instrument Panel, minus the GPS that will be added later, is complete.
I'm really happy with it.  Has that fine wood look that I was after.
Some of the eariler photos made it appear somewhat light in color.  These photos are almost exactly what it looks like in person.  A deep rich red.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
(in reply to spaceworm)
       Post #: 724
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 4:19 AM
TripleDeucer
Score: 101
Last Login: 5/21/2013
Status: offline
Phil, did you have anything over the gauges for glass? If so, what did you use?
Mark
Revver #48
Hide Signatures
       Post #: 725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
