RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
Page: <<   < prev  28 29 [30] 31 32 33 34 35 36 37   next >   >>
Login
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 4:24 AM
SunDevilPilot
Score: 152
Last Login: 6/18/2013
Status: offline
Here is the panel just sitting on the plane.  I'll glue it on tomorrow after the polyurethane is fully cured (Still tacky due to the thick coat I put on).
SunDevilPilot
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/12/2012 2:40 PM >
_____________________________
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 726
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 4:53 AM
SunDevilPilot
Score: 152
Status: offline
quote:
ORIGINAL: TripleDeucer
Phil, did you have anything over the gauges for glass? If so, what did you use?
I have used some high quality packing tape but on this one I left it as is, photo paper.
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to TripleDeucer)
       Post #: 727
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 5:30 AM
TripleDeucer
Score: 101
Status: offline
Phil, your panel turned out great. I'm not telling you what to do, but I think before you mount the panel, it would look nice to paint the top of the dash behind the windshield a non glare flat black like the full scale jobs have. I do mine that way and they look real good. Just a thought for you.
Mark
Revver #48
Hide Signatures
       Post #: 728
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 6:05 AM
SunDevilPilot
Score: 152
Status: offline
I did just as you describe on my 1/5th Cub but I am not sure if I will get it done on this model.  I am having enough issues with the windshield and I am not sure if I can bend the windshield onto the fuselage and maintain a seam at the location where an anti glare coating has been painted onto the fuse.  My other model has a pre-formed windshield which allowed me to mark out where the transition would be and keep it under the windshield frame.  This would be a real challenge with this model.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 729
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 6:50 AM
TripleDeucer
Score: 101
Status: offline
I'll bet you could paint it with a brush from inside after the windshield is installed. You would need a thin flat brush for the cut in next to the windshield. It's not like you would be painting blind, as you can look through the windshield. A good artist supply store would have the correct brush. How about some of the Fourmost chaneling along the baseline?  Anyway, whatever you do will look just fine.
Mark
Revver #48
Hide Signatures
       Post #: 730
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 10:33 AM
TomCrump
Score: 116
Status: online
quote:
ORIGINAL: SunDevilPilot
Thanks for the idea of the H9 Windshield but it will not work with my model, based on the lack of the ''Eyebrows'' on a Super Cub.  Had I left it a J3 that would be a great option.
The Instrument Panel, minus the GPS that will be added later, is complete.
I'm really happy with it.  Has that fine wood look that I was after.
Some of the eariler photos made it appear somewhat light in color.  These photos are almost exactly what it looks like in person.  A deep rich red.
SunDevilPilot
Nice work on the IP !
Tom C
Hide Signatures
       Post #: 731
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/12/2012 2:09 PM
GerKonig
Score: 191
Last Login: 6/19/2013
Status: offline
On the instrument issue. this weekend I met a vendor that had some amazing scale stuff including instruments for a 1/4 scale J-3 I have. check his site, the instrument panels for WWII warplanes he had blew my mind... Also the full body 1/4 scale pilots.
Gerry
http://www.iflytailies.com/store/instruments/1-4-scale-civilian/
Hide Signatures
(in reply to TomCrump)
       Post #: 732
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/13/2012 1:23 AM
SunDevilPilot
Score: 152
Status: offline
Video looks pretty amazing!
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to GerKonig)
       Post #: 733
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/13/2012 7:57 PM
SunDevilPilot
Score: 152
Status: offline
Today was a day of reckoning between me and the windshield.  The windshield won the previous round but today I had success.
Using what I had learned during my previous attempt I cut and shaped the windshield.  I used the .020 from Balsa USA and it was a little bit easier to deal with than the .030 stuff from Sig.
Right now the windshield is gluing to the "A" pillars.  Once those set I will release the clamps on the upper portion of the windshield and glue that down.
The black U-Channel was glued to the bottom of the windshield before I began the install onto the fuselage.
I also have the instrument panel gluing into the fuselage.  I used a stick as a wedge to hold it in place until the glue sets.
***  Updated photos with one taken after clamps removed ***
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/16/2012 4:06 AM >
SunDevilPilot
Hide Signatures
       Post #: 734
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/13/2012 10:20 PM
AmishWarlord
Score: 121
Last Login: 6/14/2013
Status: offline
I love those Irwin clamps. I have about 30 of the $1 clamps that I got on sale for .50 cents at Harbor Freight. I still feel ripped off.
You can never have enough clamps!
Hide Signatures
       Post #: 735
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/14/2012 3:44 AM
SunDevilPilot
Score: 152
Status: offline
I have started to work on the battery tray.  I am just creating as I go.  The plan was to create a base frame and glue that into the plane.  The base would have rails at the front and a bolt at the rear to secure a slide in style battery tray.  The tray will be secured to the batteries via velcro / velcro straps.  The batteries and tray will come out by removing a single 1/4-20 wing bolt.
In the photo you can see both parts.  The bottom tray is still too long as I have yet to cut it down at the rear but the front side is more or less what the end result will be.  As you can see I cut out the entire middle of the lower tray.  This keeps it light and allows for the velcro straps of the battery tray to not interfere with the rail system, they simple go into the open space.
On the upper tray you can see the markings where I will cut slots for the battery straps, one on the front of the battery and one towards the rear.
Both parts will be lightened up with some holes once I commit to the design.
Thoughts?
I have never tried this before so it is a bit of an experiment.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
(in reply to AmishWarlord)
       Post #: 736
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/14/2012 6:00 AM
Zor
Score: 183
Status: offline
SunDevilPilot,
You are coming along fine.
I presume that, the battery being the heaviest item in the fuselage, that you are providing for near instant deceleration.      .
Zor
Hide Signatures
       Post #: 737
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/14/2012 6:01 AM
HoundDog
Score: 183
Status: online
A Gas Tank seems a lot easer. 1 time instalation. Charges (Fills) in30 seconds too. About $4 each and you only need 1 each.   he he he LOL
Remember ... Every one of these Things we fly has a Termination date, The more expensive The bigger the tears.
Hide Signatures
       Post #: 738
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/14/2012 7:31 AM
AmishWarlord
Score: 121
Status: offline
That sounds good Hounddog but the trouble is that fuel tanks shrink over the coarse of a year.
So if you have a 24 oz tank, a year later it will only hold 19.2 oz.
Then there if fuel delivery problems.
If your fuel tank can supply the engine with 2 oz of fuel a min, a year later it can only supply 1.6 oz a min.
Also if your engine needs 2 oz of fuel per min to run at full power then you need to get a 24 oz to run for 10 mins, so you'll have a 20% reserve.
You'll need to always keep 4.8 oz of fuel in the tank or it will heat up and melt, then you'd have to buy another fuel tank.
Hide Signatures
(in reply to HoundDog)
       Post #: 739
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/14/2012 4:07 PM
HoundDog
Score: 183
Status: online
quote:
ORIGINAL: AmishWarlord
A.W.L ...
   I For got all the problems associated with Gas Tanks ... Thanks for the reminder. Of course they become a real problem after a short time. Think maybe "SOLAR" might be the way to proceed? One thing you failed to mention is that one problem with Fuel Tanks is the plane get's lighter as the Tank empties, about 2.2 Lbs Lighter. This in it's self presents a problem in that the Plane doesn't want to land. Anothe thing with Fuel Tanks is the "Fire Hazard"  EXPLOSIVE situation.   sorry!!!  he he he LOL ... Man I'm in trouble NOW.
Hide Signatures
       Post #: 740
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/18/2012 9:58 PM
SunDevilPilot
Score: 152
Status: offline
I have been a little busy and as a result I have been neglecting my Cub.  I have, however, been able to get the construction of the battery tray completed.  I need to paint the parts cream but it is raining outside right now so that will have to wait.  After paint is completed the lower portion of the tray will be glued in.
In the photo I just have one of the batteries on the tray.  I was using it to size the removable portion of the tray.
Everything seems to be coming out good.
As you can see I lightened the parts quite a bit.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 741
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 1:01 AM
SunDevilPilot
Score: 152
Status: offline
These last few steps are taking my a lot of time!
Today I glued in all the windows on the side of the fuselage.  The U-Channel I installed onto each pane of glass made this process pretty easy.  I just had to be careful not to push the window out of alignment until the glue set.  A bead of glue was run around each window using a syringe with the point sanded off to lay down the glue.
Tomorrow I will install the top glass then all I have left is to paint and install the main battery tray.
I plan on getting some litho plate to paint and cover up the glue on the windshield and top glass with a simple frame.  (Another experiment).
After the battery tray is in the plane is airworthy, I hope!
SunDevilPilot
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/20/2012 2:32 AM >
SunDevilPilot
Hide Signatures
       Post #: 742
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 2:11 AM
cannonball200
Score: 105
Status: offline
SDP;
LOOK'IN FANTASTIC!!!!!!!!!
I am a J-3 guy but I am enthused with your work.....
Thanks and good luck,
Eddie
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
       Post #: 743
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 4:37 PM
Zor
Score: 183
Status: offline
SunDevilPilot
SunDevilPilot,
What kind of glue did you use for these windows ?
Is that syringe still useable after glue was in it ?
Thanks for that info.
Zor
Hide Signatures
       Post #: 744
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 5:57 PM
AmishWarlord
Score: 121
Status: offline
Zor, do a gogle search for Microject 412. You can buy them for $25 a box of 50.
Hide Signatures
(in reply to Zor)
       Post #: 745
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 6:32 PM
Zor
Score: 183
Status: offline
I supposed you meant Google.
I searched for Micoject412
and also for Microject 412 (with a space)
I got nothing concening syringes.
Thanks for trying to help.
I hope to receive information per my questions.
Zor
Hide Signatures
       Post #: 746
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 6:37 PM
AmishWarlord
Score: 121
Status: offline
I'm on my cell so can't post links or spell Google. I have a.link posted on an rcu these under "Chinese Hobby Shops" see if you can find it there.
Hide Signatures
(in reply to Zor)
       Post #: 747
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 6:47 PM
AmishWarlord
Score: 121
Status: offline
Ah misspelled it it's "Monoject 412"
Hide Signatures
       Post #: 748
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 7:06 PM
SunDevilPilot
Score: 152
Status: offline
Glue - The glue I used is Pacer RC560.  I have has the bottle for years.  It stays rubbery and dries 100% clear.  Really good stuff for canopies.
Syringes - I washed mine out.  The canopy glue is water based so it easily cleans up.
This morning I sprayed the wheels black.  I was going to go with cream but I happened to have some Krylon black that is made for painting plastic.  So I tried it out and really like the look.
Right now I'm waiting for the paint to start it's reaction so I can spray the cream onto the battery trays.  I will be quite happy to be done painting for a while.  Cleaning out the spray gun is a real chore.
After painting I will work on the top glass and glue that on.
This will leave me with installing the battery tray when it is dried and this plane is flyable!
I will likely add some more details after the plane has flown.
SunDevilPilot
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 3/20/2012 10:00 PM >
SunDevilPilot
Hide Signatures
       Post #: 749
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 3/20/2012 9:56 PM
AmishWarlord
Score: 121
Status: offline
Found the link to the glue syringe.
http://www.net32.com/ec/monoject-disposable-syringe-412-12cc-with-curved-d-40956?utm_source=Windfall&utm_medium=ProductFeed&utm_content=dental&utm_campaign=GoogleShopping
Hide Signatures
       Post #: 750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
