RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) Page: <<   < prev  34 35 36 37 38 [39] 40 41 42 43   next >   >>
Login
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/30/2012 10:10 PM
SunDevilPilot
Score: 147
Last Login: 5/25/2013
Status: offline
Bottom of the right wing is now covered.
I have to say, every time I use SolarTex I am amazed at its ability to go around a wing tip.  I just turn the temp up a bit with the iron, warm the covering in advance of the curve, and bend it into place.  It really cant be easier!
Taking a 15 minute break then onto the top side covering.
SunDevilPilot
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 10/31/2012 3:39 AM >
_____________________________
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 951
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/31/2012 12:01 AM
SunDevilPilot
Score: 147
Status: offline
Right wing is now totally covered.  I plan on going back over both wings with a little hotter iron to tighent things up right before painting and I still need to cut / melt the holes for all the hardpoints, servo hatches, and strut screws.  I use a cheap solder iron for the screw holes and an xacto for the servo hatch holes.
That's it for this weekend.
SunDevilPilot
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 952
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/31/2012 12:04 AM
box car
Score: 100
Status: offline
SDP I am building a 1/4 scale Jack Capen PA-18, those airport pictures you posted are a great in helping my build. Thank You
Ken
Wherever conversion engines are outlawed, only outlaws will have conversion engines.
Hide Signatures
       Post #: 953
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/31/2012 3:44 AM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: box car
I've never heard of that one, so I looked it up.  Found a few photos of one, looks good!
I saw where you were researching the plans, you making a build thread?
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to box car)
       Post #: 954
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/31/2012 8:19 PM
box car
Score: 100
Status: offline
I have been making changes to the plans as far as the wood they used. This is the list of wood used in the plane, bass wood, plywood, maple, mahogany, spruce, luan, and 2 5x5 1/4 balsa. Very heavy plane at 21#, used a 38 gas. I am going to try and get that down to about 16# and use a 30 gas. All the controls are pull-pull cable, all that will be gone, first time seeing cable flaps and ailerons in my 60 years of modeling. A build thread, I would be to slow for these guys.
Ken
Hide Signatures
       Post #: 955
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 10/31/2012 11:03 PM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: SunDevilPilot
SunDevilPilot
FWIW, fabric is the only way to cover a compound curve, such as your wing tips. It always works out perfectly. The weave of your fabric is what lets it conform to the complex shape.
As for tightening, it's the same as the Koverall which I use. The dope is what really causes the shrink. You'll never get the heat shrink fabric as taught as it becomes once the dope shrinks it. And once it's all shrunk and painted, that adds to the integrity of the iwng. It strengthens things considerably. That's something a plastic iron on covering won't do.
As an aside, Sig mentions that in the instructions for their 1/6 Cubs. They warn that the wing structure as designed is not suitable for the iron on films due to their lack of added strengt.
In any case, it's nice to see that you have rebuilt your plane. Very nice. Wish you all the best with the "new" version.
Hide Signatures
       Post #: 956
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/2/2012 3:16 AM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: do335a
SunDevilPilot
I can hardly believe that I finally read another fellow showing the advantages of fabric and aircraft dope.
Another surprise is that do335a is nearly my next door neighbor. Wherever he is in Toronto I am a bit west of the Pearsen Airport..
It would be nice to meet sometime. You could send me a PM and we could have lunch together.
Zor
Hide Signatures
(in reply to do335a)
       Post #: 957
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/4/2012 7:32 PM
SunDevilPilot
Score: 147
Status: offline
This morning, as planned, I put the color onto the bottom side of each wing.  Everything is coming along.
I am off from work this coming week so maybe on Wednesday or Thrusday I will spray the top sides of each wing completing that part of the project.
Hopefully this week I can cover up  the fusealge, gear, and start painting on the fusealge parts + struts.
There is a bunch to do but we're getting there.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
(in reply to Zor)
       Post #: 958
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/6/2012 9:01 PM
SunDevilPilot
Score: 147
Status: offline
I got done at work a little early today so I came home and jumped right into painting the top sides of the wings.
At this point the wings are completely repaired.
Next, I will trim and prime the cowl.  When the cowl is ready for the final prime I will strip the landing gear and prime them along with the cowl.  I will also prime the main struts.  Once all that is done I will begin covering the fueselage.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 959
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/9/2012 5:00 PM
SunDevilPilot
Score: 147
Status: offline
Too windy outside for the painting to continue...  However, the primer was dry enough to allow the gear to get recovered.  I drew a template onto my cutting surface then cut to shape four pieces (Two one direction and two the opposite).
I covered the bottom side first to have the overlap from the top side appear on the bottom and out of view.
The covering doesn't stick very well to the metal framework so you have to be really careful as you work the first piece on.  Once the top side goes on, and sticks to the first, the covering becomes permanently attached.
Pictures say a thousand words....
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 960
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/11/2012 10:41 PM
SunDevilPilot
Score: 147
Status: offline
Weather turned a little cold a little fast around here but I managed to get the cowl and struts painted as planned.  I think I was pushing the limits of the paint in terms of cold but everything went well.
This Tuesday I will try and get the fuselage recovered and then next weekend I can paint the cream color onto the fuselage.
SunDevilPilot
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 961
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 10:54 AM
VincentJ
Score: 145
Last Login: 5/24/2013
Status: offline
Looks fantastic SDP, just curious, how cold does it get in your part of the world?
VJ
Hide Signatures
       Post #: 962
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 1:38 PM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: VincentJ
On a few occasions in winter it will get down to the 20s-30s.  During the day it warms back up to the 50s.  Not too cold.
That being said, The Klass Kote data sheets recommend painting in weather warmer than 70.  I bettery hurry or I'll miss my window until the end of winter!!
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to VincentJ)
       Post #: 963
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 2:28 PM
Lins
Score: 100
Status: offline
quote:
ORIGINAL: VincentJ
Just curious, how cold does it get in YOUR part of the world?
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 964
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 3:56 PM
VincentJ
Score: 145
Status: offline
Here in Gods' country we'll see temps well below zero, as cold as -10.  I'm sure that is warm in contrast to what you see up in Canada!
VJ
Hide Signatures
(in reply to Lins)
       Post #: 965
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 4:13 PM
Lins
Score: 100
Status: offline
http://www.weatheroffice.gc.ca/forecast/city_e.html?nt-24&unit=i
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 966
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 4:16 PM
Lins
Score: 100
Status: offline
Long building season
Cub Brother #10
Waco Brother #221
Hide Signatures
(in reply to Lins)
       Post #: 967
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 4:50 PM
SunDevilPilot
Score: 147
Status: offline
Weather at our flying field is very localized, thanks to the adjancet mountains.  Today flying was "blown out" so I am back home and will try and get my fusealge recovered a little ahead of schedule.
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to Lins)
       Post #: 968
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 8:17 PM
SunDevilPilot
Score: 147
Status: offline
Bottom recovered...  Lunch, then onto the sides.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 969
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/12/2012 11:21 PM
SunDevilPilot
Score: 147
Status: offline
Just finished up recovering the right side.  Onto the left.
SunDevilPilot
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 970
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/14/2012 2:05 AM
SunDevilPilot
Score: 147
Status: offline
I'm tired..  Started covering  the remainder of the fuselage at around 800 AM.  It is now 700 PM and I just finished putting on the cream color onto the fuselage.  I'm trying to beat the cooler weather of winter.  The cream was a little difficult to spray in the setting sun / cooler temp so I got a few runs on the gear parts.  Fortunately the fuselage was perfect.  I'll sand the flaws on the gear next weekend and touch up those parts.
Now that the cream is on I should be able to tape and paint the red onto the fuselage completing the paintwork next weekend.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 971
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/14/2012 3:23 AM
Zor
Score: 181
Status: offline
You are doing lots of progress and very nice work as always.
Thanks for the pictures.
Zor
Hide Signatures
       Post #: 972
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/14/2012 11:48 AM
VincentJ
Score: 145
Status: offline
Resurrected from the bin !  Won't be long before she takes flight once again.  Nice work, haven't seen you work this fast before...
VJ
Hide Signatures
       Post #: 973
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/14/2012 3:47 PM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: VincentJ
It was, and will be, my favorite plane. I was heartbroken when it crashed. I want it back!
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 974
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build) - 11/14/2012 10:10 PM
WacoNut
Score: 175
Status: offline
Glad to se you didn't scrap it out. Mine was damaged way beyond what your was and I almost rebuilt it but I had a 1/3 kit on the way so I just gave it to a friend and built the 1/3 for myself.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 975
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
