Ready to maiden?...HELP
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
PST Reaction 54 ARF With Radio and Turbine
Seller:  rcguy!
Details:   $4,750.00   |  10/11/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Ready to maiden?...HELP
Page: [1]
Login
Ready to maiden?...HELP - 6/17/2009 10:35 PM
flybyme
Score: 100
Last Login: 11/7/2009
Status: offline
My fifth plane is a Edge 540 with two servos on the  elevator, could someone guide me through setting up my elevators using  a program mix. I have a spektrum dx7 tx, and I'm using a 9 channel spektrum dsm2 receiver.........I was told to use the # 5 or #6 mix, but where do I   plug in my two servos...........one in the elevator slot and the other?...........or do I use a y-harness, or , or, or ............help!!!!!!!!!!!!
I was previously using the AUX 2, and and the elevator channels, but I could not adjust the control throw on the AUX 2 channel..................ready to maiden.......help!!!!!!!!
Hide Signatures
       Post #: 1
RE: Ready to maiden?...HELP - 6/17/2009 10:56 PM
ChuckW
Score: 125
Last Login: 11/8/2009
Status: offline
Yes, you want to use the #5 or #6 mix. With these two, the trim for the master channel also trims the slave, this isn't the case on other mixes.
Plug one servo into the regular elevator spot and the other into Aux-1 or Aux-2.
When you set up the mix, make elevator the master and Aux-1 or Aux-2 the slave. You can control end points and the direction of elevator and your chosen slave channel as needed to get the elevator working correctly. Make sure you set the mix at 100% in both directions.
I believe you also have to disable the switch for the slave channel but I don't remmeber off the top of my head. I can look at a couple of my setups this evening.
Hide Signatures
(in reply to flybyme)
       Post #: 2
RE: Ready to maiden?...HELP - 6/18/2009 12:02 AM
CGRetired
Score: 110
Status: offline
Or you can save all that and simply use a Y cable.  I have four planes with an aileron servo on each side and use the Y cable and all of them work just fine.
CGr
_____________________________
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to ChuckW)
       Post #: 3
RE: Ready to maiden?...HELP - 6/18/2009 1:17 AM
flybyme
Score: 100
Status: offline
Yes I have a y-harness on ailerons, I'm trying to connect and adjust the throw on the elevators. With a y-harness on it, the elevators operate in opposite directions.
Hide Signatures
(in reply to CGRetired)
       Post #: 4
RE: Ready to maiden?...HELP - 6/18/2009 1:25 AM
flybyme
Score: 100
Status: offline
connections are to elevator slot and aux 2. the servo going to the elevator slot works fine, but the servo going to the aux 2 slot operates in only one direction, how do I change the direction of the  aux 2 servo.
Hide Signatures
       Post #: 5
RE: Ready to maiden?...HELP - 6/18/2009 4:02 AM
ohnoucdat
Score: 105
Status: online
flybyme
     Go to HH site and look up mixes and radio set ups for your DX7. I found everything I needed there when I set up my Fliton Edge 540. Hope this helps
Hide Signatures
       Post #: 6
RE: Ready to maiden?...HELP - 6/18/2009 4:33 AM
ChuckW
Score: 125
Status: offline
quote:
ORIGINAL: flybyme
Just go into the reversing menu and reverse aux-2. You can reverse every channel on the DX-7.
Edit: Just re-read your post and see what you are saying. I'll take a look at one of my setups. if not tonight, definitely tomorrow. I just can't remember off the top of my head.
< Message edited by ChuckW -- 6/18/2009 4:35 AM >
Hide Signatures
       Post #: 7
RE: Ready to maiden?...HELP - 6/18/2009 3:58 PM
ChuckW
Score: 125
Status: offline
Wife had me doinf stuff to prep for upcomign trip last night. I'll take alook today though.
Hide Signatures
       Post #: 8
RE: Ready to maiden?...HELP - 6/18/2009 4:18 PM
DadsToysBG
Score: 100
Status: offline
I don't mean to fault people in their opinions, but someone buys a good radio with the functions to do want he wants and he's told forget it. The dx-7 can also have two channels for the ailerons. This give him diff and expo. Y-harnesses are just a another point of failure. Ask me why i don't use a 4 channel with y's in my jets or why my GS planes use 12 channels to fly a 4 channel 40% plane with  11 servos. But that just me. I also like power steering and air in my car too. O yes and power brakes, and the GPS so i don't get lost. I never did like looking at a map. And my wife said i wouldn't ask directions. Dennis
Dads Toys. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 9
RE: Ready to maiden?...HELP - 6/18/2009 6:06 PM
Gray Beard
Score: 131
Status: offline
No kidding, why would anyone buy a good radio then start using Ys to make things work?? If that's the thinking then any old 4 ch. would be the radio of choice. There are reasons to have a good radio and not having to use all the old school crap is one of the big reasons! Use the radio the way it was designed to be used.
quote:
ORIGINAL: DadsToysBG
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to DadsToysBG)
       Post #: 10
RE: Ready to maiden?...HELP - 6/18/2009 6:37 PM
ohnoucdat
Score: 105
Status: online
I can tell ya why. I call it KISS (Keep It Simple Stupid) I have several radios and I know I don't use them to there full capabilities, I just did what this gentelman is doing setting up dual elevator servos, got help here and was sent to a site with the programming I needed for my radio. Works great, happy I didn't have to use reverser, but the rest of my planes I stay with KISS, maybe later I'll use some of the radios extra features, but right now I'm flying the plane ( I should say trying to fly)  not the computer / radio and KISS works for me.
Hide Signatures
(in reply to Gray Beard)
       Post #: 11
RE: Ready to maiden?...HELP - 6/18/2009 10:10 PM
ChuckW
Score: 125
Status: offline
OK, here is what I've been doing...
1- From the main menu where you program the name of the airplane and stuff, disable the switch for the slave channel you are intending to use. In my picture I have both the flap (aux-1) and aux-2 channels set to INH since I'm using both dual elevator and dual aileron servos. Doing this insures that bumping the switch won't affect one of your surfaces.
2- In the regular adjustment menu turn on mix #5 or #6. Select the elevator as the master and the desired channel as the slave. In this case I am using the flap (aux-1) channel for my second elevator servo so I have flap set up as the slave. Make sure you set the mix percentage in BOTH directions. In my case the linkages were dead on so 100% in each direction did the trick.
If you need to reverse one channel, just do it in the regular reversing screen. You can also control end points for each elevator channel separately to fine tune everything althoug I'd do it as best possible mechanically first.
This may not be the correct or the best way but I know it works.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Ready to maiden?...HELP - 6/19/2009 2:29 AM
flybyme
Score: 100
Status: offline
Thanks everyone for your support and info.............I now have functioning elevators using no. 6 mix, as of last night...............looking to maiden Saturday morning.
Hide Signatures
       Post #: 13
RE: Ready to maiden?...HELP - 6/26/2009 1:19 AM
flybyme
Score: 100
Status: offline
Hi guys, one more problem I forgot to mention, how do I set up my throttle on my dx7, that will allow me to have full travel on my transmitter, because from both carb and trx at closed throttle when I go to full throttle my sticks on my tx are at 50% and my throttle is full open................................help
Hide Signatures
       Post #: 14
RE: Ready to maiden?...HELP - 6/26/2009 6:53 AM
DC12VOLT
Score: 110
Last Login: 10/26/2009
Status: offline
That isn't the radio necessarily. Try moving the throttle rod going into the servo from whatever hole it's at now to the closest one to the middle of the servo. If that doesn't do it, move the throttle rod going to the throttle on the carb farther out from the middle.
WARNING: I ask a lot of questions, and I am almost GUARANTEED to go off-topic (or use parenthesis)!
Hide Signatures
       Post #: 15
RE: Ready to maiden?...HELP - 6/26/2009 10:42 PM
flybyme
Score: 100
Status: offline
Got it! thanks
Hide Signatures
(in reply to DC12VOLT)
       Post #: 16
RE: Ready to maiden?...HELP - 6/28/2009 8:29 AM
DC12VOLT
Score: 110
Status: offline
Yeah, I had to mess with my control rods at least 6 times before I got just the right combination.
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.938RCU1
