TexasSkyPilot
Score: 438 Joined: 2/2/2004 Last Login: 5/17/2013 From: San Antonio,
TX, USA Status: offline
I L-O-V-E mine. I have two of them, one for three years, and the other for about a year now, but to be honest, I just started it for the first time this weekend. Easy, simple to use, they work great and start every time. As you can see, I've had very few problems with mine, and a spark plug failing is NGK's problem, not Syssa'a. They make a Champion plug replacement, and I'm going to check them out. The NGK is 4.39 each, and the Champs are 8.99 each. But the difference may be worth it. In three years, I've replaced two plugs, so it's not exactly what you'd call an issue. In the early days of these Syssas, some of the guys had problems with mufflers coming loose, but I wasn't one of them. I had one come loose a few weeks back (first time ever), and found out they have a replacement muffler that bolts on differently, and solves the problem completely. I bought two, and mounted both. Starting up my newer one this week, I found it has a great sound. DLE 30 guys have reported some of the mufflers breaking, cracking from the vibration. J-Tec mufflers, I believe; wraparounds used to give it the same Pitts-muffler look that the Syssa comes stock with. Issues I've dealt with: Mounting to the firewall. I've had my bolts vibrate out. No matter what engine you run, no matter whose mounts you use, you have to mount it to the firewall, and you use the same dang screws to do it with. I identified the problem as the hole being slightly tight, and screwing the bolt through the tight hole wiped all the locktite off the bolt. That's not Syssa, that's the moron with the drill (me). Solved this by removing the standoffs entirely, using red locktite on the screws (already through the firewall), and screwing the standoffs onto that. THAT won't come loose. The more I screw up, the smarter I gets. You won't find a nicer engine anywhere. I promise you. I think that most of the time you'll find that attention to detail is where the problems lie. If a guy is careful, dots all his i's, crosses his T's, double-checks everything, his likelihood of succeeding increases exponentially. If the guys at your field really can't stand their Syssa and want to sell it, I'd like to buy it. The one still in the box sounds good. I'm not kidding. If one of them wants to sell his, I'd like to buy it. Thanks! ~ Jim ~
_____________________________
J.M. Surra, author of AERODYNAMIC, and T.I.T.O.R. - In July of 1947, something crashed in Roswell, New Mexico. . .
Hide Signatures
