RE: SYSSA 30CC GAS MADE IN USA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: SYSSA 30CC GAS MADE IN USA
Page: <<   < prev  220 221 222 223 224 225 226 [227] 228 229   next >   >>
Login
RE: SYSSA 30CC GAS MADE IN USA - 1/17/2013 11:45 PM
Joystick TX
Score: 170
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: Syssa Pilot
Ordered mine,#5 on Jan 9. Recieved it on Jan 12. Good service I think .
Wow, wish I had that many.
Did you set your spark plug gap to .025 like someone on here recommended? They said it made the low end carb adjusment less sensitive.
I just set the gap on my engine today, but I didn't get a chance to try it out. It was set to .018 before. Hope it works.
_____________________________
Steve
Check Six!
Hide Signatures
(in reply to Syssa Pilot)
       Post #: 5651
RE: SYSSA 30CC GAS MADE IN USA - 1/18/2013 2:28 AM  1 votes
ahicks
Score: 669
Last Login: 5/22/2013
Status: offline
I've made that suggestion before (setting the plug to .025), but usually it would be in reference to mid range burbling? Sounds like a bunch of BS, but it's pretty effective! That said, cleaning up the idle with that move might be a bonus? Opening the gap up is about helping the plug to run cleaner in a rich environment - which pretty well describes how most of my gassers are set on the idle at least!
Iridium plugs, well that's their specialty - cleaning up a rich idle. That's about all they're good for, so many don't like spending the money on them just to help handle that.
Hide Signatures
(in reply to Joystick TX)
       Post #: 5652
RE: SYSSA 30CC GAS MADE IN USA - 1/18/2013 3:37 PM
Red Raider
Score: 105
Last Login: 5/19/2013
Status: offline
For what it's worth, I've been experimenting with different props. The 18x6 Vess and Xoar work really well. An 18x10 wood prop like the top-flite or Menz is too much and will cause the engine to over heat especially in a cowled application. Plus the static thrust goes down along with the rpm. BUT, I have the Biella 18x10 carbon prop on an RC Guys Cessna 150 and it is perfect. I fly that thing like a sport plane, throwing it all over the sky, great big loops, slow rolls, stall turns and snaps. It slows down so much on landing that I have to use 1/4 throttle until I'm just about on the ground. Chief Aircraft sells them for about $38. A little pricey, but at least for this particular airframe is well worth it.
SS
Fly it like you stole it
Hide Signatures
(in reply to Zippi)
       Post #: 5653
RE: SYSSA 30CC GAS MADE IN USA - 1/18/2013 3:41 PM
Red Raider
Score: 105
Status: offline
I've gone all the way to .030 and it works well. In fact, I got an engine back from Todd, and no matter what I did, it wouldn't start. Pulled the plug and thought it looked like it was a little tight. Gapped it to .030 and it started on the first flip. I think the spark plug gap must be more critical to this engine than it is maybe for other engines. Has anyone done any testing with different gaps? If not, I may set up one of my engines on the test stand and run it with different plugs and gaps and see if anything turns up.
SS
Hide Signatures
(in reply to ahicks)
       Post #: 5654
RE: SYSSA 30CC GAS MADE IN USA - 1/18/2013 3:56 PM
Joystick TX
Score: 170
Status: offline
I usually go with what the plug manufacturer recommends, but there are a lot of variables with the engine design and the ignition used that may make it necessary to change the gap.
Steve
Check Six!
Hide Signatures
(in reply to Red Raider)
       Post #: 5655
RE: SYSSA 30CC GAS MADE IN USA - 1/20/2013 1:30 AM
moto-x
Score: 100
Last Login: 5/20/2013
Status: offline
A few pics I promised of the 70" AJ Slick from 3D hobbies with the SAP 180.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
It's about to get real ugly.
Hide Signatures
       Post #: 5656
RE: SYSSA 30CC GAS MADE IN USA - 1/20/2013 3:59 AM
bob418
Score: 100
Status: offline
Just a picture of the "twins" 70" velox's both with Syssa 30cc engines!!
Love these engines!!
Click for fullsize
Hide Signatures
       Post #: 5657
RE: SYSSA 30CC GAS MADE IN USA - 1/21/2013 3:32 AM
Joystick TX
Score: 170
Status: offline
Wow, great looking planes.
Temp was 71 degrees and very light winds. Really good day for late January even though it was 41 degrees for my first flight today. Got in several great flights. Didn't notice any difference in the engine performance with the plug gap at .025. Did not need to make any carb adjustments. The engine ran perfectly, so will keep the gap there since I tend to run mine a little rich.
Steve
Check Six!
Hide Signatures
(in reply to bob418)
       Post #: 5658
RE: SYSSA 30CC GAS MADE IN USA - 1/22/2013 9:57 PM
bob418
Score: 100
Status: offline
quote:
ORIGINAL: Joystick TX
Lets see here it is sunny and light winds, and was -6 at 10am! NO flying for me today!! BUMMER!!!
Hide Signatures
       Post #: 5659
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 12:28 AM
Scooterpilot
Score: 130
Last Login: 5/9/2013
Status: offline
Anyone have pictures of how you set up your choke to open and close it. I'm having problems coming up with with something for my 25%MSXR
Chuck AKA Scooterpilot
Magnum Fuels, Syngery N-9
Hide Signatures
       Post #: 5660
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 12:53 AM
Joystick TX
Score: 170
Status: offline
Pictures of my setup are in my gallery. I started off with a servo to move the nyrod, but now I just operate it manually. It is spring loaded to the off position. Since I use the prop rocking method to draw fuel with the choke on I haven't found it necessary to have it lock in an on position. It only takes 6 to 8 rocks of the prop to choke the engine.
Steve
Check Six!
Hide Signatures
(in reply to Scooterpilot)
       Post #: 5661
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 12:54 AM
Joystick TX
Score: 170
Status: offline
I had all of the below zero temps removed from my thermometer when I moved to TX.
Steve
Check Six!
Hide Signatures
       Post #: 5662
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 2:31 AM
Scooterpilot
Score: 130
Status: offline
Joystick TX
Thanks, the pic's help
Hide Signatures
       Post #: 5663
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 2:31 AM  1 votes
ahicks
Score: 669
Status: offline
Gettin pretty sick of it here too.... Florida's looking better all the time!
Hide Signatures
       Post #: 5664
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 2:53 AM
pgmeyer
Score: 165
Status: offline
Heading for Texas in March :-)
Bringing the Syssa powered 25% Pilot RC Extra -
AMA #876027 "Clip-Wing Coupe" Brotherhood #6
Hide Signatures
       Post #: 5665
RE: SYSSA 30CC GAS MADE IN USA - 1/23/2013 3:23 AM
Joystick TX
Score: 170
Status: offline
Wow, Texas in March, you may need to put 10 or 20 pounds of lead ballast in your Extra to keep it from blowing away. If you get to the Fort Worth area, stop by the Greater Southwest RC club, we have a nice grass field that is mowed like a putting green. May have a few bumps left from the hogs digging it up, but we try to keep them smoothed out.
Steve
Check Six!
Hide Signatures
(in reply to pgmeyer)
       Post #: 5666
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 1:19 AM
pgmeyer
Score: 165
Status: offline
Steve,
Thanks - putting greens? Wow, sounds wonderful - you keep those armadillos out? but we will still be rolling south to the area around Temple. I have flown at the nice paved runway near Austin - and of course, the Temple Aero Modelers. Hope to get a few days of calm weather, if not I will just enjoy the warm :-)
There seems to be a plethora RC fields and flying opportunities in Texas, lots of undeveloped flat space-
Paul
Hide Signatures
       Post #: 5667
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 2:13 AM
bob418
Score: 100
Status: offline
quote:
ORIGINAL: Scooterpilot
Here is a video on how my chokes are set up on both of my Syssa, this works out really nice!!    Enjoy!!! Joe (the builder) is a one smart cookie!!
http://www.youtube.com/watch?v=XgD6vS1eo94&list=UUc3zbxJ6Y-HQpuEI6dzDIAw&index=11
Hide Signatures
       Post #: 5668
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 3:17 AM
Scooterpilot
Score: 130
Status: offline
WOW, very nice choke set up .......
Thanks for sharing.
Hide Signatures
       Post #: 5669
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 8:43 AM
JeffinTD
Score: 110
Status: offline
That is pretty snazzy.
I just used a flexible control rod out the bottom, ran through a piece of fuel tubing wrapped with safety wire so it stays where it is set.
Hide Signatures
       Post #: 5670
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 2:05 PM
Syssa Pilot
Score: 105
Last Login: 3/16/2013
Status: offline
I agree with  joystick. just a rod, hold it to prime.  KISS
Hide Signatures
(in reply to JeffinTD)
       Post #: 5671
RE: SYSSA 30CC GAS MADE IN USA - 1/24/2013 6:14 PM  1 votes
ahicks
Score: 669
Status: offline
I got fancy with my push (pull) rod. It has a "J" bend on the end of it. I use that hook to kind of "hang" it on the cowl when I want to close the choke. Unintended bonus is the fact it generally comes unhooked as soon as the engine starts (!) - thus making it an automatic choke? Gotta love it! Often the setup allows for one or 2 flip starts from cold. -Al
Hide Signatures
       Post #: 5672
RE: SYSSA 30CC GAS MADE IN USA - 1/31/2013 2:42 PM
kfla
Score: 100
Status: offline
I call and I call, No answer. Sometimes I get to leave a very nice and polite message, But I never hear back. The message service fills up pretty quick when its empty so I imagine others are trying to contact them aswell. Has anyone recieved any engines from them? Are the V2 engines even out yet? I "orderd" a V2 engine, tone inserts, cdi mount, drill tool and m3 pin drive. It's been 4 months, I'm really starting to wonder Thanks guys for any info.
Hide Signatures
       Post #: 5673
RE: SYSSA 30CC GAS MADE IN USA - 1/31/2013 5:43 PM
Joystick TX
Score: 170
Status: offline
Just got back from flying my GSS with the Syssa 30cc engine. Temps were in the 30's at the start, but at least the winds were calm. Seems like there were no ill efects from opening up the spark plug gap. The engine runs great as usual.
Steve
Check Six!
Hide Signatures
(in reply to kfla)
       Post #: 5674
RE: SYSSA 30CC GAS MADE IN USA - 1/31/2013 5:56 PM
Jim Henley
Score: 120
Status: offline
Steve, I have not been able to get out due to the weather however, the last time I flew the Super Stearman, it seemed to have a better low end response with the wider plug gap.
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
       Post #: 5675
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: SYSSA 30CC GAS MADE IN USA
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
