Strange Thing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Strange Thing
Page: [1]
Login
Strange Thing - 6/20/2009 1:38 AM
h1979pk
Score: 100
Last Login: 11/15/2012
Status: offline
I have been flying Hobby Zone Firebird Phantom for the last 6 months. 2 days ago it acted very strangely. After 5 to 10 seconds of flying suddenly it took very sharp right turn with nose down and then it hit the ground. I thought it could be my mistake. I flew it again and it did same thing again. I then checked the controls. Everything was working fine on ground. I flew it again and it did same thing again. I thought it could be range problem. I then checked the range and it was ok. All this is very strange to me. Does any know what is the cause of problem? I will really appricate if anyone can help.
Hide Signatures
       Post #: 1
RE: Strange Thing - 6/20/2009 4:15 AM
safeTwire
Score: 100
Last Login: 7/1/2012
Status: offline
Are your Transmitter batteries fresh?
If they are fading, they might allow for good control up close, but when you fly out and  increase distance/range, they can't deliver enough to maintain control.
Hide Signatures
(in reply to h1979pk)
       Post #: 2
RE: Strange Thing - 6/20/2009 2:44 PM
h1979pk
Score: 100
Status: offline
yes, transmitter batteries are fresh.
Hide Signatures
(in reply to safeTwire)
       Post #: 3
RE: Strange Thing - 6/20/2009 3:16 PM
safeTwire
Score: 100
Status: offline
How about a renge test. If that checks out ok,  there is mention about adjusting flap position and stick trim lever in the troubleshooting section of the manual.
Is the rx antenna ok?
Hide Signatures
       Post #: 4
RE: Strange Thing - 6/20/2009 5:08 PM
h1979pk
Score: 100
Status: offline
Antina is ok i think because i tested range and it was perfect.
Hide Signatures
       Post #: 5
RE: Strange Thing - 6/20/2009 5:53 PM
allans
Score: 105
Last Login: 5/24/2013
Status: offline
Did you check the Rx batts? Are you using a 2.4 gig system. Your symtoms match low voltage dip conditon and the subsequent response . The Rx does not alwyas reset it upon seeing low voltage. The voltage dip may not be low enough to cause a reset. But it can cause the symptomes you describe without going in to fail safe. But then maybe it did and came out when the voltage came back up.
Is your batt ok? How do you know? How many digital servos are you using?
Interested in you response.
Allan
_____________________________
BLACK DIRT SQUADRON ( Most Beautiful R/C Field in North America) http://www.blackdirtsquadron.org/
Hide Signatures
       Post #: 6
RE: Strange Thing - 6/20/2009 6:03 PM
h1979pk
Score: 100
Status: offline
I have tried to different batteries. 2 servos
Hide Signatures
(in reply to allans)
       Post #: 7
RE: Strange Thing - 6/20/2009 6:06 PM
safeTwire
Score: 100
Status: offline
Page 22 of manual are adjustments for unwanted turning. Did you try those?
Hide Signatures
       Post #: 8
RE: Strange Thing - 6/20/2009 6:09 PM
allans
Score: 105
Status: offline
Did you do forming charge on the NiMH batts ? Suggest 3 full cycles ( Loaded discarge and slow charge(c/10)).
Just a thought.
Allan
Hide Signatures
       Post #: 9
RE: Strange Thing - 6/20/2009 6:10 PM
h1979pk
Score: 100
Status: offline
yes i have tried those as well. But i dont think its relevant to that, coz plane flies ok (straight) for 5 to 10 seconds and then suddenly it takes sharp right turn with nose down.
Hide Signatures
       Post #: 10
RE: Strange Thing - 6/20/2009 6:13 PM
h1979pk
Score: 100
Status: offline
that day i did the same. discharged the batteries and recharged them slowly. with both batteries same thing happened.
Hide Signatures
       Post #: 11
RE: Strange Thing - 6/20/2009 8:42 PM
safeTwire
Score: 100
Status: offline
Wing moving in flight...Have the rubberbands stretched? Maybe try new and add a few more?
How was the wind on that day? Stonger ? Coming from the left?
Did you try a flight yet with the "ACT" turned off?
Hide Signatures
       Post #: 12
RE: Strange Thing - 6/20/2009 10:14 PM
h1979pk
Score: 100
Status: offline
That was very calm day. No wind. ACT on and off, checked with both. Same thing happened.
Hide Signatures
       Post #: 13
RE: Strange Thing - 6/20/2009 11:12 PM
safeTwire
Score: 100
Status: offline
Maybe a call to the factory might help?
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
