1/7th F-14D Scratch build thread *building started*
My Feedback: (23)
Go here for the beginning of the build:
http://www.rcuniverse.com/forum/m_88...mpage_3/tm.htm
So i have begun the build of a 1/7th scale F-14. Some are probly going "why, xxxx company has one / will have one coming out".. Main reason... mostly b/c i want to But some other reasons are b/c on some of the others i have seen pictures of, some of them have some scale defencies, engineering i just personally dont like, to small of size, etc etc. So thats the reason for this. I'm planning on doing this "harold huff" style w/ plugs that are lithoplated, then molds and an all composite airframe. I was lucky enough to get a set of plans from Mike Emilio at http://www.cmsmithplans.com/html/catalog.html to get a head start. I've been stocking up on books and other materials for scale documentation as well. I've been working on some of the mechanical stuff in cad for the past couple of weeks, and just recently got started on some of the saw dust making procedures. I plan to keep this thread updated with new pictures through-out the entire build as i'm wanting to make this an "extreme" scale model that will have a quality in par with the airworld stuff. I am "thinking" of selling some airframes once the molds are complete to offset some of the cost as well, but honestly For this to happen i'd need to raise of hands of who would be interested in a high quality scale Tomcat and a price range they feel would be reasonable.
I'm planning for the model to have scale hinging flaps and leading edge slats. I still haven't decided how I want to actuate the leading edge slats and speed brakes.. but a hausl hydraulic system for these along with the landing gear are in my mind as one of the easiest ways...
Ok, enough of the rambling.. here's some pictures: Any questions, or comments are of course welcome and highly encouraged. If you have any documentation of a F-14D and willing to share, please let me know, as i'm always looking for more.
My Feedback: (12)
RE: 1/7th F-14D Scratch build thread *building started*
Awesome Thomas, I am doing the same thing right but haven't started my thread, soon though, soon!!!;-) Looks good, how did you cut out your formers? I plan on laser cutting out mine for better accuracy. I have access to a CNC router now as well but it cannot do sharp corners. Looking forward to this build!!
Great start invertmast! Looks like it's gonna be a very involved build but one that will be more than worth it. I have the 1/10 Lazer Lizard kit awaiting a build and yours might just be the insperation I need to get it going!
Good luck with it and I like many others who have subscribed to your build thread,really looking forward to seeing this awesome bird develop.
All the best,
Nigel
All the best,
Nigel
OH
Great project, don't let anyone stop you.
Here are pics of someone who did the same project just for the fun of it.
William
William
My Feedback: (23)
Ian,
i cut out the formers using a good ole hand held jig saw w/ a very fine tooth blade, a dremel scroll saw, and a 1" x 30" table top belt sander. If it hadn't of been for that belt sander, it would of taken me months to get the fuselage bulkheads sanded to size, but with the belt sander it only took about 9 hours to do all 33 bulkheads. I looked into having all my parts laser/cnc cut but no one had a table large enough to keep the fuselage bulkheads in 1 piece (largest bulkhead is 12" tall x 36" wide) and all wanted to use birchply. Since the bulkheads are for the plug, i wasn't worried about weight and more worried about cost.
All of the bulkheads are made out of the 6mm luan plywood from home depot. It took approximately 1 1/2 4x8' sheets.. and at $9.87 a sheet, the price was more than worth it to hand cut them.
Nigel,
The laser lizard shortkit is a great start.. their are some things about that short kit i didn't like when i started on mine that i would of liked done differently b/c its a real pain to build the fuselage around the forward inlets with the small size of the bulkheads in those area's.
William,
thanks for the pics! That is one big airplane. any idea on if it is actually 1/7th or larger? It looks to be around 1/5 scale or so.
Nigel,
William,
My Feedback: (23)
ORIGINAL: NickC5FE
Awesome Thomas, just AWESOME! Good luck hombre!
Quick update:
Tail parts are rough cut and ready for final sanding, started drawing up the parts templates for the wing spoilers and the new building table is done.
I'll get pictures of the tail parts later today once they are done... and if everything goes well today, i should have the majority of the wing ribs cut as well, which will complete the short kit.
Cool! Looks like you have your time pretty much covered for a decade or so!I have quite a few different 3views, dont know which one is the best but you seem to be past this stage anyway.anyone special your looking for?Jonas
My Feedback: (12)
Nice Thomas, thats the same thing I am doing for my bulkheads too. I am using 1/8th inch tempered masonite. Very stable ans then instead of strip planking I am going to fill between the bulkheads with foam and hotwire and sand the rest to shape. I HATE strip planking . I'll be watching bro!!
My Feedback: (23)
ORIGINAL: ianober
Should have the entire short kit cut out by end of today.. i hope!
My Feedback: (12)
True, you just need to be careful when removing the extra foam. I will not be using a hot wire right up against the bulkheads, that would create flat spots. All that will be sanded by hand.
My Feedback: (23)
ORIGINAL: ianober
ahhh very good then... so what are you working on? *hopes its not an F-14*... lol
My Feedback: (23)
ORIGINAL: George
Good luck Thomas, I'll be watching.
George
P.S. Are you going to Liberty Bell?
George
Good question on liberty bell... it really all depends on work.. but i'm going to try and get there..
** Update **
Short kit is 99% complete. all i have to do is cut the spar slots in the wing ribs out and do a wee little bit of sanding in the corners and she'll be ready for construction to begin. Pictures to come later tonight.
My Feedback: (23)
Ok,
here's the pics of the short kit. i've still got to remove the spar cutouts, but other than that the short kit is done. After looking at some detailed photo's and 3 view drawings, i've noticed a very large discrepancy in the line drawings of the plans between the Trailing edge of the wing and horizontal stab. This area should have a inward "sweep" towards the centerline of the fuselage, and the plans are just "straight". This should be a fairly simple task to fix, as all i'll have to do is measure the discrepancy between the 3views and the actual plans and do some math to figure out how far the side of the fuselage needs to be moved in, then just copy the current shape at this new mark and trim to the new dimension and we'll be good to go!..... This is no fault of the designer, as i believe it was intentional to make the building process easier..
Each wing rib is 3/16" balsa, except for the 2 most inward which are 1/8" ply. All of the horizontal tail parts are 1/8" ply. The vertical tails are a combination of 3/8" and 5/16" balsa.. If your wondering why their is only 1 of each part, the parts are actually doubled together so each pair of ribs are identical side to side.
enough of my babbling... here's some pics:
I double checked that side indent Thomas.
The plans will generate a side indent, but could use a bit more.
Geez, , , that's gonna be a real terror for sheeting because of the concave shape.
It should indent inward an additional 3/8" more from the current line.
Sending you a pm showing which formers to adjust. I'll update the master.
My Feedback: (23)
Mike,
thanks for the assistance in making this hopefully "the" best F-14 to come so far. I'm very impressed with the plans and the acceptance of helpful criticism to make them even better! Can't wait to get started on the actual building and see this baby come to life!.
For those lurking on the thread, does anyone know anything about the hausl hydraulic system?
My Feedback: (23)
ORIGINAL: NickC5FE
OOOOOOOOOOOOOHHHHHHHHH- LOTSA WOOD HOMIE!!!!!! HAVE FUN WITH THAT PLANKING!
Hey Thomas- i never received a package from you- did yo send it? If not no worries, just want to make sure it didnt get lost!!
yea, i've figured it out, and so far i'm about about 30 sheets of balsa just to sheet the wings and tails. It takes about 9 sheets per wing panel, 3 sheets per stab x 4 stabs. I'm estimating about 150 sheets of balsa for the fuselage. Not to mention all the balsa "blocks" for the tips, edges, etc..
funny you mention that.. I just got a phone call from the wife saying their was a package for a "nick" on our front porch today. Honestly.. i think she just forgot to ship it to ya. lol So i'll drop it off at the post office when i get back next week.
CA
ORIGINAL: invertmast
Also, if you don't have one of these for documentation, I'd highly suggest you pick one up:
[link=http://cgi.ebay.com/Grumman-F-14A-Tomcat-NATOPS-Flight-Manual-US-Navy_W0QQitemZ310116559296QQcmdZViewItemQQptZLH_De faultDomain_0?hash=item48346329c0&_trksid=p3911.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1240%7C 240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50]Grumman F-14A Tomcat Flight Manual[/link]
I ordered one a few months back...lots of good information!
My Feedback: (23)
The plan is to keep the accuracy to detail as close to the real thing as possible.. The gear i have already decided on where to get and plan to do some resin cast detail parts, but this will probly be after the first one is flying. the gapless OWF (over-wing fairing) is one thing i am highly looking into, as it should be fairly simple.
The wing sealing bag, i'd like to do as well, but i am having a helluva time trying to figure out how to make it happen, as i have no idea where to get the bladder bag made.. then how to inflate and suck it back down. The inflation part is simple, but getting it to suck back down flat is the difficult part, as the only way i can think of making this happen is for it to be stretched over the mounting surface slightly so the tension of the rubber bag pulls it back down.
If i can find a natop manual for the F-14D i'll definitely pick one up, as its on my list of stuff to get for this project.
