CH Ignition    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> CH Ignition
Page: [1]
Login
CH Ignition - 6/24/2009 7:26 AM
Kimhoff
Score: 109
Last Login: 5/18/2013
Status: offline
I bought a CH ignition that has the timing advance built in. CH told me to set the static ignition at 28-32 degrees before TDC? If this is correct how can the igniton retard to anythig less than the seting of 28-32 before TDC. Shouldn't the static timing be set at 4-8 degrees? I can see see how the timing could be advaced from this point based on the engine RPM that could be measured by the time between pulese.
Can anyone help me with this?
Hide Signatures
       Post #: 1
RE: CH Ignition - 6/24/2009 7:38 AM
RC Extreme power
Score: 100
Last Login: 7/30/2009
Status: offline
Why question them, They have been doing ignitions for longer than we have been using gas engines for model planes, It works set at 28 deg.
http://www.rcuniverse.com/forum/m_8868990/tm.htm
Milton
< Message edited by RC Extreme power -- 6/24/2009 7:39 AM >
_____________________________
Importer of high performance RC gas engines
www.rcextremepower.com
Hide Signatures
(in reply to Kimhoff)
       Post #: 2
RE: CH Ignition - 6/24/2009 7:44 AM
w8ye
Score: 318
Last Login: 5/25/2013
Status: offline
The timing doesn't advance. It retards
A fast flip past the sensor will retard it about 16 degrees and it doesn't get to full advance intil up around 4500
If you think about it electronically, it could only retard
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to RC Extreme power)
       Post #: 3
RE: CH Ignition - 6/24/2009 9:32 AM
av8tor1977
Score: 665
Status: offline
Yes, "auto advance" is a misnomer; it should be "auto retard". There is a computer chip in the ignition that senses the speed (or rather time) that the magnet is under the sensor. At very slow rpms, like when you slowly turn it over by hand, the timing is advanced. That way you can set the timing at your desired max advance. When the engine is turning a few hundred rpms, the ignition retards itself for starting and low speed running, then starts advancing as the rpms rise up to where you initially set it when the rpms reach 4000.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to w8ye)
       Post #: 4
RE: CH Ignition - 6/24/2009 9:40 AM  1 votes
tkg
Score: 657
Status: offline
What he said........
TKG
Too much power is just about right.
Hide Signatures
(in reply to av8tor1977)
       Post #: 5
RE: CH Ignition - 6/24/2009 4:54 PM
pe reivers
Score: 646
Status: offline
also what my strobe tests showed.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to tkg)
       Post #: 6
RE: CH Ignition - 6/24/2009 11:39 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: av8tor1977
I will say the description how it works is very good. But any ignition tha advances the timing with the RPM increasing...is a auto advance ignition. Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 7
RE: CH Ignition - 6/25/2009 5:19 AM
av8tor1977
Score: 665
Status: offline
You do love to argue Captain John....
AV8TOR
Hide Signatures
(in reply to captinjohn)
       Post #: 8
RE: CH Ignition - 6/25/2009 9:35 AM  1 votes
tkg
Score: 657
Status: offline
quote:
ORIGINAL: captinjohn
I will say the description how it works is very good. But any ignition that advances the timing with the RPM increasing...is a auto advance ignition. Capt,n
No that is incorrect. An ignition that is an advancer STARTS with the timing around 4-5 deg BTDC. An ignition that is a retarder starts around 30 Deg BTDC and retards the timing at low RPM. As the rpm increases it returns to its starting point. It does not advance, it retards less.
Why don't we just call it Computer Controlled Timing.
< Message edited by tkg -- 6/25/2009 9:36 AM >
TKG
Hide Signatures
       Post #: 9
RE: CH Ignition - 6/25/2009 9:59 AM
av8tor1977
Score: 665
Status: offline
Thanks Terry; I didn't want to "get started" and get into a huge unnecessary discussion about it. Remember the big "Top Dead Center" debate some time ago?
AV8TOR
< Message edited by av8tor1977 -- 6/25/2009 10:00 AM >
Hide Signatures
(in reply to tkg)
       Post #: 10
RE: CH Ignition - 6/25/2009 4:48 PM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: tkg
Terry,
It is good to know if the ignition is an advancer or a retarder if you consider how to set the timing.
Advancers need to have the timing set at between TDC and 6° BTDC
retarders must have a setting of 20° - 35° BTDC, depending on engine make and application.
Some advancers, like the VLACH and Falcon are/were in fact super retarders. Because the pickup signal came too late to fire the same cycle, the signal time was stored and used to fire the next cycle! If I am informed well, they used the mean of the last 10 cycles to do that. When starting, these were fixed timing ignitions, switching to super retarding when the engine was running.
Hide Signatures
(in reply to tkg)
       Post #: 11
RE: CH Ignition - 6/25/2009 6:33 PM
captinjohn
Score: 247
Status: offline
Oh...we had fun with that advance-retard thing...yup tis great to know this stuff. That is why it is a good idea to read as much as you can before you try something new!!! I sometimes reply to postings here & there just to get that extra data placed for new experimenters!!!! Best Regards capt,n
Hide Signatures
(in reply to pe reivers)
       Post #: 12
RE: CH Ignition - 6/25/2009 10:22 PM
pe reivers
Score: 646
Status: offline
Of course ALL electronicaly advanced ignition advance the firing as rpm rise. 'tis just the way how they do it.
Hide Signatures
       Post #: 13
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> CH Ignition
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
