RE: How many rubber bands? and what do you think of this?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> RE: How many rubber bands? and what do you think of this?
Page: <<   < prev  1 [2]
Login
RE: How many rubber bands? and what do you think of this? - 6/25/2009 2:03 PM
bingo field
Score: 105
Last Login: 11/7/2009
Status: offline
Probably just a typo for Talcum powder...
_____________________________
http://www.tailhook.org/AVSLANG.htm
Sign over Ready Room Door: "Complacency Kills" - Thimk
Hide Signatures
(in reply to el_xero)
       Post #: 26
RE: How many rubber bands? and what do you think of this? - 6/25/2009 2:59 PM
Nathan King
Score: 100
Last Login: 9/14/2009
Status: offline
quote:
ORIGINAL: Frank Truter
On my H9 Alpha 40, I used 6 bands in total, not once did I ever have a problem. Keep bands in a bottle of calc powder so not to perish. If bands show the slightest of nicks/cuts,through out. The stationary shop here stocks loads of different size and strenght bands and the cost is basically for free.Using 8 on each side and 4 across seems a bit excessive.
That's odd because that was the exact model I was referencing in my initial post.
Proud to be a pattern pilot!!
WACO Brotherhood #99
Hide Signatures
(in reply to Frank Truter)
       Post #: 27
RE: How many rubber bands? and what do you think of this? - 6/25/2009 4:00 PM
el_xero
Score: 105
Last Login: 11/1/2009
Status: offline
ah ha! thanks
Hide Signatures
(in reply to bingo field)
       Post #: 28
RE: How many rubber bands? and what do you think of this? - 6/27/2009 4:06 AM
beachyboy429
Score: 100
Last Login: 9/1/2009
Status: offline
I also have the H9 Alpha 40 and i put my rubberbands in a little ziplock with baby powder to absorb oil and moisture. I use the rubberbands that came with the RTF kit. I believe its 8. I've only had 4 flights on her so far and definately nothing risky maneuver wise but she seems to fly great!
as far as the EVO trainer system... its perfect so far! Its my first glow engine and its so easy to start its rediculous. I flip it with my finger and it fires first time EVERY time. Had to tweak the high end a little rich after 2 flights but other then that i love it! I cant wait to get her up in the air this weekend! woo
up. up, UP! ouch.
Hide Signatures
       Post #: 29
RE: How many rubber bands? and what do you think of this? - 6/27/2009 4:41 AM
el_xero
Score: 105
Status: offline
aw man tell me about it! I can't wait to see if I can get to fly tomorrow and sunday!!!!!! I've been waiting all week haha.. earlier this week as i was napping i even smelled what I thought was glow fuel! hahaha turns out the neighbours were having a BBQ I called up my trainer and told him he laughed his @$$ of and said "yup thats it right there! You've caught it! It's officially an obsession for you now!"
I felt so welcomed sniff sniffel sniff sniff
Hide Signatures
(in reply to beachyboy429)
       Post #: 30
RE: How many rubber bands? and what do you think of this? - 6/27/2009 11:47 AM
kenaf
Score: 100
Last Login: 11/8/2009
Status: offline
I am surprised that no-one has mentioned an alternative to rubber bands. I found that standard, out of the box type rubber bands, were adversely affected in time by fuel, so I now use 4 (1 each fore and aft and 2 on the diagonal) bands made from an inner tube. I cut them about 8mm wide.
Hide Signatures
       Post #: 31
RE: How many rubber bands? and what do you think of this? - 6/27/2009 12:51 PM
CGRetired
Score: 110
Status: offline
Necessity is the mother of invention, I guess.
Rubber bands are cheap. Some of us just don't have a spare inner tube lying around.
CGr.
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to kenaf)
       Post #: 32
RE: How many rubber bands? and what do you think of this? - 6/27/2009 2:58 PM
el_xero
Score: 105
Status: offline
hmm I might look into that heh! thanks!
Hide Signatures
(in reply to kenaf)
       Post #: 33
RE: How many rubber bands? and what do you think of this? - 6/28/2009 9:26 AM
beachyboy429
Score: 100
Status: offline
quote:
ORIGINAL: CGRetired
CGr.
haha well said.
up. up, UP! ouch.
Hide Signatures
(in reply to CGRetired)
       Post #: 34
RE: How many rubber bands? and what do you think of this? - 6/28/2009 4:33 PM
RegFlyer
Score: 106
Last Login: 8/17/2009
Status: offline
Here is how I check; start with 5 on each side of the wings, hold the fuse down and with the other hand carefully pull up on the end of the wing, if the wing can be lifted from the saddle at all add more rubber bands then use 2-4 diagonally on the wing to hold everything together. Also is there is a good wind add more bands, some may break and cause your wing to come lose or come off! not good JuJu.
AMA#: 926032
Avionics Technician 3rd class, USN
Hide Signatures
       Post #: 35
RE: How many rubber bands? and what do you think of this? - 6/28/2009 5:14 PM
KitBuilder
Score: 110
Status: offline
12 or so as everyone says with at least the last two to keep the others on ... Also which i didnt see mentioned.. you should atlernate where you start the attachement. For instance first two start at the rear.. next two start at the front and switch back and forth. This is because where you start first will have more stress as you pull on it. Also a good idea to hook the band on your dowel, then pull upwards and with it stretched then lay it across the wing and hook to the front or back whichever the case may be. less crushing possible if you don't have proper reinforcing on the leading or trailing edge.
glow fuel will also shorten thier life as well causing loss of elastcicity. I use mine two or 3 times tops if in an area where glo residue can get to them.
< Message edited by KitBuilder -- 6/28/2009 5:16 PM >
Mike -
Kits are made to be bashed
Hide Signatures
       Post #: 36
RE: How many rubber bands? and what do you think of this? - 6/28/2009 10:22 PM
el_xero
Score: 105
Status: offline
some great tips there man thanks! I'll keep em in mind for sure!
Hide Signatures
(in reply to KitBuilder)
       Post #: 37
RE: How many rubber bands? and what do you think of this? - 7/1/2009 3:27 AM
rc airplane nut
Score: 125
Status: offline
When my rubber bands are brand new(never used) I put on 10 total, after 1 to 3 flights I put on 12 and when they get a little stretched out I put on 2 extras.
< Message edited by rc airplane nut -- 7/1/2009 3:28 AM >
"Pull Up Pull Up"
Hide Signatures
       Post #: 38
RE: How many rubber bands? and what do you think of this? - 7/1/2009 7:13 AM
LLD
Score: 100
Status: offline
quote:
ORIGINAL: el_xero
Guys I've often wondered about this but never bothered to ask... How many rubber bands should we use to hold down our wings on our trainers like the PT40 and Avistar?
and what do you guys think of this enging Evolution Trainer Power System: A. sold on horizon hobby?
I've used eight on .25 through .60 size trainers since the mid eighties...I install them as follows:
1) 2 parallel to the fuse
2) 2 crisscross
3) 2 parallel to the fuse
4) 2 crisscross ( the last two being crisscrossed is very important as they will make sure the previous two don't slip off to vibration).
I pre-stretch all rubber band prior to using them...I've had rubber band pop although I check them before each flight. I never had a wing separate using this technique.
Larry Diamond
Hide Signatures
       Post #: 39
RE: How many rubber bands? and what do you think of this? - 7/1/2009 11:54 PM
el_xero
Score: 105
Status: offline
Ah prestretching nice thanks
quote:
ORIGINAL: LLD
quote:
ORIGINAL: el_xero
2) 2 crisscross
Larry Diamond
Hide Signatures
(in reply to LLD)
       Post #: 40
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.000RCU1
