Bent Prop Shaft
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $119.00   |  10/11/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> Bent Prop Shaft
Page: [1]
Login
Bent Prop Shaft - 6/24/2009 8:30 PM
_kyle_
Score: 100
Last Login: 8/5/2009
Status: offline
Hey guys, I had a little trouble after a crash that left my e-flite apprentice with a bent propeller shaft. It has a 15 size brushless motor. The motor still runs and the plane still flies, but it vibrates a ton, especially at a low speed. I was wondering if any of you have any experience with re-aligning the shaft. I have a student work study in a machine shop where I have access to all the tools. Thanks!
Hide Signatures
       Post #: 1
RE: Bent Prop Shaft - 6/24/2009 8:59 PM
mboland
Score: 100
Last Login: 11/8/2009
Status: offline
Disassemble the motor and run the shaft on a straight surface, glass is good, then using a hammer, GENTLY tap the high spots (not on the glass by the way). Keep doing this until you have it flat as you roll it across the glass. Most times it will be straight enough.
Alternatively buy a new shaft and reassemble.
_____________________________
It''s the quality of life that counts, not the quantity.
Hide Signatures
(in reply to _kyle_)
       Post #: 2
RE: Bent Prop Shaft - 6/24/2009 9:32 PM
lejongleur
Score: 100
Last Login: 11/7/2009
Status: offline
If possible, get a new shaft. I see that BL15 motor costs $70 (ouch). If you can't buy the shaft anywhere, call E-Flite. If that doesn't work, you might want to consider getting a similar replacement motor from somewhere cheaper, like hobbycity.com. It will be about 1/3 the price.
Hide Signatures
       Post #: 3
RE: Bent Prop Shaft - 6/25/2009 9:02 AM
frank99
Score: 100
Status: online
need a 4 mm snap ring for my hobby city motor any ideals where to get one, thanks frank
Hide Signatures
(in reply to lejongleur)
       Post #: 4
RE: Bent Prop Shaft - 6/25/2009 2:15 PM
_kyle_
Score: 100
Status: offline
Thank you very much, I will try pulling the motor apart and bending the shaft first. I appreciate the help.
Hide Signatures
(in reply to frank99)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.688RCU1
