C-160 ELECTRIC CONVERSION
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> C-160 ELECTRIC CONVERSION
Page: [1]
Login
C-160 ELECTRIC CONVERSION - 6/25/2009 3:40 PM
Rizlaw
Score: 100
Last Login: 6/26/2009
Status: offline
Hey guy my first post on a project that im very proud of
Ok this is to be my pride and joy the one i can savour.
i think its a cm pro c160 72" wingspan.
fibreglass fuz and balsa covered foam wings
the set up i will install is the following
2x 1100kv 3548 motors
2x 70Amp esc's
1 3s 4800 kokam lipo
seperate 7.4v 2250 lipo for r/x servo with bec
so far i have installed servos towerpro 5010 which at 6v produce 6kg torgue
i have done inital test of motors on 10x7 prop which on 3cell takes about 45amps full throttle at 10000 rpm which equates to 90amp total.
on 2 cell it draws 28 amps full throttle with 7-8000 rpm. totalling 56 amps.
so imy iniotial option will be 800 watts of power and have the option of 400 watts .
im estimating a all up weight of 3kg which is 6.61 lbs this equates to 120 watts per pound which will provide a sporty performance. Its not like i need to do a knife edge wit hthis one eh lads
on 2 cell power it will be lighter but have a ratio of 60 watts per lb which would make it the power of a weak glider.
i mean if this item comes at 2.5kg all up then i have a aerobatic plane etc.
so the build, i have used insulation tape for windows,
motor mounts needed to be extended to allow perfect fit for naccelles.
i used a 1/4 ply to add further strenth to existing mount and som wide piece of ply to cover the 5cm of distance i needed to make up.
have a look at pics and ill keep you posted.
for your info i have used 12 awg wire from speedo to batt and have kept existing 14awg on the speedos, i have used 6mm bullets for all connections for least resistance.
any comments appreciated
Hide Signatures
       Post #: 1
RE: C-160 ELECTRIC CONVERSION - 6/25/2009 4:32 PM
normgoyer
Score: 100
Last Login: 11/6/2009
Status: offline
Photography rule of the thumb: Do not use distracting patterned background as it will tend to take over the subject being photographed. Look at your pix and the first thing you see is the circles on the background.suggest cheap window shades on rollers, the light brown photographs nicely, is neutral and comes in all sizes and then rolls back up for storage. Norm
Hide Signatures
(in reply to Rizlaw)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
