OMP Yak 65"
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> OMP Yak 65" Page: [1]
Login
OMP Yak 65" - 6/26/2009 7:22 PM
mnrcaerobat
Score: 100
Last Login: 11/8/2009
Status: offline
I previously posted in the profile general area. I ended up buying the Yak profile from my LHS. I am going to use all Hitec Digital servos. 5925mg on rudder and elev and 6965hb on ailerons and throttle.
Is this plane intended to have two elevator servos? There is no joiner on the halves.
I bought a YS110 for the plane. I am going to run a 16x6 and 2 1/2" spinner.
What size tank should I get?
_____________________________
Brian
Hide Signatures
       Post #: 1
RE: OMP Yak 65 - 6/26/2009 7:23 PM
mnrcaerobat
Score: 100
Status: offline
Do my servos and motor combo sound correct?
Brian
Hide Signatures
(in reply to mnrcaerobat)
       Post #: 2
RE: OMP Yak 65 - 6/26/2009 10:22 PM
ThumbSkull
Score: 103
Last Login: 11/7/2009
Status: offline
Don't use the spinner. It's a profile. No cowl for the spinner to mate to. Looks silly.
YS 110 is a great motor for it. Servos sound OK.
Mine came with a U shaped wire elevator joiner in the hardware kit. I Like the Hayes 13oz for that motor/plane.
Hide Signatures
       Post #: 3
RE: OMP Yak 65 - 6/26/2009 10:48 PM
mnrcaerobat
Score: 100
Status: offline
Thanks. Do you use a spinner nut?
How long can you fly with the 13 oz tank? Most of the flight is probably at 1/2 throttle, so it is probably pretty decent.
What is the leading of the elevator halves made of? I think I will router it out and put a CF rod in it. I would assume there is tiangle balsa where the elevators meet the stab, but what is next to that on the elevators?
Brian
Hide Signatures
(in reply to ThumbSkull)
       Post #: 4
RE: OMP Yak 65 - 6/27/2009 1:39 AM
AFSalmon
Score: 100
Last Login: 11/6/2009
Status: offline
There was supposed to be a wire joiner for the elevator halves. 1/8" wire shaped like a "U" to join the two. The builder must have left it out. Only one servo required for the elevator.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
       Post #: 5
RE: OMP Yak 65 - 6/27/2009 7:07 AM
ThumbSkull
Score: 103
Status: offline
Spinner nut is OK but the stock locking nut set works great. After my 110 was broken in, I like it best with a 17x4 Xoar or a 16x6 on 25-30%. 13oz gives 10-15 minutes. I don't know what's inside the ele construction. Don't mount the fuel tank solid. Use foam under it and rubber bands.
Hide Signatures
(in reply to AFSalmon)
       Post #: 6
RE: OMP Yak 65 - 6/28/2009 7:12 PM
mnrcaerobat
Score: 100
Status: offline
Does it matter which way I mount the aileron servos? Should the output be towards the leading or trailing edge?
Brian
Hide Signatures
       Post #: 7
RE: OMP Yak 65 - 6/28/2009 11:58 PM
hkilian
Score: 100
Last Login: 10/11/2009
Status: offline
Brian,
A couple on installation comments on the YS 1.10.
Be very careful with the installation into the provided wood rails. In my case they were not well glued into the structure and were shaken loose by this rather powerful motor. I replaced them with a 1/2" plywood U shaped plate that I epoxied into the nose of the plane. On top of that, I put a number of 3-4 thin glass layers on each side of the slab (see pictures). This has worked now for me for over a year without any issues.
The standard tank of 350cc is in fact good for about 10 min., set your timer for no longer, this is a thirsty motor.
Herb, J7
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: OMP Yak 65 - 6/29/2009 12:43 AM
AFSalmon
Score: 100
Status: offline
Herb, I think this one was a kit build and not the ARF. MNRC, does not matter how you mount your ron servos. Your preference but most put the control arm closer to the surface to reduce the pushrod length.
< Message edited by AFSalmon -- 6/30/2009 12:57 PM >
Ohio Model Planes
Hide Signatures
(in reply to hkilian)
       Post #: 9
RE: OMP Yak 65 - 6/29/2009 3:05 AM
ThumbSkull
Score: 103
Status: offline
quote:
ORIGINAL: mnrcaerobat
I can't see how that would matter on any airframe. You could say there is a preference toward the trailing edge to make the control rods shorter.
Hide Signatures
       Post #: 10
RE: OMP Yak 65 - 7/10/2009 12:22 AM
mnrcaerobat
Score: 100
Status: offline
I have a YS 110 to put into this plane. Is the 16x6 a good choice. I have the prop. It is an apc, or is there somthing that works a lot better?
Also, the motor doesnt fit tight in the mount. I can add some light ply. Is it important to keep the motor centered, or can I just add some ply to one side or the other. It appears to be about 1/8 inch.
Do I also need some right thrust on this motor? Is a washer on each side enough to start?
Brian
Hide Signatures
       Post #: 11
RE: OMP Yak 65 - 7/10/2009 1:43 PM
AFSalmon
Score: 100
Status: offline
Don't use light-ply for the motor mount area as it won't last at all. Use good hard aircraft ply or hardwood. A 16-6 is a good prop for the YS110. I used both a 16-4W and a 16-6 with success. Also depends on how much nitro you run. Keep the motor centered in the mount and add about 2-3 degrees of right thrust.
Ohio Model Planes
Hide Signatures
       Post #: 12
RE: OMP Yak 65 - 7/25/2009 4:34 AM
mnrcaerobat
Score: 100
Status: offline
I am getting there. I have the servos mounted. I am going to finish up my linkages tomorrow. I also need to mount my tank.
Where do I need to put the CG on this?
I used to build a kit quicker than this. Now I know what the people meant when they said it was hard to build with kids, wife, job, etc. Plus I had to rebuild my helis. I am trying to fly them inverted.
Brian
Hide Signatures
       Post #: 13
RE: OMP Yak 65 - 7/25/2009 11:25 PM
AFSalmon
Score: 100
Status: offline
The cg on the 65" Yak was 7-8 inches back from the leading edge at the root. Start at the forward location and work back to tailor for your liking.
Ohio Model Planes
Hide Signatures
       Post #: 14
RE: OMP Yak 65 - 7/26/2009 12:49 AM
mnrcaerobat
Score: 100
Status: offline
How do I mount the horn and linkage for the elevator? It seems tight? Or do I have the servos backward? They are both in line with each other and mounted on the same side. Do I need to move the arms for the elevator to the other side? Do I offset it?
Click for fullsize
Brian
Hide Signatures
       Post #: 15
RE: OMP Yak 65 - 7/26/2009 4:28 PM
daveopam
Score: 109
Status: offline
I would mount the elev servo with the arm on the other side of the fuse. With extreme throws in the tail you could have some interference problems.
David
"Never use a big word when a little filthy one will do"
Johnny Carson
Hide Signatures
       Post #: 16
RE: OMP Yak 65 - 7/28/2009 12:51 PM
AFSalmon
Score: 100
Status: offline
Concur with Dave. That was the typical setup....servos facing opposite each other.
Ohio Model Planes
Hide Signatures
(in reply to daveopam)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.719RCU1
