Timer recommendations
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Composite-ARF Yak-55SP 3.3m
Seller:  Edbaker
Details:   $6,500.00   |  10/14/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Timer recommendations
Page: [1]
Login
Timer recommendations - 6/27/2009 3:50 AM
paully_321
Score: 110
Last Login: 9/28/2009
Status: offline
My radio does not have a built in timer...However, I think I would benefit from having one...Does anyone have a recommendation for a standalone timer I could attach to my radio? Obviously something small. I've looked around a bit, but I thought if someone had one they could recommend, that would save me a whole lot of wasted purchases.
Model number and link would be awesome,
Paully
Hide Signatures
       Post #: 1
RE: Timer recommendations - 6/27/2009 4:11 AM
beachyboy429
Score: 100
Last Login: 9/1/2009
Status: offline
got a kitchen time with a clip from Target for like 5 bucks. Its digital and simple to use with a loud beeper. You dont need an LHS for everything ya know
_____________________________
up. up, UP! ouch.
Hide Signatures
(in reply to paully_321)
       Post #: 2
RE: Timer recommendations - 6/27/2009 4:14 AM
RCKen
Score: 166
Last Login: 11/6/2009
Status: online
Ditto the cooking timer. you can get them in the kitchen section of Wal-mart. That's what I used on my older radios that didn't have timers on them.
Ken
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
AMA# 712539 - www.gettingairborne.com
Hide Signatures
(in reply to beachyboy429)
       Post #: 3
RE: Timer recommendations - 6/27/2009 4:51 AM
flaminheli
Score: 100
Last Login: 7/25/2009
Status: offline
My radios have timers but I find myself never using them. I always just look at my watch.
Hide Signatures
(in reply to RCKen)
       Post #: 4
RE: Timer recommendations - 6/27/2009 5:14 AM
jimmyjames213
Score: 120
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: flaminheli
i have a timer but dont usually use it (unless im seeing how long i can stay in the air), just run the plane until you think your out of fuel, you will get a "feel" for it after a gallon or so
i usually fly until i feel like landing, or about ten min. i rarly fly at full throttle so i usually have half a tank left. however when im in the mood to just fly im good at guessing when the tank is almost out.
i fly close to the field so in the event of a dead stick i just land the plane (only happened once because of an empty tank)
since i dont have flight lines i dont need to maximize my flight times. if you do, i would go the timer method, then when the timer goes off gain some altitude, fly till you dead stick and land the plane.
Anything worth doing.............is worth overdoing
Hide Signatures
(in reply to flaminheli)
       Post #: 5
RE: Timer recommendations - 6/27/2009 5:28 AM
rabraaten
Score: 100
Last Login: 11/7/2009
Status: offline
Just fly till you run out....now keep in mind I'm still flying an intermediate trainer. But your approaches and landings get much better much faster when there is no 'go-around' as an option....perfect or you're walking a long ways....
Keep the roundy thingys on the runway...
Hide Signatures
(in reply to jimmyjames213)
       Post #: 6
RE: Timer recommendations - 6/27/2009 7:25 AM
Alex7403
Score: 125
Status: offline
I'm using a "talking timer" it announces every minute how many minuts left.
works for the the second year on the same batteries, attach it to the neck strap or to the hat, couldent be happier.
http://cgi.ebay.com/Talking-Kitchen-Timer-Clock-for-the-Blind-w-Braille-Ins_W0QQitemZ200353628735QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea601c23f&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Ya know a cat appears to be longer if you measure it from tail to head than if you measure it from head to tail.
Hide Signatures
(in reply to rabraaten)
       Post #: 7
RE: Timer recommendations - 6/27/2009 7:49 AM
bigtim
Score: 113
Status: offline
a small digital timer works well, I got mine at Radio Shack the clip eventually broke so I rubber band it to my radio,running out of fuel not a option when flying a warbird, or most any high performance type plane.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Alex7403)
       Post #: 8
RE: Timer recommendations - 6/27/2009 2:33 PM
Dsegal
Score: 111
Status: offline
I use a Radio Shack timer attached to the base of the transmitter antenna with a spring-type wooden clothespin and Radio Shack Superlock strips. Note: this not a hook and loop material but has both halves with rigid plastic tiny fingers that won't let go accidentally.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dsegal -- 6/27/2009 2:35 PM >
Dave Segal
Hide Signatures
       Post #: 9
RE: Timer recommendations - 6/27/2009 4:39 PM
stang
Score: 100
Status: offline
Get the talking timer. They announce every minute the time you have left and in the last minute a female voice announces every ten seconds. Sort of like your own "****in Betty" the fighter jocks have.
Solving problems with the selective application of violence
Hide Signatures
(in reply to Dsegal)
       Post #: 10
RE: Timer recommendations - 6/27/2009 7:13 PM
lnewqban
Score: 115
Status: offline
My timer, from Walmart:
Note the rubber band for the clip.
Click for fullsize
Click for fullsize
< Message edited by lnewqban -- 6/27/2009 7:19 PM >
Lnewqban - - - - http://awesomelycooljuan.com
Just for the joy of flying,.....in good weather,.....among good people
Hide Signatures
(in reply to stang)
       Post #: 11
RE: Timer recommendations - 6/27/2009 8:12 PM
-pkh-
Score: 102
Status: offline
I bought a kitchen timer from the Dollar store for a buck, and epoxied a clothespin to the back of it so I can clip it to my antenna.
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 60, Tribute 36, Two PZ BL P51s, Two F27C Strykers
Hide Signatures
(in reply to lnewqban)
       Post #: 12
RE: Timer recommendations - 6/27/2009 8:45 PM
red head
Score: 100
Status: offline
I have a talking timer and like it for some things, most of my radios also have timers. Now the whole story !! Most of my students use the timer from the dollar store for a buck. It works great and I even use it now and then. BEST DEAL going.
ENJOY !!! RED
Hide Signatures
(in reply to -pkh-)
       Post #: 13
RE: Timer recommendations - 6/27/2009 11:46 PM
Hareman
Score: 100
Last Login: 11/2/2009
Status: offline
If you have a "Dollar Tree" store near you, get the 99 minute kitchen timer. For a dollar, you can't beat it. Everything in the store is only a dollar.
Hide Signatures
(in reply to red head)
       Post #: 14
RE: Timer recommendations - 6/27/2009 11:48 PM
Mikecam
Score: 108
Status: offline
I like the timer on my radio. 7C. Only counts when the throttle is 1/4 or more and the radio remembers the time I have programed for a particular model. Some 8 minutes and some up to 14 minutes.
Hide Signatures
       Post #: 15
RE: Timer recommendations - 6/28/2009 1:46 AM
tony0707
Score: 100
Status: offline
hi do fly with a timer -never know were on the field you will run out of fuel go dead stick and risk the plane-i purchased a clear syringe from the hobby shop-that is calculated in ozsEX-if you have a 10oz tank and you use 5ozs in 5 minutesyou now draw out the fuel left in the tank with the syring- in this case it would be 5ozs so you know you can fly a total of 10 minutes max on this planes tank of fuel the syringe is very useful if you have a sudden abrupt landing as the clunk in the tank can be jammed foward in the fuel tank-if you draw fuel out with the syringeand get air not fuel- good chance the clunk has been jammed to the front of the tank-and needs to be relocated to the rear of the tank-(by shaking it loose )-the result of the clunk being to the front of the tank are short unexplained engine runs on take off
Hide Signatures
(in reply to Mikecam)
       Post #: 16
RE: Timer recommendations - 6/28/2009 8:26 AM
DC12VOLT
Score: 110
Last Login: 10/26/2009
Status: offline
I taped the "Chronometer" from my dad's old '78 Chrysler LeBaron onto my radio, and I can run it off the radio's battery! When the display gets dimmer, I know I'm running out of batteries. And we scrapped the car, so the clock and the carb from that car are all we have left of it...
WARNING: I ask a lot of questions, and I am almost GUARANTEED to go off-topic (or use parenthesis)!
Hide Signatures
(in reply to tony0707)
       Post #: 17
RE: Timer recommendations - 6/29/2009 6:54 AM
Korps
Score: 110
Status: offline
Cellphone? I use my countdown timer on my cellphone - the alarm when the set time has run out almost sounds like a danger alarm inside an aircraft
Watch out! Dead Man Flying!
Hide Signatures
(in reply to DC12VOLT)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.516RCU1
