RE: NEW DLE30!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Page: <<   < prev  191 192 [193] 194 195 196 197 198 199 200   next >   >>
Login
RE: NEW DLE30! - 9/23/2011 5:04 AM
FOOPED
Score: 105
Last Login: 5/25/2013
Status: offline
There are a lot of pro and cons on oil breakin and changes after breakin.
Hide Signatures
(in reply to cloudancer03)
       Post #: 4801
RE: NEW DLE30! - 9/23/2011 5:32 AM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
quote:
ORIGINAL: cloudancer03
sort of curious .when you start the new engine in my case a dle30 after say a couple gallons do you ever change the ratio of oil to gas mix.does the time of season ever play into your decision??
Nope, 32:1 from the first run then on forever, summer, winter, fall or spring, rain, hail, sleet, snow, or shine. Your engine will thank you for it.
_____________________________
Now go outside and play
Hide Signatures
       Post #: 4802
RE: NEW DLE30! - 9/23/2011 2:10 PM
cloudancer03
Score: 122
Last Login: 5/14/2013
Status: offline
hey there .hows your new digs going.nice of you to chime in.I asked that question because I had my generator serviced and the tech mentioned to put in 30 wt. oil for the upcoming winter.so I wondered if flying in really cold weather affected 2 stroke gassers.I am using sthil ultra oil mixed with regular gas.hoping to fire it up later today or sat.
Hide Signatures
(in reply to jedijody)
       Post #: 4803
RE: NEW DLE30! - 9/23/2011 2:13 PM
cloudancer03
Score: 122
Status: offline
I see you guys are in some instances using wood standoffs.is there a approx length where its better to just to go with barstock alumimun.??
Hide Signatures
       Post #: 4804
RE: NEW DLE30! - 11/8/2011 5:34 PM
tail heavy
Score: 105
Status: offline
I need some ideas about my DLE 30 rear carb. I am running it in a GP Giant Super Sportster with a Xoar 19X8 prop. Stihl Ultra HP at 32:1. The problem is that it dies every time I go into an inverted nose down position. Battery is a 2 cell LiFe pack for the complete system. Rx and ignition. Voltage is reduced to approx. 5 volts via diodes for the ignition. I can fly it level inverted without problems. If I attempt to do an inverted flat spin, it quits every time.
I believe the needles are set appropriately. But possibly just a touch rich on the high side.
Any suggestions would be appreciated.
Thanks....Alan
"No mans life, liberty, or property are safe while the Congress is in session." - Mark Twain
Hide Signatures
       Post #: 4805
RE: NEW DLE30! - 11/8/2011 6:17 PM
greg palmer
Score: 100
Last Login: 4/2/2013
Status: offline
I had the same problem. When I would do blender and come up on the power flame out. I talked to jedi jody at VVRC the master, and he told me to richen the low end even though I had good throttle transition, well it fixed the problem.
Hide Signatures
(in reply to tail heavy)
       Post #: 4806
RE: NEW DLE30! - 11/8/2011 9:04 PM
kgeb
Score: 111
Last Login: 2/7/2013
Status: offline
I will second the richen low speed needle. fixed al three of mine
Hide Signatures
(in reply to greg palmer)
       Post #: 4807
RE: NEW DLE30! - 11/8/2011 11:19 PM
tail heavy
Score: 105
Status: offline
Thanks guys. really had me stumped as my DLE 20's run perfectly regardless of the plane's attitude. The weather here is wet due to rain. Will try to fly again on Saturday or Sunday. Will let you know if this was the problem.
Thanks again.....Alan
< Message edited by tail heavy -- 11/9/2011 4:01 AM >
Hide Signatures
(in reply to kgeb)
       Post #: 4808
RE: NEW DLE30! - 11/8/2011 11:52 PM
kgeb
Score: 111
Status: offline
It doesnt take much. Screw driver blade width richer is about all it takes. Do a little at a time!
Hide Signatures
       Post #: 4809
RE: NEW DLE30! - 11/9/2011 6:09 PM
Mpizpilot
Score: 100
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: jedijody
Jody, whats your choice of oil? I've got all sorts, amsoil, lawn boy, pennzoil(my personal fav)
Hide Signatures
       Post #: 4810
RE: NEW DLE30! - 11/9/2011 7:41 PM
cloudancer03
Score: 122
Status: offline
everything sounds good .if you richen the motor a tad bit more you will solve the issue.
Hide Signatures
(in reply to Mpizpilot)
       Post #: 4811
RE: NEW DLE30! - 11/9/2011 7:54 PM
GSK
Score: 105
Last Login: 5/3/2013
Status: offline
   I have found that black smoke coming out of the exhaust at idle works for me , best test is that the motor always comes back to a nice idle after giving the motor heaps  during the flight .
Graeme
Hide Signatures
       Post #: 4812
RE: NEW DLE30! - 11/12/2011 5:05 AM
tail heavy
Score: 105
Status: offline
I got a chance to fly today. I richened the low end a bit and the engine did not die, but still sagged badly. Adjusted again a bit more rich and the sagging was gone.
Thanks for the help gentlemen. It is much appreciated.
Alan
Hide Signatures
(in reply to GSK)
       Post #: 4813
RE: NEW DLE30! - 12/10/2011 1:01 AM
Sbach342Guy
Score: 100
Status: offline
What is a good carbon prop for this engine (size, pitch) ?
Hide Signatures
       Post #: 4814
RE: NEW DLE30! - 12/10/2011 1:30 AM
raubold
Score: 105
Status: offline
18X8 Mejchlic, works great for me
Carl Goldberg Ultimate Brotherhood member 26
Hide Signatures
(in reply to Sbach342Guy)
       Post #: 4815
RE: NEW DLE30! - 12/10/2011 1:53 AM  1 votes
tail heavy
Score: 105
Status: offline
My Giant Super Sportster and my Giant Big Stick fly great with Xoar 19X8's
Hide Signatures
       Post #: 4816
RE: NEW DLE30! - 12/10/2011 3:10 AM
microdon2
Score: 110
Last Login: 5/24/2013
Status: offline
tailheavy - I'm thinking of transitioning from APC to Xoar props, but the carbon fiber are a bit too pricey for me. Are the Xoar wood props also more efficient than APC also? Seems they're about the same price. I'm a little concerned over the wood being more fragile in ground strikes, too. Any feedback is appreciated.
Hide Signatures
       Post #: 4817
RE: NEW DLE30! - 12/10/2011 4:13 AM
raubold
Score: 105
Status: offline
APC does not wind up like wood, recommendation , don't strike the ground, XOAR's work just fine
Hide Signatures
(in reply to microdon2)
       Post #: 4818
RE: NEW DLE30! - 12/10/2011 4:28 AM
tail heavy
Score: 105
Status: offline
I have had good luck with Xoar. I prefer wood over because they spool up faster and in case of a ground strike, they will break before bending the crank.
I learned that from experience with a Zenoah 23.
Hide Signatures
       Post #: 4819
RE: NEW DLE30! - 12/10/2011 5:04 AM
microdon2
Score: 110
Status: offline
Thanks. I'll try the Xoars. And try to avoid ground strikes. (just like I try to avoid low-altitude stalls, outright crashes, flying in a cross-wind...)
Hide Signatures
       Post #: 4820
RE: NEW DLE30! - 12/10/2011 3:42 PM
captinjohn
Score: 247
Status: offline
NO REPLY BUT...This thread is getting kinda long.  What do you guys think.  Can we start a new thread start about January 1st of the new year?   It may Have a title  "New DLE 30cc engine...Part 2"  As thread goes on it is easy to ...cut copy and past just the real imformative parts of the old thread.   What say ye?
Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 4821
RE: NEW DLE30! - 12/10/2011 3:45 PM
raubold
Score: 105
Status: offline
quote:
ORIGINAL: captinjohn
NO REPLY BUT...This thread is getting kinda long.  What do you guys think.  Can we start a new thread start about January 1st of the new year?   It may Have a title  ''New DLE 30cc engine...Part 2''  As thread goes on it is easy to ...cut copy and past just the real imformative parts of the old thread.   What say ye?
Capt,n
Yehh, we copy and paste the old and important infos then right ?
Hide Signatures
(in reply to captinjohn)
       Post #: 4822
RE: NEW DLE30! - 12/10/2011 4:52 PM
captinjohn
Score: 247
Status: offline
Yup...just the data....sometimes have links.  Thanks for any and all Ideas.  It would be great to make this smoother and more easy.....somehow.  We need people to help that have great computor skills.
Hide Signatures
(in reply to raubold)
       Post #: 4823
RE: NEW DLE30! - 12/10/2011 6:21 PM
tail heavy
Score: 105
Status: offline
Sounds good Capt'n. Might save some search time for some people.
Alan
Hide Signatures
       Post #: 4824
RE: NEW DLE30! - 12/11/2011 2:44 AM
raubold
Score: 105
Status: offline
But i still see all the questions repeated on the horizon, would be nice to just filter out just actual information, might be a top notch DLE Manual after that.
Hide Signatures
       Post #: 4825
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.531RCU1
