RE: NEW DLE30!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Page: <<   < prev  192 193 194 195 196 [197] 198 199 200 201   next >   >>
Login
RE: NEW DLE30! - 2/3/2012 8:20 PM
GSK
Score: 105
Last Login: 5/3/2013
Status: offline
do you get that burble sound sound when going lean or is it still a bit rich?
 It tends to be a little on the rich side ,
 Do not be too keen to get rid of it unless it is really annoying .
I usually keep an eye on the plug when leaning it out at that stage , the motor tuning will change as it gets more running .
 Graeme
Hide Signatures
(in reply to airraptor)
       Post #: 4901
RE: NEW DLE30! - 2/3/2012 9:07 PM
DaleD
Score: 105
Last Login: 5/19/2013
Status: offline
I think the burble is an indication of a slightly right low end.  Some modellers will tune their engines this way to facilitate easier starting.
Hide Signatures
       Post #: 4902
RE: NEW DLE30! - 2/3/2012 9:53 PM
airraptor
Score: 130
Status: offline
yes it doesnt bother me at all. it does it at full throttle but only in tight turns or hard pull to verticle.
Runs great. compression is geeting so good now the Dynatron cant turn it over. Hand start with the wood props but the APC's I use the starter.
Once i get some other cylinders and pistons we will start working on them to see what we can get out of them. Both high rpm power and some high torque ones.
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to DaleD)
       Post #: 4903
RE: NEW DLE30! - 2/4/2012 8:24 PM
Night Scream
Score: 104
Last Login: 4/12/2013
Status: offline
Hi everyone:
I'm looking for anyone that might still have the original dle30 side carb backplate and everything that came with It.
The small mounts that came with it and the black carb divider.
If anyone has this please e-mail me at: yusenkyo@yahoo.com. or pm me here.
Thank you.
Hide Signatures
(in reply to jedijody)
       Post #: 4904
RE: NEW DLE30! - 2/4/2012 8:25 PM
Night Scream
Score: 104
Status: offline
Hi everyone:
Thank you.
Hide Signatures
       Post #: 4905
RE: NEW DLE30! - 2/5/2012 3:10 AM  1 votes
ahicks
Score: 669
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: airraptor
I have another question for you guys. I have the DLE mounted in a H9 miss america. The engine runs well great idle of 1,700 and good midtop end. The engine has a burble or sounds rich when going into tight turns or a pull to verticle. I will be installing the telemetry stuff this weekend.
do you get that burble sound sound when going lean or is it still a bit rich? Also in a dive it will get that burble every now and then.
A while back somebody mentioned they had a midrange burble they couldn't tune out. My first thought was welcome to the club! Well then he mentioned he cleaned his up by opening the spark plug gap - to .024 - and fixed it!!!! I thought, yea, right... but I've seen weirder, so I tried it. It worked. My midrange burble is gone.
It's worked on a few others since. The DLE 20 sometimes does that the same thing, and also responds well to the opened up gap...
Might be worth a try if you haven't already.
Hide Signatures
       Post #: 4906
RE: NEW DLE30! - 2/18/2012 12:49 AM
Beej
Score: 100
Status: offline
Hi Everybody,
I have searched this and other forum extensively but can't find an answer to the following question.....
I have a new EF Extra 78, DLE 30 and ES 30g pipe - is there an "off the shelf" header/plumbing solution - the pipe runs immediately aft of the engine, down he centre line. Suggestions appreciated. Guess at the very least if I had some indication of a short header followed by some KS (or similar) plumbing I could get it together.....
Thanks!
Beej
Hide Signatures
(in reply to ahicks)
       Post #: 4907
RE: NEW DLE30! - 4/14/2012 1:14 PM
FLYING-HIGH2
Score: 100
Last Login: 4/27/2012
Status: offline
did you ever get a header for your engine?
Hide Signatures
(in reply to Beej)
       Post #: 4908
RE: NEW DLE30! - 4/17/2012 12:27 PM
DaleD
Score: 105
Status: offline
A couple posts back in this thread, maybe more than just a couple, the WT-813 was recommended as a suitable replacement for the DLE 30 carb.  Would the WT-805 supplied with the MLD 35 work?  I notice the venturi is about 0.8mm bigger on the WT-805.
DaleD
Hide Signatures
(in reply to FLYING-HIGH2)
       Post #: 4909
RE: NEW DLE30! - 4/17/2012 2:19 PM
greg palmer
Score: 100
Last Login: 4/2/2013
Status: offline
I have a problem with my dle 30 it has a pop to it from 1/4 to full throttle I have tried tuning it out with no luck changed the spark plug and gapped it a .018-.019 and just switched to Stil hp ultra 50:1 oil with no luck yet. I think I could have a timing issue does anybody have any thoughts on this.
Hide Signatures
(in reply to DaleD)
       Post #: 4910
RE: NEW DLE30! - 4/17/2012 3:03 PM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: greg palmer
increase gap to 24 , see if that helps
i remember i did everything i could think of on my 30cc, just about when i gave up the popping started subsiding.... i guess it needed more run time.
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to greg palmer)
       Post #: 4911
RE: NEW DLE30! - 4/17/2012 5:02 PM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: MetallicaJunkie
One of my 30s acted like this too. Increased the plug gap to .024 or so and the problem went away. I really don't know what the exact plug gap is as I just opened it up some from the .020 it was set at and all was well so I left it alone from there.
Some people reported a similar problem when running the engine on a freshly charged battery. The problem going away after a bit of run time. I don't know much about this problem other than what I have read though. You might do some searches for additional info.
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 4912
RE: NEW DLE30! - 4/17/2012 6:40 PM
CK1
Score: 150
Status: offline
greg ,
This seems to be a fairly common issue on some of the 30's and the 55's that I have delt with . Some or most of the engines with your concern are taking a long time to break in as well . The Bowman ring has been successful in curing some by allowing a quicker break in and a better cylinder seal. Some require a little more running time and resolve themselves .
I would do the following things in this order .Some of which you have already done.
1) Use a freshly charge 4.8v ignition pack
2 ) Use a real CM6 plug gapped at .024 "
3) Verify the Ignition timing is set to no more than 30 deg BTDC (28 BTDC is recommended ) I have checked several DLE engine than were at over 40deg BTDC ,way too advanced.(see related threads on how to properly set the ignition timing)
4)After the above steps are completed retune the carb (see related threads on proper carb adjusting) If problem persists go to set 5
5) add a tube and a vent line to the carb diaghram vent and place the open end in the fuse away from irratic pressure changes that may effect carb tuning and performance
and recheck carb tuning after adding vent tube ( steps 4 and 5 can be performed in reverse order to reduce repeditive tuning if desired) (see related threads on carb vent lines)
6) After proper tuning is achieved fly , fly, fly .... If the engine is not improving after a few more gallons of flying time , replace the piston ring with a Frank Bowman ring and retune.
7) A key factor here is tuning after any other changes are made ,(timing , plug gap , prop size or brand , mechanical changes .. all have an effect on engine tuning needs.
Its a procees of elimination begining with the most basic , simple and least expensive .
The above list does not deal with possible internal carb faults (hard diaghrams , incorrect needle arm hieght), but those are the least common on a low time engine with the exception of a dirty internal screen which is easily checked
"Aint this great !!" - Chris
"Nosen Cessna 310 Club" #8
Hide Signatures
       Post #: 4913
RE: NEW DLE30! - 4/17/2012 6:53 PM
greg palmer
Score: 100
Status: offline
I'm going to start with gapping the plug at .024" and see if that helps.
Hide Signatures
(in reply to CK1)
       Post #: 4914
RE: NEW DLE30! - 4/17/2012 7:04 PM
Mikecam
Score: 120
Last Login: 5/18/2013
Status: offline
My 30 had 35* and a high speed mis/pop. 32* gives easy starting, normal temps and 7450 RPM. 28* gave 7100 RPM's. The Canadian Warranty shop sets his DLE 30 engines at 32*. 1/4 throttle sounds low for the timing pop but worth checking.
http://www.youtube.com/watch?v=GBXFpxWg7vY
Hide Signatures
       Post #: 4915
RE: NEW DLE30! - 6/16/2012 9:13 PM
ricochet59
Score: 100
Status: offline
Hi all, I could use some help. This is my first gas engine, read through this thread and others. I'm putting the DLE30 in a Seagull Spacewalker 120. The choke seems a little stiff, so I'm using a Hitec 645 servo (metal gear, high torque, analog). There is about a 2" drop from the engine to the servo tray. I was thinking of using Sullivan 4-40 Nyrods (or similar), but the 4-40 I don't think would bend enough. My other thought was to use metal pushrods on the throttle and choke, and use Dubro ball links on the engine end. Is this enough to separate the metal to prevent RF interference. Any help and ideas would be greatly appreciated.
Rod
Club Saito #803
Hide Signatures
(in reply to Mikecam)
       Post #: 4916
RE: NEW DLE30! - 6/16/2012 10:36 PM
cmptrguy
Score: 100
Last Login: 4/13/2013
Status: offline
Yep, That will work just fine- I use exactly the same setup on one of my DLE-30's. No problems at all. Welcome to the world of Gassers, Cheap fuel, dependable and just Flip and Fly - no starter box required.
Computer guy
Hide Signatures
(in reply to ricochet59)
       Post #: 4917
RE: NEW DLE30! - 6/17/2012 5:45 AM
Sbach342Guy
Score: 100
Status: offline
Has anyone had issues with their engine fading like it's gonna stall when coming out of a banked turn? It hasn't actually stalled yet so maybe my ears are just playing tricks on me.
Hide Signatures
(in reply to cmptrguy)
       Post #: 4918
RE: NEW DLE30! - 6/17/2012 12:50 PM
iflywhenican
Score: 100
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: DonLEmmel
Yep..sure have. You may want to do what I did and clean the wire screen filter in the carb. It was loaded with factory crap. After I did the cleaning and re-adjusted the needles, I have had no problems. Hope this helps.
If you have to bend over more than once, it wasn''t a good landing....
Hide Signatures
(in reply to Sbach342Guy)
       Post #: 4919
RE: NEW DLE30! - 6/17/2012 1:33 PM
ricochet59
Score: 100
Status: offline
Thanx CMPTRGUY. I think that will make the setup a lot easier.
Rod
Club Saito #803
Hide Signatures
(in reply to iflywhenican)
       Post #: 4920
RE: NEW DLE30! - 6/17/2012 2:41 PM
SkyPilot101
Score: 125
Status: offline
quote:
ORIGINAL: ricochet59
Hi all, I could use some help. This is my first gas engine, read through this thread and others. I'm putting the DLE30 in a Seagull Spacewalker 120. The choke seems a little stiff, so I'm using a Hitec 645 servo (metal gear, high torque, analog). There is about a 2'' drop from the engine to the servo tray. I was thinking of using Sullivan 4-40 Nyrods (or similar), but the 4-40 I don't think would bend enough. My other thought was to use metal pushrods on the throttle and choke, and use Dubro ball links on the engine end. Is this enough to separate the metal to prevent RF interference. Any help and ideas would be greatly appreciated.
Rod
Stiff Choke??? In my experience anyway, the choke on the 20 & 30 were a little stiff out of the box, oil the brass choke shaft were it passes through the carb body, and work it open & closed awhile, should loosen right up. The pre-mix should keep it lubed from there.....
Hide Signatures
       Post #: 4921
RE: NEW DLE30! - 6/17/2012 6:28 PM
ricochet59
Score: 100
Status: offline
Thanx for the tip, I'll try that when I get home in July.
Club Saito #803
Hide Signatures
(in reply to SkyPilot101)
       Post #: 4922
RE: NEW DLE30! - 6/17/2012 6:47 PM
AA5BY
Score: 153
Status: offline
Rod
Yes... it should be adequate separation.
btw... don't put the Seagull Spacewalker into a flat spin with CG on recommended position.
Hide Signatures
       Post #: 4923
RE: NEW DLE30! - 6/27/2012 4:10 PM
greg palmer
Score: 100
Status: offline
Ok its been a while with IMAC and work I finally got to work on my dle 30 increased plug gap to .024" no luck, on the ground it seemed to be ok but once in the air the miss would come back, played with the hall sensor still no luck. My next thought is to change out the ignition with a known good one which I have since I'm building a 3DHS extra with a dle 30 that I know does not have a miss.
Hide Signatures
(in reply to AA5BY)
       Post #: 4924
RE: NEW DLE30! - 7/14/2012 7:39 AM
yurdakut
Score: 100
Last Login: 4/7/2013
Status: offline
dear friends I m sorry if you have talked this before..I have dle 30 cc I live 1800 metres( nearly 600o feet) above sea level..we have no humidity problem here....so can I use gasoline il mixture(hidden in a well closed box in a cold area)  1 weeks after I have mixed it..?and is it different for mineral and synthtetic oil mixture ?
Hide Signatures
       Post #: 4925
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.609RCU1
