RE: NEW DLE30!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Page: <<   < prev  192 193 194 195 196 197 198 [199] 200 201   next >   >>
Login
RE: NEW DLE30! - 10/14/2012 7:57 PM
cmptrguy
Score: 100
Last Login: 4/13/2013
Status: offline
drube:
The pilot Sbach is a 73" wingspan for the 30CC size.
cmptrguy
Hide Signatures
(in reply to greg palmer)
       Post #: 4951
RE: NEW DLE30! - 10/14/2012 8:24 PM
Mikecam
Score: 120
Last Login: 5/18/2013
Status: offline
If it was at 35 degrees and you moved it to 33 degrees it still could be the timing. Not one of my 3 DLE's had the correct timing, not out by much (1 or 2 degrees at most) but out nonetheless.
Video showing how to check.
http://www.youtube.com/watch?v=GBXFpxWg7vY
Print out and glue on to a piece of cardboard. Keep hole in the center small enough so it is hard to push over engine hub.
http://ch-ignitions.com/img/cms/timing/imageEPQ.JPG
Hide Signatures
       Post #: 4952
RE: NEW DLE30! - 10/22/2012 1:58 AM
Neddy191
Score: 100
Status: offline
This is probably a stupid quesion. I have a new DLE30 for a plane I'm building. When I got it from Tower I also bought the prop drilling guide for it. I got a Xoar beechwood prop. The hole in the prop is a bit smaller than the roudn piece in the center of the drilling guide so I can't bolt the prop onto the guide. I guess my question is what is the best way to enlarge that hole so the guide will fit. I'm wondering the best way to ensure it stays centered. Can I just put the proper sized drill bit on my drillpress and go for it or is there something other way I should do it instead?
Hide Signatures
(in reply to Mikecam)
       Post #: 4953
RE: NEW DLE30! - 10/22/2012 2:08 AM
w8ye
Score: 318
Status: online
The best way is with a prop reamer.
But as you have a drill press . . .  Select a drill bit the size of the original hole in the prop and with the bit mounted in the chuck, use it to located the prop exactly centered under the chuck and then clamp the prop down.
Then install your new size drill bit and slowly make the hole larger.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Neddy191)
       Post #: 4954
RE: DLE30! - 11/10/2012 2:07 PM
drube
Score: 115
Last Login: 5/15/2013
Status: offline
Hi guys,
 What size fuel tanks are you using and what kind of flight times are you getting?  I'm not sure what size tank to use but I would like to get at least 10 to 12 min flight time or longer.
The plane is a 25% Extra 230
My Music
http://www.reverbnation.com/tunepak/3545294
Hide Signatures
(in reply to DL826)
       Post #: 4955
RE: DLE30! - 11/12/2012 1:25 PM
drube
Score: 115
Status: offline
Anyone?
My Music
Hide Signatures
(in reply to drube)
       Post #: 4956
RE: NEW DLE30! - 11/12/2012 1:48 PM
ahicks
Score: 669
Status: offline
Somebody was talking about an ounce a minute, which sounds about right to me for wide open throttle?
Hide Signatures
(in reply to drube)
       Post #: 4957
RE: NEW DLE30! - 11/12/2012 1:51 PM
guille2006
Score: 109
Last Login: 5/17/2013
Status: offline
Half a litter will be more than enough for that time...
Exocet Engineering & Design.
Hide Signatures
(in reply to drube)
       Post #: 4958
RE: DLE30! - 11/12/2012 9:40 PM  1 votes
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: drube
Hi guys,
12oz is more than enough
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to drube)
       Post #: 4959
RE: NEW DLE30! - 11/13/2012 1:06 AM
greg palmer
Score: 100
Last Login: 4/2/2013
Status: offline
I use a 16oz tank and after 10 to 12 minute flight I still have at least a half of a tank. That's a little bit of 3d and IMAC style flying.
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 4960
RE: NEW DLE30! - 11/13/2012 2:20 PM  1 votes
Cyberwolf
Score: 655
Status: offline
Yep I cut my tank size down to a 10 OZ on my 30 and still have close to half a tank after a good 10 min flight
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
       Post #: 4961
RE: NEW DLE30! - 11/14/2012 5:48 PM
MartyH
Score: 105
Last Login: 12/6/2012
Status: offline
Same as Greg. Mix of IMAC and full power on 12 minute flight leaves about 1/2 tank.
Hide Signatures
(in reply to Cyberwolf)
       Post #: 4962
RE: NEW DLE30! - 11/15/2012 1:53 AM
RBean
Score: 115
Last Login: 5/16/2013
Status: offline
I need some help with 3 blade prop size for the DLE 30. I have a DLE 30 installed in a Black Horse 70" wing span FW 190. Presently it has an 18-8 Master Airscrew 2 blade. Static rpm is 8,450. The plane has more than enough power. Also I think maybe in flight its too much rpm, probably exceeding 9,000. I want to install a 3 blade prop for the scale look. The selection of 3 blade props in the possible appropriate sizes is some what limited and they arn't cheap. I had a Beila 17-10 I had aquired somewhere. Installed it. Static rpm was only 5,500. I'm thinking maybe a Zinger 17-8 or 18-6 three blade. Does anyone have any info or testing in this regard? These prop are too expensive for me to buy four or five for testing. Here are picture of the plane with the 2 blade and the Beila 17-10 three blade.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MartyH)
       Post #: 4963
RE: NEW DLE30! - 11/15/2012 2:03 AM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
Rbean - the three blade prop definitely looks more scale. I don't know about Zinger 3-blade props, but the 2 blade Zinger's I've tested are better suited to stir paint.
Hide Signatures
(in reply to RBean)
       Post #: 4964
RE: NEW DLE30! - 11/15/2012 4:03 AM
DaleD
Score: 105
Status: offline
I would suggest you look at a 16" prop for three blade.  Check out the 16.5x10x3 from Bolly http://www.bolly.com.au/models/glassthree.html
DaleD
Hide Signatures
(in reply to RBean)
       Post #: 4965
RE: NEW DLE30! - 11/15/2012 1:30 PM  1 votes
ahicks
Score: 669
Status: offline
I would suggest staying away from a 6" pitch for a military plane? They're more for the slow (Cub), 3D or acrobat types looking for good vertical. 8" pitch would work better I think, but 10" might work OK too? If that's of any help.... -Al
Hide Signatures
(in reply to DaleD)
       Post #: 4966
RE: NEW DLE30! - 11/16/2012 4:54 AM
RBean
Score: 115
Status: offline
I took the 190 to the field and test flew the 17-10 Biela three blade prop. I put 1/8 turn rich on the high end because this prop is going to put more load on the engine. Turning up about 6,000 rpm at the field. It felt like enough thrust. A club member suggested a high speed taxi to see how it felt. So I did, but waited too long to throttle back and plane took off. Seemed to be enough power, then engine started sagging. I throttled back and it kept running so I put the gear down and didn't move the throttle until final. Landed ok. I put another 1/8 turn rich on the high end and 1/8 turn rich on the low needle. Ran ok until I pulled the nose up, sagged again. Landed ok. now 1/4 turn rich. Took off, too rich. 1/8 turn lean. Took off ok. Ran ok. aceleration after take off is slower but gets up to good speed and ran ok in level flight, but when I pulled up to do a loop the engine slowed and started four cycling. Not much verticle with this prop. Also the engine seems more sensitive to needle adjustments running this much prop.
Just confirmed what I thought. This is too much prop for the engine. Any prop shorter than 17" wouldn't look right on this plane with the big cowling. I think a 17-8 three blade is the way to go. I agree a 6 pitch wouldn't be enough. Now I need to find a 17-8 three blade prop.
Hide Signatures
(in reply to ahicks)
       Post #: 4967
RE: NEW DLE30! - 11/16/2012 12:29 PM
iflywhenican
Score: 100
Status: offline
Try Troybuilt Models.
A three blade prop looks good on this model or any warbird for that matter, but a three blade is not as efficient as a two blade.
If you have to bend over more than once, it wasn''t a good landing....
Hide Signatures
(in reply to RBean)
       Post #: 4968
RE: NEW DLE30! - 11/16/2012 12:42 PM
microdon2
Score: 110
Status: offline
Agree with Iffy - everything I've read says the less prop blades the more efficient the prop. Though, if you've got an over-powered engine you can afford a little less prop efficiency, especially if you need the ground-clearance. Pretty sure why this setup works on the real-life warbirds.
I picked up an H9 P51 150 (80") with an MVVS 35 here on RCU. I'm putting a Xoar 2-blade 20x8 in it (recommended for this engine). Once I reinforce the retract area of the wings I'll fly it and let you know.
Hide Signatures
(in reply to iflywhenican)
       Post #: 4969
RE: NEW DLE30! - 11/16/2012 12:48 PM
iflywhenican
Score: 100
Status: offline
Hey Don...Haven't heard from you in quite a while, hope all is well.
Congrats on getting the P-51, they are a lot of fun and also a bit tricky...so be carefull...
Hide Signatures
(in reply to microdon2)
       Post #: 4970
RE: NEW DLE30! - 11/16/2012 12:58 PM
microdon2
Score: 110
Status: offline
Iffy - thanks. On the DLE 30 I'm still impressed by this engine's power. I have mine on a CG Sukhoi (73") swinging an APC 18x10 and it's got great speed and unlimited vertical. Really impressive. Once I get some 3D practice on foamies I'll try a Xoar 20x8 on the Sukhoi and try some 3D with that.
With the P51 - yeah - I had one flight so far. The plane \ engine came with no muffler - only a header - so was loud as hell - 97db. They let me fly it anyway, but I was nervous and came in too slow. The plane dropped the last 3 feet and the gear grabbed in the grass runway, ripping them off, damaging the wings. But it's amazing how LITTLE reinforcement H9 designed into the retract area. So, reinforcing the wing is my next project. Am hoping the replacement stock retracts are strong enough on smooth landings (good retracts cost a fortune...)
Hide Signatures
       Post #: 4971
RE: NEW DLE30! - 11/16/2012 1:08 PM
iflywhenican
Score: 100
Status: offline
Yeah, I have the DLE 30 on a Goldwing Yak, swinging a Xoar 18-10 also...like you say, unlimited vertical, more power that you can believe from this engine.
On the P-51, you are right, they seem to think that toothpicks will be enough for the landing gear on these planes...NOT for a grass runway as I have found out... ...unless you re-inforce it well.
Hide Signatures
       Post #: 4972
RE: NEW DLE30! - 11/16/2012 2:23 PM
drube
Score: 115
Status: offline
Thanks guys.
My Music
Hide Signatures
       Post #: 4973
RE: NEW DLE30! - 11/16/2012 2:28 PM
w8ye
Score: 318
Status: online
WHEEL PANTS and RETRACTS do not like GRASS!
Original AMA #31261
Hide Signatures
(in reply to drube)
       Post #: 4974
RE: NEW DLE30! - 11/16/2012 8:58 PM
Mikecam
Score: 120
Status: offline
Most efficient prop is a one blade.
Hide Signatures
(in reply to w8ye)
       Post #: 4975
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
