RE: NEW DLE30!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Page: <<   < prev  133 134 [135] 136 137 138 139 140 141 142   next >   >>
Login
RE: NEW DLE30! - 7/18/2010 9:04 PM
captinjohn
Score: 247
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: captinjohn
Do many heat cycles
Got to make fast short replies...my connection keeps kicking out!   Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to captinjohn)
       Post #: 3351
RE: NEW DLE30! - 7/18/2010 9:45 PM
Switch_639
Score: 324
Last Login: 4/15/2011
Status: offline
heat cycles? and how many is many...
Hide Signatures
       Post #: 3352
RE: NEW DLE30! - 7/18/2010 10:24 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: Switch_639
10-15 per day...for 7 days  after shutting down...park piston at Top dead center.  Capt,n
Click to see fullsize image.
Click for fullsize
< Message edited by captinjohn -- 7/19/2010 7:51 AM >
Hide Signatures
(in reply to Switch_639)
       Post #: 3353
RE: NEW DLE30! - 7/19/2010 10:51 AM
HornetFitter
Score: 100
Last Login: 5/19/2013
Status: offline
Finally got my DLE 30 sorted out. It would start with a new plug, but would only run (sputtering) for about 15 seconds, then nothing. Testing for spark outside the combustion chamber revealed a strong arc, but it would not fire reliably when installed in the combustion chamber. After going through 3 NGK plugs, I figured...This thing just SUX! So, I got a return authorisation number from HK and ordered one from another supplier. I initially installed the carb and reed block from the new engine, but the result was negligable, So, I switched out the ignition pack and it fired right up (untill my neighbour came out and complained aout the noise. (it was 10 pm....It is OK to make as much noise as they want when his buddies are over drinking on a Friday night though). So I shut it down and called it a successful night.
2009 CF-18 Hornet Demo Team
Hide Signatures
       Post #: 3354
RE: NEW DLE30! - 7/19/2010 5:43 PM
Super08
Score: 135
Last Login: 5/17/2013
Status: offline
Good to hear. I was down in you neck of the woods for the first two weeks of July. I went out to the field a couple of times, but no one was around. The dogs had fun running around anyways. I see the land is up for sale. That may cause you problems down the road if someone wants to use the land for crops. I spent some time sitting up the road from AETE watching the boys do circuits. What can I say... I miss home.
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
(in reply to HornetFitter)
       Post #: 3355
RE: NEW DLE30! - 7/19/2010 7:45 PM
HornetFitter
Score: 100
Status: offline
quote:
ORIGINAL: Super08
You should have fired off a PM to me. I would have been happy to come out with my 1/4 Cub on floats (Not really; just sick of all the rain)...Yes, the land went on the block this spring. It will most likely be used for residential development. All the builders are buying up land just outside city corporate limits, to avoid the high taxes in town. The "bird watching area" gets some heavy use during Maple Flag, but there is usually something happening most days.
Take care!
D
Hide Signatures
(in reply to Super08)
       Post #: 3356
RE: NEW DLE30! - 7/20/2010 7:11 AM
bigtim
Score: 132
Status: offline
finally got the 30 mounted in my ESM FW190, after some tribulation I went ahead and got these stand offs from china, to extend the engine out enough to fit the cowl opening location,a perfect match for my pits style muffler I got from Jody as well, nice looking offering BTW, the 30 fits cleanly in the cowl of the ESM FW with just the plug sticking out the bottom of the cowl.
my plan is to mount the ign. to the firewall and the battery directly underneath to keep my weight forward, any reason i couldn't use a metal strap to secure the ign or would a plastic zip tie be a better option.
here's a shot of my repainted FW 190A the stock paint is not really all that close to scale
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3357
RE: NEW DLE30! - 7/21/2010 4:21 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: bigtim
If you can keep ignition & battery away from the exhaust.  Looks like you could place 2 balsa sticks 90 degree across the top standoffs.  Maybe use stick foam strips lengthwise of battery and use tie raps or good rubber bands to hold to top stand-offs.  You need air to circulate around the ignition & battery...but still keep vibration out.  Just  a Idea!
        Capt,n
Hide Signatures
(in reply to bigtim)
       Post #: 3358
RE: NEW DLE30! - 7/22/2010 9:55 PM
jvg69
Score: 100
Last Login: 12/6/2011
Status: offline
YES, LIKE RUNNING AN ENGINE AT W.O.T. THAT HAS NOT BEEN BROKEN IN YET. IF YOU DIDNT KNOW WHAT YOU WERE DOING WHY NOT ASK SOMEONE WHO IS EXPERIENCED. NOW YOU ARE GOING TO SAY ITS A WARRANTY ISSUE WHEN ITS NOT,ITS ABUSE.
Hide Signatures
(in reply to Tired Old Man)
       Post #: 3359
RE: NEW DLE30! - 7/23/2010 5:15 AM
maddog 71
Score: 100
Last Login: 5/2/2013
Status: offline
Just got my first DLE 30 whats the little clear plastic clips for looks like they fit the cooling fins for something?
http://www.facebook.com/pages/Timberlake-RC-Club
Spitfire Brotherhood # 159
Hide Signatures
(in reply to jvg69)
       Post #: 3360
RE: NEW DLE30! - 7/23/2010 5:27 AM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
They are meant to be used for holding the radio plugs for the ignition together.
Now go outside and play
Hide Signatures
(in reply to maddog 71)
       Post #: 3361
RE: NEW DLE30! - 7/23/2010 5:29 AM
maddog 71
Score: 100
Status: offline
OK thanks!
Hide Signatures
(in reply to jedijody)
       Post #: 3362
RE: NEW DLE30! - 7/23/2010 5:41 AM
captinjohn
Score: 247
Status: offline
Well I had to take time to clean the shop....took about 2 hours!!!!  Anyway I found a special part I made on the lathe....nice side benifit.  Also got most of the things I will need to finish one plane.  It looks like it will not be in time for our anual fly in.  I guess it may rain anyway.   The Beat goes on........................................................        Capt,n
Hide Signatures
       Post #: 3363
RE: NEW DLE30! - 7/23/2010 6:12 AM
Tired Old Man
Score: 662
Last Login: 1/16/2012
Status: offline
quote:
ORIGINAL: jvg69
I'm not too clear on what you're referring to. Please enlighten me.
If my experience level troubles you, I'm definately open to your expert tutelage I suppose shortly after you are taught that using all caps is viewed as yelling at someone in internet protocol you could step up and show me all that I need to know about the proper handling and running of two stroke gas engines. Shall we start with carbureted, injected, or heavy fuel versions? What about injected heavy fuel? Singles, opposed twins and quads, inlines, or radials? By brand perhaps? I'm all ears and desparate to glean as much useful and pertinent information from you as I can
I should quote P.T. Barnum here but I'll restrain myself. Your reply would be both appreciated and entertaining.
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to jvg69)
       Post #: 3364
RE: NEW DLE30! - 7/23/2010 7:25 AM
Super08
Score: 135
Status: offline
This is going to be good...lol.
Hide Signatures
       Post #: 3365
RE: NEW DLE30! - 7/23/2010 8:16 AM
captinjohn
Score: 247
Status: offline
Yup....funny....read all 6 posts......from....
Hide Signatures
       Post #: 3366
RE: NEW DLE30! - 7/23/2010 8:40 AM
Tired Old Man
Score: 662
Status: offline
Read two of them. A TBM employee it appears. That other UAV company, lol. Still clueless with the reference and applicability of his post.
I would very much like to learn why a new engine cannot be run at wot. There is clearly much I have to learn about the correct operating methods concerning new small gas two strokes.
Hide Signatures
       Post #: 3367
RE: NEW DLE30! - 7/23/2010 9:42 AM
jetmanr18
Score: 100
Last Login: 1/22/2013
Status: offline
Hi Jody!
I am new to the Giant Scene and need to ask you two questions:
1) Are there any "metric screw" torque tables in inch pounds anywhere in the forum? (I have a "TORX" screwdriver-type torque wrench).
2) Do you use or recommend the JIS screwdrivers instead of the American Phillips? (I'm having great luck with mine on Japanese engines!).
Brian Gray  -  jetmanr18
bgray191@mchsi.com
P.S. I'd PM you with this request, but I haven't yet figured out how...
Hide Signatures
       Post #: 3368
RE: NEW DLE30! - 7/23/2010 10:41 AM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
Hey pat, let me in on it too, we just ran a newly assembled GT80 race twin at about 10,500 on the test stand....Had about 5 minutes warm up time on it...
RC Ignition
Hide Signatures
(in reply to jetmanr18)
       Post #: 3369
RE: NEW DLE30! - 7/23/2010 11:14 AM
jedijody
Score: 309
Status: offline
quote:
ORIGINAL: jetmanr18
Hi Jody!
bgray191@mchsi.com
Well you must have heard about Google, it's this cool thing where anyone can type in any question and it will give you just as many different answers as a gas engine forum.
http://www.imperialinc.com/pdf/A_FastenerTorqueCharts.pdf
For inch lbs., multiply the foot lbs. by 12.
JIS fasteners suck, it's the Japanese just being different to be a pain in the butt. Plus, I doubt you will find the JIS screw drivers very handy on a Chinese engine held together with socket headed cap screws. They may come in handy though if your video camera needs a carb rebuild before filming your DLE30 maiden.
Hide Signatures
       Post #: 3370
RE: NEW DLE30! - 7/23/2010 4:27 PM
darkith
Score: 101
Status: offline
quote:
ORIGINAL: Tired Old Man
His post has a reference link to this old ToM post: http://www.rcuniverse.com/forum/fb.asp?m=9585744
Which is in reference to this post: http://www.rcuniverse.com/forum/fb.asp?m=9583821
Seems either like somebody with an axe to grind, or somebody doing searches and finding an post they just have to disagree with in ALL CAPS (and either not caring or not noticing that it's an old post).
Ahhhh, what fun.
D.
RCU Required Disclosure: Manufacturer of DBC battle circuit for Heng Long tanks.
Hide Signatures
       Post #: 3371
RE: NEW DLE30! - 7/23/2010 5:06 PM
Whistling Death
Score: 150
Status: offline
quote:
ORIGINAL: jvg69
That isn't as ridiculous as you guys (TBM) recommending 50cc engines for 13 lbs. planes.
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
(in reply to jvg69)
       Post #: 3372
RE: NEW DLE30! - 7/23/2010 5:26 PM
Tired Old Man
Score: 662
Status: offline
From their point of view it makes some sense. They get to sell a larger engine for more money and turn a larger profit. Not the right perspective but it would benefit them rather well.
Ralph,
Soon as the guy clues me in I'll give you a shout so you can sit through the classes too. I'm certain we'll both be able to expand our two stroke qualifications by an order of magnitude by listening to what this guy has to say I'm always open to expanding my knowledge base.
Hide Signatures
(in reply to Whistling Death)
       Post #: 3373
RE: NEW DLE30! - 7/23/2010 5:45 PM
Whistling Death
Score: 150
Status: offline
T.O.M. can you give us a play by play and break it down so the simple layman will be able to understand the techno-speak?
Blake
Hide Signatures
       Post #: 3374
RE: NEW DLE30! - 7/23/2010 7:05 PM
whitey84
Score: 100
Last Login: 7/24/2010
Status: offline
SSSSSSSSSooooo. how do you guys know it is a "he" ?? besides who cares ? arent we supposed to be on DLE ? i like reading about this motor even after 135 pages, but it seems to be wandering more and more onto petty arguments as to who knows more. bla bla bla. TOM you seem to be very knowledgeable and reasonably coherent, however, most of the time you cant seem help yourself. i would suggest you try to let some things go....... to be old and wise you must first be young and stupid.   this guy/ girl clearly hasn't read any of the thread and just has nothing better to do. seriously guys does this warrant 8+ posts ???
Hide Signatures
       Post #: 3375
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE30!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
