RCLander F-16 SEPO foam???
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RCLander F-16 SEPO foam???
Page: [1]
Login
RCLander F-16 SEPO foam??? - 6/27/2009 8:19 PM
mowery1
Score: 100
Last Login: 10/12/2009
Status: offline
Are the RC Lander F-16's Nitro models show in stock the new SEPO foam??? Do they have the newer metal retracts??? Hopefully someone from Nitro models will respond to this...
_____________________________
Authorized dealer for Fei Bao, Tamjets, Yellow Aircraft, Jetcat, Aero-Works, FlyEagle Jets, Extreme flight, Robart, DA..
Hide Signatures
       Post #: 1
RE: RCLander F-16 SEPO foam??? - 6/29/2009 2:20 PM
flyboytha1
Score: 100
Last Login: 11/6/2009
Status: offline
On The New Nitro Planes RCLANDERS F-16 New Metal Plate To Support The Landing Gear, And Yes The Foam Is The EPS Foam. I'm Sure They Will Start Offering The Metal Retract Upgrade Here Soon.
I Have A Build Thead On Here With Flight Video For The 6 Cell Setup Here's The Link:
http://www.rcuniverse.com/forum/m_8837730/tm.htm
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by flyboytha1 -- 6/29/2009 2:23 PM >
Hide Signatures
(in reply to Parkflying)
       Post #: 2
RE: RCLander F-16 SEPO foam??? - 6/29/2009 2:36 PM
mowery1
Score: 100
Status: offline
Thanks, I'll check out the build thread...
Hide Signatures
(in reply to flyboytha1)
       Post #: 3
RE: RCLander F-16 SEPO foam??? - 7/6/2009 7:11 PM
JWanca01
Score: 100
Last Login: 7/24/2009
Status: offline
Do you have this plane as well?
< Message edited by JWanca01 -- 7/6/2009 8:06 PM >
Hide Signatures
(in reply to mowery1)
       Post #: 4
RE: RCLander F-16 SEPO foam??? - 7/6/2009 8:05 PM
JWanca01
Score: 100
Status: offline
You mind if  I ask you what type of ESC; Motor; and servos you used. I just got the RCLander with retracts and its my firs kit where I need to put all parts in it. It is the 70MM and I basically need everything. I'm pretty new to this and changed it up from sport bikes to this.
Thanks in advance and I checked out some of your videos. Nice stuff
Hide Signatures
       Post #: 5
RE: RCLander F-16 SEPO foam??? - 7/9/2009 8:21 PM
Vasy
Score: 100
Last Login: 10/24/2009
Status: offline
Tower Pro sg90 or HXT900 servos work very well and are super cheap on ebay and other stores at max $5 each with shipping.
For the retracts make sure to get metal gear servoswith some torque, I'd look for at least 2.2 KG or more.
ESC need to be 60 AMP or more, you don't want to run cheap ESC at max. At full power on stock 4s motor will drain about 50 amps give or take a bit.
Make sure to get UBEC, you will fry ESC and risk loosing your plane for $10-$20 extra you would have to pay for one. With so many servos ESC with BEC will overheat and can just shut down in mid flight. Adding a chance that a retract servo can bind you are crazy not to.
< Message edited by Vasy -- 7/9/2009 8:32 PM >
Hide Signatures
(in reply to JWanca01)
       Post #: 6
RE: RCLander F-16 SEPO foam??? - 7/9/2009 9:40 PM
opjose
Score: 128
Status: offline
Yeah Bec's are often overlooked necessities, and newbies often blame burn outs and other problems on conditions caused by the lack of a separate BEC.
Decent Becs can be had for as low as $8.00 USD EACH.
Build em'''', fly em'''', crash em'''' and build more.
Hide Signatures
(in reply to Vasy)
       Post #: 7
RE: RCLander F-16 SEPO foam??? - 7/15/2009 2:43 AM
terrorsound
Score: 100
Last Login: 7/26/2009
Status: offline
I watched the build of the RC lander, very nice and I understood everything!! This is a good thing for me, I am looking at an RC lander f16 myself but the camo scheme..
Keep up the build videos, this is great education for us intermediate RC jet guys..
Thanks and keep them coming!!!
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
